How to: DIY Wedge Camper
Discussion in 'Tonneau Covers, Caps and Shells' started by Ripcord, Apr 15, 2019.
  1. May 9, 2021 at 10:55 PM
    #1821
    nanserb
    nanserb Well-Known Member
    Elliott
    2019 ZR2 Colorado
    I don't know if this has been asked, but is there any reason these "hidden" inside corner brackets couldn't be used?
    https://www.tnutz.com/product/hc-015-a/
    Thinking it would be easier to continue the kedar rails further into the corners that way...[​IMG]
    bfaris1 likes this.
  2. May 10, 2021 at 5:37 AM
    #1822
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Those are not anywhere near as strong as the outside brackets. The only thing that holds those in is the set screw.
    You’d be better off doing counterbores.
  3. May 10, 2021 at 8:04 AM
    #1823
    Beak
    Beak Active Member
    2020 White Tacoma SR 4x4
    Hey dudes, figured I'd do a bit of a longevity post here. I built my camper over the summer, and have had it on since Sept 2020. Camped in it in hot weather, cold weather, nuking snowstorms, blasting wind, and pissing rain. Done pretty OK in all.
    My setup is mounted on a 2020 SR Access cab SX, based out of Utah currently.
    While everything functions fairly well, a large number of my issues are caused by lack of insulation and poor ventilation.
    I've always had limited shop access and time to work on this project, so I've cut a few corners here and there to save on time/cost/complexity.
    My tent is solvent welded marine grade vinyl (glued) without any windows, with some hefty rain flaps (a recent addition), and attached with keder rails. I kept the narrow edge of the tent open for ventilation purposes, as it doesn't risk significant water intrusion down there.
    The big test this winter was 5 nights in February in the Mt. Bachelor parking lot. Dumped 6"+ of snow on us every day/night.
    Heated the camper with a diesel heater set outside, with a dryer vent tube plumbed through a hole in a side panel.
    Overall... Slept well each night, but by the end of the 5 days, there were condensation icicles hanging from the inside of the camper. The Dibond material is almost the opposite of an insulator, and just sucks heat out like crazy.
    Anyways, I have some upgrade/update plans for the coming weeks here, and I figured I'll keep the world here in the loop as I do them.
    Problems to solve: Condensation, Driving Visibility, Poor rigidity/usability of side panels, heat loss in cold weather
    Solution: Remove hinges from side panels + rigid mount to frame with adhesive/rivets, add windows to all panels, add rigid foam insulation to all exterior panels.
    I didn't build my side panels particularly well, and they function just as poorly as they're built. In use though, I don't find myself wishing for side access too often.
    I have a set of windows harvested from a camper shell, and I plan to put those on my exterior panels. My thought is that the ventilation from the sliding windows, in addition to insulation, will solve my condensation issues.
    Cheers and happy building!
    Pickup90, DeanJ, PNW_Sparks and 3 others like this.
  4. May 10, 2021 at 10:01 AM
    #1824
    Afilao
    Afilao Tacoma Driver
    SoCal
    ‘18 MGM DCSB Off-Road 6MT
    I believe he’s talking about the interior brackets used in conjunction with the exterior ones. Ripcords list has some L brackets that are in the way of taking the rails that hold the tent all the way to the corners.
  5. May 10, 2021 at 11:32 AM
    #1825
    nzbrock
    Noah
    San Marcos, TX
    Yes by outside brackets I meant outside of the aluminum extrusion, not inside the extrusion like these that were posted.
  6. May 10, 2021 at 12:13 PM
    #1826
    Afilao
    SoCal
    That was great way for me to look like an idiot :bananadead:
    nzbrock[QUOTED] likes this.
