"How to" drain 4.5 quarts of tranny fluid.
Discussion in '1st Gen. Tacomas (1995-2004)' started by BAZZMAZZA, Nov 15, 2011.
  1. Nov 15, 2011 at 6:53 PM
    BAZZMAZZA
    BAZZMAZZA [OP] Well-Known Member
    Virginia Beach, VA
    SR5 and then some...
    OME-882 Coils + Nitro- Sport shocks, ARB Compressor, Spare fuse box, ALL-PRO Bedrack
    2004 Tacoma 3.4 Automatic
    Yesterday I jacked up the front of my truck as high as I could with a 3 ton jack and a small piece of 4x4 post and was able to drain 4.5 qts of tranny fluid out of my tranny. Initially it sat level and drained about 3.5 qts the book says 2.1 qts for drain and refill but I dont think it is correct. So if you want to get more of the old fluid out just jack up the front just be safe and use jack stands, emergency brake and a chock for the rear wheels.
    Measurments are of old fluid are accurate.
    I used OEM Toyota TIV fluid and 5 qts went back in order get fluid to cold level on stick during idle (after cycling through all gears).
  2. Nov 15, 2011 at 7:34 PM
    AlphaEcho2k5
    AlphaEcho2k5 Well-Known Member
    Adam
    Hurlburt Field, FL
    '02 4Runner
  3. Nov 16, 2011 at 9:36 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    Or drive it up on ramps.
  4. Nov 17, 2011 at 11:56 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Thank you for the post.
