how to do front brake lines ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Jan 14, 2012.
  1. Jan 14, 2012 at 10:21 AM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Do you need to drain all the fluid out of the system before taking off the stock brake lines to put on the extended ones?
  2. Jan 14, 2012 at 10:29 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    No, but you might want small container (like a coffee can) to catch what leaks out when you breach the lines (remove)
  3. Jan 14, 2012 at 11:13 AM
    kinkrider101
    santa barbara
    wheels and tires
    So I can just take the wheels off and use a flare wrench and another wrench and take the lines off? For some reason I thought all the fluid would drain out.
  4. Jan 14, 2012 at 11:15 AM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    The fluid will drain but have you new line ready to attach right as you pull that one off and you won't have to refill your reservoir as much. Definitely bleed your brakes still because there will be air in the lines.
  5. Jan 14, 2012 at 2:00 PM
    kinkrider101
    santa barbara
    wheels and tires
    So the fitting on the hard line threads into the brake line correct?and the flare wrench is for the brake line fitting right?
  6. Jan 14, 2012 at 3:41 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    Any wrench of the correct size should work fine. The hardline is a female fitting and there should be a male/male fitting that allows you to connect it to the hose that goes to the caliper. Basically allowing you to connect 2 female ends together.
