How To: Door Actuated Map Light Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blue92, Jan 4, 2020.
  1. Jan 4, 2020 at 9:18 AM
    Blue92
    Blue92 [OP] Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    This will be the write up for installing a 3 Button door actuated maplight/mirror assembly.
    Tools Needed:
    Needlenose pliers, Wire Cutters, an angled trim removal tool, Philips Screwdriver, Flashlight, 10mm Socket and Ratchet, Your choice of wire strippers/crimpers, and a small flathead screwdriver.
    First things first, get power off the dome circuit. You can do this via disconnecting the ground battery lead. Or if you have an aftermarket stereo like me and dont want to screw up the settings, you can go under the hood and pull the dome circuit fuse. Its the little bugger that my pliers are on.
    Next, go ahead and pull the drivers A-Pillar. Pop the covers off the grab handle with the small flathead screwdriver, and undo the 2 10 mm bolts underneath. If you have a pre 01 truck, I hear these are JIS screws and a pain to remove.
    Once the handle is off, grab the pillar trim and pull down, then back towards you. After thats done, take your old mirror off. If you have a 2 button mirror, its easy. Just undo the little trim piece in the middle with a flathead, then reach up behind it and pry the cover down with the angled trim removal tool. Then unscrew the 4 screws holding the mirror up.
    The mirrors without maplights just have a plastic cover. Just pop it off and unscrew the mirror. You will have to cut the headliner, just line up your new mirror and trace out the holes. Then cut with a razor. The recess holes and screw holes are already in the metal under the headliner. This should be the finished product.
    Next you need to run 1 or 2 pieces of wire from the a pillar to where the mirror will go. Just pull the headliner down a bit and feed it up under. If you have the mirror with lights already, you'll just need 1 wire.
    Go ahead and splice in your new 2 wire connector for the new mirror. One wire should be red/green and the other is red/grey. The red/green wire will connect to the solid black wire in the a pillar, the red/silver will connect to the black/white wire in the a pillar.
    If you want to install a lighted key ring, it will also connect with the black/white wire. Since I already did this mod, I spliced my maplight into that wire.
    At this point, connect your mirror, screw it in place.
    If the new mirror is loose like mine was, you can swap in you old mirror to the 3 button assembly. Heres what the attatchment looks like.
    After the mirror is up, your wires are spliced, re connect the battery or re install the fuse and test. With the door switch on, the light should come on when the door is open, and go off maybe 20 seconds after the door shuts. Just like the dome light, or the key light.
    So now put the cover on the mirror, reinstall the A-Pillar trim and grab handle. Button up the fuse box and shut the hood. Youre done.
  2. Jan 4, 2020 at 9:26 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    how much more difficult is this to do if you do not have that type of headliner material?
  3. Jan 4, 2020 at 10:01 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    :notsure:
    Does your current mirror have the maplights or not?
    GQ7227[QUOTED] likes this.
  4. Jan 4, 2020 at 10:03 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    yes, i have the maplights already
    ... was just curious about others with my type of headliner that would like this convenient feature
    @Speedytech7 said the vinyl type of headliners are more challenging!
  5. Jan 4, 2020 at 10:05 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Well you wont have to cut it then. So this should be starightforward and easy.
  6. Jan 4, 2020 at 10:05 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Excellent write up! Thank you.
    GQ7227 and Blue92[OP] like this.
  7. Jan 4, 2020 at 10:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Interesting concept just why would one want to do this ?
    Nothing like having all kinds of lights come on when you open the door then wait till your night vision recovers so you can walk from the garage to the house
    Colchicine likes this.
  8. Jan 4, 2020 at 10:10 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    :notsure: Just another creature comfort that some people pay thousands more money for when they get their trucks. I saw it in the junkyard, and figured eh, why not?
    POSTacoMike and GQ7227 like this.
  9. Jan 4, 2020 at 10:13 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Ha Ha ! I have a neighbor with Heavy Equipment that keeps dropping trees on the Electric lines so quite often I am in the Dark and to lazy to start the generator .
    Blue92[OP] likes this.
  10. Jan 4, 2020 at 10:24 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    good write up
    I, however, mostly keep the dome turned off anyway but this is neat
  11. Jan 4, 2020 at 8:04 PM
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Very tempting.
  12. Jan 7, 2020 at 4:48 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    today i decided to activate the door actuated map light in my truck to see if it still operates properly (i rarely use it so was not sure)
    it works!
    but it is not on a time delay or anything like that, it goes off immediately when i close the door.
    is there supposed to be a time delay setting?
  13. Jan 7, 2020 at 6:47 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    only if the door is open or the truck is not running, then it's like 2 minutes. otherwise it assumes you are driving therefor turns off when you close the door
  14. Jan 7, 2020 at 9:29 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i will need to try with the engine running tomorrow
    not sure if i can hold out for the two minutes to see what happens!
  15. Jan 8, 2020 at 6:29 AM
    omarq
    omarq Well-Known Member
    o
    1999 Tacoma Extracab
    17" wheel
    on my 99 extracab SR5... i had only the dome light behind me come on when the door was opened. No light on the mirror. I did this mod a few weeks ago... and its like night and day <get it?> The map lights and on this style mirror are amazing. One thing to note is that if you have the dome light... you can just connect this new light module to the wires on the existing dome light as the wiring is the same. They will run in parallel.
    GQ7227 likes this.
  16. Jan 8, 2020 at 6:45 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    can you have both the center dome light and the lights on the mirror both go on at the same time? ... not sure if i have ever tried doing that
  17. Jan 8, 2020 at 6:58 AM
    omarq
    o
    17" wheel
    Yep.. That's how mine work if both are set to "door"
  18. Feb 4, 2020 at 9:42 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
  19. Feb 5, 2020 at 3:33 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    GQ7227 likes this.
  20. Feb 5, 2020 at 5:35 AM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    Hey man, if you find any in the grey color like that I'd be interested. I'd also need the fixture part, not just the cover. I was at the junkyard a few weeks back and saw one but it I didn't know there was a mod for this so I didn't get it.
    Blue92[QUOTED][OP] likes this.
