How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Oct 21, 2014 at 8:06 AM
    #441
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
  2. Oct 25, 2014 at 7:09 PM
    #442
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
  3. Oct 25, 2014 at 7:29 PM
    #443
    nj636
    Kev
    Jersey
    I like that they drained an extra 2.5-3 quarts pumping it out with this method:
  4. Oct 26, 2014 at 5:49 AM
    #444
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    They are doing something different. The thread you commented in is about a drain and fill. The guy you quoted is doing a flush... He got more than 2.5 quarts because he repeats the steps...
  5. Oct 26, 2014 at 6:11 AM
    #445
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    any1 in GA can help me do this?
  6. Oct 26, 2014 at 8:01 AM
    #446
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    This process seems complicated for a first timer but it's actually just as easy as an oil change...minus the part of pumping the new fluid in.
    Quick tip: buy a paint bucket with quart lines in the inside to measure how much oil came out. Have done this 3 times now, and it's always 2.9-3qts. Make sure you do it on a flat surface.
    The first 2 times I did this, I went through the temp check mode steps. Now I just drain out the 3qrts and pump 3 back in.
    Pabloeeto likes this.
  7. Nov 3, 2014 at 4:46 AM
    #447
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Did the drain and fill yesterday. First thing, I had made sure all bolts (drain,fill and overflow) could be loosened first. Also made sure I could get the truck into AT temp check mode. I had done the prep work the day before. Tested the temp check mode out right after returning from a drive. Light came on blinking indicating ATF was too hot to test level as expected.
    No problems except I was going on half an hour waiting for the AT temp light to light up indicating the correct temp to check the fluid level. Outside air temp was 43F. Felt the pan with my hand and did not really feel very warm. Started wondering how the transmission fluid would heat up of the truck was not in drive. If the gears aren't turning, how is the fluid supposed to heat up. Is there a pump that circulates it when the truck is idling? Anyway, so I took it for a quick 1/2 mile run up the road and back. Then re-set the AT temp check mode because I wasn't sure if moving the gear selector after already in temp check mode would mess it up. Light came on right away.
    I had drained out 2qt 4oz. I put 3 qts back in. 11 oz came out of the overflow. So I figure I was just over a 1/2 quart low before doing the drain and fill.
    Truck is nearly 6 years old with almost 100k on the clock. First time doing the ATF drain and fill. No noticable difference in the way it drives. Shifts feel the same. I do feel better that it has the right amount of fluid now. Guess it can't be too important though since Toyota seems to be shorting everyone from the factory.
  8. Dec 7, 2014 at 6:34 PM
    #448
    kennymillertime
    kennymillertime New Member
    omak
    2007 tacoma double cab trd
    I can not get my truck into check temp mode? what do i do sat and let my truck idle for one hour and still can't get it on its about 35 degrees out
  9. Dec 8, 2014 at 5:41 AM
    #449
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    what folks have been finding( me included) is that on some Trucks you have to shift through the gears pretty quick, instead of pausing a second or two like the instructions says just shift through the sequence a little faster. In Your case Since it's too cold outside the tranny might get cold real quick and change modes in less time though, my guess.
  10. Dec 9, 2014 at 7:33 AM
    #450
    udelslayer
    udelslayer Well-Known Member
    North Carolina
    09 Taco 2wd 5AT
    Why don't you just drive it? Sitting idle under no load isn't going to heat anything much. They're not going to overheat and catch on fire in park like a 1983 S10 2.8L.
    I don't understand why they don't build these things to be changed out easily. Yota is really pushing hard to make you stealership it. Although I think my trans sucks, I am glad it has a dipstick. Its the only reason you have to go through this secret handshake BS.
  11. Dec 18, 2014 at 7:22 PM
    #451
    4x4Active
    4x4Active Well-Known Member
    Saltwater Texas
    '13 Taco DC OR 3" lift stock rims on 33s
    Because not everyone live in the same environment. A half a mile drive for me can reach 115* but that dont mean your will or it might be even over the temp that you can check the fluid level. Its from [FONT=&quot]115°F to130°F[/FONT]. They would then have to wait for it to cool down. Best method and wont burn the wallet is get one of those bluetooth OBD2. Got mine on Amazon for $15 buck. Drove around and back to the garage when it hit 115*.
    Anyways.... I did mine today. It was easy. I think mine was factory under filled. Didnt measure how much it came out but by the weight. Its not much. About -/+12 oz came out after putting in 5 quart :eek: But the process was damn easy. Just the pumping is a bit of exercise. temp was easy with a drive and monitor using torque app.
    Here are a few pictures for those who do not know where the fill port/plug is located on a V6 4x4 OR.
    After crawling under the truck ( from the passenger side). Looking up from the pan you will see the plug. Its almost directly above.
    Here is a closer up.
    The plug will say WS on it.
    Here is my pump. I brought on Amazon for 11 buck. Its felt pretty good quality. Have not failed me. I was on my stomach pumping with the bottle on the ground. Not bad at all.
