How To: Door Actuated Map Light Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Blue92, Jan 4, 2020.
  1. Feb 5, 2020 at 5:48 AM
    Blue92
    Blue92 [OP] Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Ok Ill keep you in mind. Not often a 2nd gen hits the junkyard around here though.
    04Pre_Runner and GQ7227 like this.
  2. Feb 5, 2020 at 7:26 AM
    TacomaEli
    TacomaEli Well-Known Member
    Eli
    Roanoke, Virginia
    2000 Tacoma XtraCab SR5 TRD 3.4L Auto
    @Blue92 , My truck doesn't already have the map lights. Will the wiring and connector still be in the headliner or will I have to splice into the A-pillar wiring, buy some wire , run it through the headliner, then splice into the connector that goes into the connector?
  3. Feb 5, 2020 at 7:29 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    You'll likely have to do it just like I did. Splicing the wire into the A-Pillar. But youre a pre 01, so you may wanna do some more research on it to get a definite answer as I only know for sure on the later body style trucks.
    I see youre in Roanoke, isnt there a Pick-N-Save up there and in Lynchburg? They post their inventory online so you may wanna check to see what they got.
  4. Feb 5, 2020 at 7:33 AM
    TacomaEli
    Eli
    Roanoke, Virginia
    Yeah, I was at pick n save a couple weeks ago and I saw exactly what I needed for this but I didn't know if it was a possibility to put it in my truck. I should've just bought it but I didn't. I actually talked to a buddy today and he bought a 2nd gen 4runner parts truck yesterday so he's going to check when he gets home.
    Blue92[QUOTED][OP] likes this.
  5. Feb 5, 2020 at 8:00 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I keep meaning to go there next time im in Roanoke. They tend to have more Toyota trucks in stock then the yards down here.
  6. Feb 5, 2020 at 8:47 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    https://www.ebay.com/itm/90-95-TOYO...OR-INTERIOR-DOME-MAP-LIGHTS-BLUE/254460944047
    I just bought the other one they had in a lighter gray. Not a terrible price for the convenience.
  7. Feb 5, 2020 at 9:14 PM
    omarq
    omarq Well-Known Member
    o
    1999 Tacoma Extracab
    17" wheel
    My 99 sr5 extracab didn't have a mirror light from.factory. I wired mine in parallel to the dome light and it works great. You have to run two wires to the dome light harness. The harness is the same. The screws will provide the ground for the light when the doors are closed.
  8. Feb 6, 2020 at 8:31 AM
    Floridaze
    Floridaze Well-Known Member
    Pensacola
    97 ext cab 4wd
    Abs delete, lspv delete, led headlights, 5 speed swap, ome 882 nitrochargers and dakars
    Nice write up, I’ll be doing this soon
    Blue92[OP] likes this.
  9. Feb 8, 2020 at 7:39 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    This is the light I’m getting from a friend. It came out of a 2nd gen 4runner. The picture shows how it was connected in his truck. Which wires will I splice to what in my 2000 tacoma8EA71CB0-EB4C-4EA3-BCE8-3A06B8DEB318.jpgC978F1EB-9436-4B4A-BFA0-39AE74ECB4B9.jpg
  10. Feb 8, 2020 at 7:55 PM
    omarq
    o
    17" wheel
    Easiest way is to wire color to matching color to the dome light. You don't even need to pull off a pillar trim
  11. Feb 8, 2020 at 7:58 PM
    TacomaEli
    Eli
    Roanoke, Virginia
    How do you do that? Wouldn’t it be harder to splice a wire up in the headliner? I might be more interested in splicing into the wires in the A pillar like @Blue92 did. I was just interested in what wires need to be spliced together from the light to the wires in the a pillar
  12. Feb 8, 2020 at 8:17 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Kinda hard to do that when the wire for this light is non existent in the map light location in some Tacos haha. Also our dome light wires are black.
    Red/silver wire goes to black/white in A pillar. Red/green goes to solid black.
    Floridaze likes this.
  13. Feb 8, 2020 at 8:33 PM
    omarq
    o
    17" wheel
    Unscrew a visor and fish the wire with coat hanger. Run through a loom or wrap wires with tape. To prevent chafing. Or I guess you could remove the dome light see the colors and match to the same colors at the pillar.
  14. Feb 8, 2020 at 8:39 PM
    omarq
    o
    17" wheel
    On my 1999 sr5 extended cab it's the exact same harness. You could in effect plug in the mirror to the dome light harness.
    I was guessing that the 2000 Taco and 99 were the same harness
  15. Feb 10, 2020 at 1:07 PM
    #35
    TacomaEli
    Eli
    Roanoke, Virginia
    Awesome ! Just stripped out the screw heads for the grab handle
    cruiserguy and 04Pre_Runner like this.
  16. Apr 15, 2020 at 7:52 AM
    #36
    04Pre_Runner
    Andrew
    Well. About to do the lighted key cylinder, door actuated map light, wire a dash cam to a usb on my headunit, and install the 4WD indicator light for my transfer case o_O
    From what I understand I'll have to add a wire for the map light and splice into the black/white a pillar wire. Then splice my lighted key cylinder into that same a pillar wire? Already have a map light rear view mirror to begin with.
  17. Apr 15, 2020 at 8:50 AM
    #37
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup just read the write up, it shows what wire to tap both into. The other wire on the keylight will go to chasis somewhere.
    04Pre_Runner[QUOTED] likes this.
  18. Apr 15, 2020 at 11:34 AM
    #38
    04Pre_Runner
    Andrew
    Yeah just confirming what I gathered from the write up. A lot of people seem to be hard wiring their key lights to always be on. And splice into the dome light for the map light.
    I'd rather splice into the same point on the a pillar to limit how many splices I do.
  19. Apr 15, 2020 at 11:46 AM
    #39
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Good plan. Toyota doesnt leave any extra wire so make as few splices as possible.
  20. Apr 17, 2020 at 8:29 AM
    #40
    Blue92
    Daniel
    North Carolina
    2018 Sport
