How to do an Alignment at Home
Discussion in 'Suspension' started by jberry813, Dec 7, 2012.
  1. Jul 29, 2017 at 3:20 PM
    #221
    erok81
    erok81 Well-Known Member
    Imposter
    Thanks!
    I'll give it another shot.
  2. Jul 29, 2017 at 3:21 PM
    #222
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    This is partially incorrect. While it is true that both cams adjust both camber and caster, each cam influences one more than the other due to the way the "triangle" is oriented. If it were an equilateral triangle each cam would have the same impact on both, but it not. It's a scalene triangle. The ball joint on the LCA is closer to the forward cam, this results in the forward cam influencing camber more and the rear influencing caster more. Hence why the front cam is referred to as the "camber cam" and the rear is referred to as the "caster cam". On heimed uppers this is even more true since they form more of a "right triangle"
    Zebinator[QUOTED] likes this.
  3. Jul 29, 2017 at 3:26 PM
    #223
    tetten
    Andy
    Socal
    Also you have to add a third step to the process depending on how picky you are. After you find the maximum caster for both sides, if you want them to be equal you have to lower the side with the highest caster to match the side with the lower caster.
  4. Jul 29, 2017 at 3:34 PM
    #224
    erok81
    Imposter
    I'm probably just going to give up. This tool I bought sucks. And my caster measurements don't make sense either.
    I'm just going to make sure the toe is okay, straighten the wheel and call it good enough until I can find somewhere to align mine.
    I'm going to try the ford dealership. Find someone that can align a raptor. Then go there.
  5. Jul 29, 2017 at 3:43 PM
    #225
    tetten
    Andy
    Socal
    There are extra attachments for the tools you bought that may help to bite to the wheels. Also when I do mine I use digital angle gauges clamped to the tools, fuck those bubble level things.
  6. Jul 29, 2017 at 3:46 PM
    #226
    tetten
    Andy
    Socal
    What is wrong with the caster measurement?
  7. Jul 29, 2017 at 3:52 PM
    #227
    erok81
    Imposter
    I threw it across the garage and broke the bubble gauge. So that's taken care of. :rofl::rofl::rofl:
    It's clearly way more than it's ever been based on the distance between the wheel well and the tire but calculating I get somewhere around 1.x degrees of caster. The tool say 12+.
  8. Jul 29, 2017 at 3:58 PM
    #228
    tetten
    Andy
    Socal
    Get a magnetized digital angle gauge and a piece of steel flat bar, cut the flat bar so it fits against the wheel and use that. I've got those wheel clamps too, but only use those to set toe. Sometimes I clamp the digital angle gauge to those if I'm being lazy.
  9. Jul 29, 2017 at 4:05 PM
    #229
    erok81
    Imposter
    I'm going to try that and see what happens. I have a digital gauge but the way that tool works there wasn't really a good spot to get it flat.
    I bought toe plates for that part.
  10. Jul 30, 2017 at 5:45 PM
    #230
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Touche, but I was simplifying. ;) Would have been awesome if they'd made the LCA a right triangle with the one cam the right corner...
    tetten[QUOTED] likes this.
  11. Jul 31, 2017 at 7:31 AM
    #231
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    First at home alignment. Drive in today was pretty good, still got a little jumpy on me but it's also windy as shit today. If you see anything in these specs let me know, I'll gladly try again if you think it's needed.
    One side I couldn't get more caster out of it, I'm guessing it's because I'm cranked a little more on the driver side. Those TC cam gussets sure make it tight to move the cams around.
  12. Aug 6, 2017 at 2:30 PM
    #232
    ninja89
    ninja89 HUH?
    Question. On LT 4x4 kits... do they usually want you to run negative camber? And how much camber is it?
  13. Aug 6, 2017 at 4:53 PM
    #233
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Has nothing to do with LT. It's all about driver preference and driving style.
  14. Aug 7, 2017 at 2:41 PM
    #234
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    while i know it depends on the driver and driver preference. I drive aggressively, how much negative camber would you recommend on a daily like mine is. I'm damn near at 0 camber but i don't want to wear the outside tread down fast because cornering. I see you have yours around -2, but its not a daily and -2 seems like enough to cause premature wear on a daily. I know its more of a happy medium in the end, but what would you aim for if you were in my situation for camber. I'm leaning around 1*-ish. Im going to try to dick with it some more this weekend to hopefully squeak a little more caster out of the driver side since it sometimes still dances around, but nowhere near previous.
  15. Aug 7, 2017 at 2:46 PM
    #235
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    -0.5 to -1
    LTDSC[QUOTED] likes this.
  16. Aug 7, 2017 at 2:53 PM
    #236
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    maybe i wont mess with it anymore then....
  17. Aug 31, 2017 at 4:50 PM
    #237
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    Got a real alignment as I'm having some dancing still on the highway above 60mph. My caster cam is maxed out. All the way inward with the bolt on the outside. Camber is a touch positive. We adjusted it negative to see if caster would grow and this is where it's maxed.
    Beginning to think there's not much caster built into the BajaKits kit. As of right now I'll have to say my shit drove better before the kit.
    deeezy likes this.
  18. Sep 18, 2017 at 8:54 AM
    #238
    Neodous
    Neodous Well-Known Member
    Larry
    2016 Super White Toyota Tocoma TRD Off-Road
    Stock
    Wow I have no chance of getting mine in spec then. I have a 2016 with Fox 2.5s at about 2in of lift with Dirt King UCA'S and these are my numbers before I go back in and have the caster fixed.
  19. Sep 18, 2017 at 8:55 AM
    #239
    LTDSC
    LTDSC 32oz of fun
    Sam
    NorCal
    id kill for 4* caster
  20. Sep 18, 2017 at 9:27 AM
    #240
    Neodous
    Larry
    Stock
    Why lol