  7. May 10, 2021 at 2:20 PM
    #1827
    bfaris1
    bfaris1 Well-Known Member
    Brian
    2018 White TRD OR
    6112 #700/5160 w/ Wheeler’s AAL RCI Skids Front to back RCI sliders SSO Slimline (Hi-clearance soon) Sungtop Various other crap
    This looks like what I was going to do I think it should hold up
  8. May 10, 2021 at 2:23 PM
    #1828
    Urineovrurhead
    Urineovrurhead Well-Known Member
    05 taco
    Foam board, probably just do an aluminum sheet for the exterior. Interior will be 1/4” birch plywood with poly.
  9. May 10, 2021 at 2:38 PM
    #1829
    nanserb
    Elliott
    2019 ZR2 Colorado
    Yeah I meant like inside the coner, instead of using the 15 series 4 hole inside corner bracket that interferes with the kedar rail mount.
  10. May 10, 2021 at 2:50 PM
    #1830
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    I would let the glue sit for 5-10 minutes after you spray it, it got super tacky when I did, held up a lot better.
  11. May 10, 2021 at 2:59 PM
    #1831
    bfaris1
    Brian
    2018 White TRD OR
    You think 3m adhesive or loctite glue? I got a tube for a caulk gun and was going to use that
  12. May 10, 2021 at 3:17 PM
    #1832
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    I went adhesive spray because I wanted to have 100% coverage/contact with the top panel. So that condensation couldn't form in between the layers.
  13. May 10, 2021 at 3:43 PM
    #1833
    AbePDX
    AbePDX Well-Known Member
    Abe
    Portland OR
    2007 Silver Mica Tacoma TRD OR V6 MT 6
    dis bish is done.......
    still more to come!
  14. May 10, 2021 at 4:07 PM
    #1834
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Wow, Great job @Ripcord . How in the hell have I not seen this thread before today is beyond me. This is the content I'm here for! Inspiring stuff and rad build. Keep up the good work :thumbsup:
  15. May 10, 2021 at 7:52 PM
    #1835
    PNW_Sparks
    PNW_Sparks Active Member
    Tyler
    The Dalles, OR
    2014 DCLB
    Custom Camper being built
    So unfortunatly my crazy vertical lift mec didnt work as I had planned. For the time being I'm just going to do a wedge. That way the wife and I can get outside and camp. We're getting real itchy for some camp time. Later down the road I plan on working a way to lift the roof up.
    DeanJ likes this.
  16. May 10, 2021 at 9:59 PM
    #1836
    PNW_Sparks
    Tyler
    The Dalles, OR
    2014 DCLB
    Also, has anyone tried velcro to attach the fabric to the camper rather then keder rail? Adhesive backed loop to the frame and then sew hook to the fabric. I might give this a shot over the keder rail.
    Afilao likes this.
  17. May 11, 2021 at 7:47 AM
    #1837
    Beak
    Beak Active Member
    @PNW_Sparks
    I'm not a fan of the keder rail personally. I think it adds a lot of complexity. I've played with the idea of using 5/16" ID grommets and bolting directly into the extrusion
    PNW_Sparks likes this.
  18. May 11, 2021 at 11:12 AM
    #1838
    Jarman02
    Jarman02 Well-Known Member
    Oregon
    2002 Tacoma Xtra Cab
    Sewing in the hem for the awning cord and mounting on the Keder rail was about the easiest part of the fabric portion of the tent lol. Adding velcro would substantially increase the time sewing (due to adding more sides to stitch) and I can 100% guarantee you that the adhesive will eventually fail on the velcro mounted to the extrusion. Gromets and bolting to the frame isn't too bad of an idea.
    Rando_lurker likes this.
  19. May 12, 2021 at 7:09 AM
    #1839
    nanserb
    Elliott
    2019 ZR2 Colorado
    The bush company uses rivets attached to a vertical piece of aluminum just inside the extrusion. No skirt needed that way.
    M61guru and Rando_lurker like this.
  20. May 12, 2021 at 5:25 PM
    #1840
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    I’m curious about doing that instead of the keder rail. It would solve the issue with the corners and interior brackets. Plus might be cheaper than the keder rail stuff
