How to do an Alignment at Home
Discussion in 'Suspension' started by jberry813, Dec 7, 2012.
  1. Dec 7, 2012 at 4:46 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    awesome stuff, thanks Jason :)
  2. Dec 7, 2012 at 6:32 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    nice how-to Jason!
  3. Dec 7, 2012 at 6:38 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Great thread
  4. Dec 7, 2012 at 6:43 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Jason for President. Well done.
  5. Dec 7, 2012 at 6:59 PM
    Large
    Large Red
    This. Great job.
  6. Dec 7, 2012 at 7:02 PM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Something's wrong.
    There's been nothing but accolades and kudos in this thread. Where are all the "constructive criticism" and trolling.
    Oh yeah....Whipper's perma. :p
  7. Dec 7, 2012 at 7:49 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Interesting method to get the caster, never knew how to do it!
    Very nice.
    FWIW I believe that when you have the wheels turned a direction they won't be turned to the same degree, this is the ackerman effect or whatever the hell. ... just for reference.
  8. Dec 7, 2012 at 7:53 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    100% correct.
    I figured if I went into the Ackerman geometry, I'd most likely derail the goal of the thread and inherently I would describe it incorrectly.
    nv529 likes this.
  9. Dec 7, 2012 at 7:56 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Haha fair enough! Well done though.
  10. Dec 7, 2012 at 8:00 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Haha anal. Not straight, haha.
  11. Dec 7, 2012 at 8:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Goddammit.
    Oh well...when in Rome
  12. Dec 7, 2012 at 8:08 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Awesome. :headbang:
    One point to add - for second gen guys with VSC - if the steering wheel ends up in a non-centered position, the VSC will be more likely to activate when turning left or right. If it's sufficiently off - it'll throw a code and deactivate ABS and VSC.
  13. Dec 7, 2012 at 8:12 PM
    Taco'09
    Taco'09 Well-Known Member
    Bravo OP!
    You wanted some constructive criticism, so here it is...... Actually, I don't have any only just a few observations after doing my own DIY home alignments for about five years, including four on my Taco and adding/refining stuff along the way to improve accuracy.
    Make sure the vehicle is level front-to-back and side-to-side; a carpenters level and the floor tile for shims will work on many floors. Great idea of yours for shims. Make sure tire pressures are correct. These are important because if your truck is sitting on an angle, it will introduce errors in the angle gauge in both camber readings and the calculated caster readings. My concrete garage floor looks level but has about a 3 3/4" slope from the front wheels to the back wheels.
    I found that it was necessary on my Taco to lock the brakes while doing the caster sweep because sometimes tire walk would occur and will give inconsistent readings. A 2x4 or something else wedged between the seat (protect the seat) and brake pedal works good.
    If you really want to get fancy, you you can introduce a simple string box around the truck and do thrust angle alignments as well. I use cheap-o polyester dayglo orange thread from Wal-Mart, jack stands, and steel rulers graduated to 1/128 in. to measure from the string to the centers and edges of the rims. Doing this you can get a truck that tracks straight as an arrow, correct for thrust angles and get a straight steering wheel.
    Not my intent to thread jack here but say don't be afraid to do a DIY alignment. The first one takes the longest and it gets easier each time.
    Nod69er, Calion, Jon64l and 1 other person like this.
  14. Dec 7, 2012 at 8:21 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Sounds like an advantage to me :crapstorm:
    Excellent points! We're in complete agreement about the surface being being level, both left to right and front to back.
    Locking the brakes is something I didn't think to mention but definitely an important point. Any measurable walk with the truck while doing the alignment will skew the end result.
    The string box method is a whole separate way to measure toe, but not one that will work on my truck and often complicates things for those guys running wheel spacers. I used the string box method with my old track car. However with this truck, I have extended UCA's and LCA's which pushes my front wheels out +3.5" over each side. As for the rear I have a Tundra axle which is only +3" over each side. String box method is less than perfect for people that have suspensions modified in the same manor as I. The spray paint and scribed line works regardless of modifications. As long as the wheels are not out of round, you can get a very accurate measurement. It's not nearly as accurate as string box, but it'll do!
    Governor likes this.
  15. Dec 7, 2012 at 8:23 PM
    #35
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    http://www.circletrack.com/techarticles/ctrp_0709_chassis_alignment/viewall.html
    You talking about something like this?
    We had to lay out right triangles in my HD PM class but I don't recall exactly how to do it. Something roughly like one of those pictures.
  16. Dec 7, 2012 at 8:53 PM
    #36
    Taco'09
    Yup. Nice write up in the Circle Track article.
    For my first string-box alignment I stole a write up from an Elantra forum that has great pictures and is easy to follow.
    But I heartily agree with the OP's comments above about the simplicity factor. The idea is not to scare anyone away from trying it, and IMHO his write up does a good job at this.
    For me, I simply got tired of getting burned by incompetent alignment shops and vehicles that pulled hard one way or another despite being "within specs." If you do a Google search you will find that many are similarly tired of being burned and have resorted to DIY techniques.
    I reached the point of anger one day after going to three different shops, same day, and getting totally different numbers at each shop. Car still pulled hard right.
    So I called Hunter Engineering and had a nice lengthy conversation with one of the engineers to ask why I was getting poor alignments despite wiz-bang lasers and computers from expensive machines.
    The answers amazed me. These things must be calibrated regularly and that costs substantial money for shops to have the factory techs come out. So many skip it. Also, if a head is dropped, or handled roughly, forget assuming the machine is in calibration. Is their rack level? Don't even assume so.
    MR E30 likes this.
  17. Dec 7, 2012 at 9:25 PM
    #37
    Taco'09
    bjmoose is correct in post no. 32 above.
    The FSM says you must do a Zero Point Calibration for the VSC/ABS whenever you do anything at all to the suspension, steering, and following alignments. The steering wheel has to be centered to do this, and the truck has to be level. Of course the stealership is more than willing to do this for you.......for a substantial fee.
    But it is easy to do yourself. I'm too lazy to look for a thread on this now, if there is one, but have it worked out on my '09 that has all the electronic nannies.
  18. Dec 7, 2012 at 9:35 PM
    #38
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Pffffffft. The dealer can kiss my shiny white ass.
    I did a zero point calibration on my wife's runner with a paperclip. Again, attaching relevant section of the FSM. Skip to step 4.
    EDDO likes this.
  19. Dec 7, 2012 at 9:40 PM
    #39
    Taco'09
    Ha. I love it. The paper clip is the expensive SST referred to! Good job.
  20. Dec 7, 2012 at 9:58 PM
    #40
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Caster is a PITA to measure accurately. Camber and toe are relatively easy.
