how to drain and refill manual transmission fluide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sim55, Feb 13, 2012.
  1. Feb 13, 2012 at 4:49 PM
    sim55
    sim55 [OP] New Member
    tacoma
    Hi, I would like to know step by step how to drain and refill manual transmission fluide. Also, if somebody has few pics of it, that would be appreciated.
  2. Feb 13, 2012 at 4:56 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    Remove drain plug after removing fill plug. Let oil drain, then fill. Fo a search there is a thread.
  3. Feb 13, 2012 at 7:49 PM
    badger
    badger Well-Known Member
    07 SR5
    I don't think there is a real how-to on here. It's pretty simple.
    You need a 34mm socket, 2 qts of Redline MT-90, and a hand pump for the oil. Drive the truck long enough to warm the oil.
    1. remove the fill plug on the passenger side.
    2. remove the drain plug on the bottom
    3. drain the oil
    4. clean both plugs. The drain plug has a magnet that must be cleaned
    5. replace the drain plug
    6. use the pump to add the oil. Go slow near the end so the oil levels.
    7. when oil starts to dribble out the hole, put the fill plug in and clean the cases of all oil.
    tips:
    1. do not overtighten the plugs! Hold the socket wrench near the head when you snug them down
    2. Use the socket to remove the plugs, not an adjustable wrench or other tool
    3. after a short drive check the plugs for leaks
    Key-Rei likes this.
  4. Feb 13, 2012 at 10:12 PM
    TnShooter
    TnShooter Well-Known Member
    07' TRD Off-Road, Auto
    STOCK
  5. Feb 13, 2012 at 11:51 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    OP wanted manual trans instructions :facepalm:
    36tacundra and Key-Rei like this.
  6. Feb 14, 2012 at 1:18 AM
    Manwithoutaplan
    ID
  7. Feb 14, 2012 at 8:53 PM
    TnShooter
    STOCK
    Shows you how good I read....huh?
    Sorry OP..... And be happy it's not an Auto.
    Key-Rei likes this.
  8. Nov 13, 2017 at 1:15 AM
    lo2hi
    lo2hi Well-Known Member
    Oregon