    The parts tech was trying to tell me that my truck has a dipstick. Man I wish. But this is a easy DIY. A bit longer than a oil change and dealership trying to get a few hundred for this. Damn
  12. Dec 18, 2014 at 7:25 PM
    #452
    4x4Active
    Saltwater Texas
    If you cant get it into check mode. Try doing it fast. I was able to get mine into check mode by doing it fast after a second or 2 pause from P to N. If all failed. Get yourself a bluetooth OBD2 and torque app. Which would total to about 20 buck.
    BTW..... You can let your truck run/idle for hours or days and nothing will happen if you cannot get into check mode (temp light stay on for about 2 second after the shift)
  13. Dec 20, 2014 at 4:17 PM
    #453
    volks71folk
    volks71folk Well-Known Member
    This is all drain and fill. Does anybody have a write up for just checking the level of the fluid? Tusks
  14. Dec 20, 2014 at 4:41 PM
    #454
    metrick1215
    metrick1215 Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    If i send in my Ultragauge and get the MX update, can i do this without the entire shifting to get into mode processes?
  15. Dec 20, 2014 at 8:58 PM
    #455
    4x4Active
    Saltwater Texas
    Basically the same thing man..... You skip the first part and go straight into temp mode and make sure its the correct temperature. Open up the overflow plug and check the level.
    If it show the temperature. You do not need to go into the temp mode (shifting)
  16. Jan 18, 2015 at 9:59 AM
    #456
    notbrigum
    notbrigum Well-Known Member
    Chandler AZ
    08 double cab 4x4
    TRD intake, Magnaflow exhaust, billet grille, tube steps
    Ok, no problems. Crush washers are cheap, get them the next time you're at the dealer, don't mess with re-using them, especially since you're normally only into these plugs but once every 3-5 years, not like the oil where if you have a small drip you can redo it in 4 months. Re. getting it into check Temp mode, first time didn't work, watch the video, it's quick, In, Out, In, Out, etc. Works. Also, here in AZ I had a hard time getting the fluid to cool off from AT Temp light ON > Off, so I could confirm it would rise to the correct temp. Every time I would put in into Check Temp mode, wouldn't go Off, just stayed On (I know, that means it's correct, but if you're wanting to REallly know for sure, you want to see it start Low/Off and then rise to On) Just saying. Easy but messy, especially with 13 y/o son learning/helping. Keep many garage towels around for cleanup. Thanks all.
  17. Jan 20, 2015 at 12:06 PM
    #457
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    Toyota service tech is telling me its not necessary because its a sealed system. However if its good preventative to do it I am ok with that. I would likely have the dealer do it because i don't have the time right now.
    I have a 2006 TRD Sport V6 4x4. I have 130K, all highway and city, no offroading, some 4WD in snow or heavy rain only. Am I ok to stay put or should I have the tranny flushed and refilled?
  18. Jan 20, 2015 at 12:16 PM
    #458
    WeberSarge
    WeberSarge Well-Known Member
    Kevin
    Ohio, Illinois
    '08 SR5 TRD 4X4 Quad Cab , '77 FJ40
    Stock for now...
    In my opinion , I'd flush a trans about every 50k - it's just peace of mind insurance . And that bs that this oil is "good for life of vehicle" , yeah - right . Depends on their definition of "life of vehicle" ....bullshit . You really expect not to do damage even with only 130k on the odometer ? Not in my opinion of working on mechanical stuff for over 40yrs .
    Same goes with the antifreeze - someone would have to flat-out prove it's not causing corrosion inside any part of the engine or radiator/heater cores , valves ect . I say even with the uber-expensive antifreeze about 5yrs is tops ...
    Sarge
    svocobra likes this.
  19. Jan 23, 2015 at 8:03 AM
    #459
    Tinkerab
    Tinkerab New Member
    07 DBL Cab 4x4 offroad
    thank you to all who have contributed to this thread and especially the OP.
    I did the drain and fill last night and had a bit of an issue. My driveway has a bit of a decline so even with my leveling kit the front end was sagging probably 3 inches from the rear.
    First i removed the fill plug then the over flow. roughly 1.5 qts spilled out of the over flow at this point. I then opened the drain plug and another 1.5 qts or so came out.
    I then followed the fill process and while the truck was warming up I jacked up the front end to level it the best I could. It still sat slightly tilted forward. Probably by 1 inch or so.
    As I did the overflow a ton started pouring out so I quickly plugged it and tightened it up.
    In your opinion is my pan/overfill plug damaged or will everything be okay if I simply do it again on perfectly level ground? Also will putting a level on the bottom of the frame be a sufficient measure for being level?
    Once again thanks to all the contributors.
  20. Feb 12, 2015 at 12:22 PM
    #460
    123GO
    123GO Member
    A strainfully hard piss steam if your past 60yrs....lol :eek:
