How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Mar 6, 2016 at 7:45 PM
    #601
    mdmt800
    mdmt800 Active Member
    Houston
    2007 Tacoma
    Awesome thread. A question about the AT fluid. I thought I read about 2 different brands used besides the toyota atf ws. Can you use other brands or is that pushing my luck? I hoping to try my luck on this tomorrow. Another question when I get it to go into the temperature check mode, a solid light for 2 seconds, then goes out, and I put it into P, the light stays out, then lights up steady when it reaches the correct temperature. Is that right? Thanks.
  2. Mar 6, 2016 at 9:00 PM
    #602
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Let us know if that Harbor Freight scan tool will read transmission fluid temp(TFT). I'll be surprised if it does. Maybe it will allow users to input make-specific PIDs.
  3. Mar 6, 2016 at 9:04 PM
    #603
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    What's the pill bottle for?
    mdmt800 likes this.
  4. Mar 7, 2016 at 12:36 AM
    #604
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Valvoline MaxLife appears to be the most popular aftermarket WS alternative. I have it in my truck and wife's 07 Lexus ES350. Other options include Amsoil, Purple Royal, and Super Tech (Wallyworld). Better to do a full flush than to mix/match. Put away the jump wire - the IR method has been proven to be just as accurate as the TechStream or jump wire methods.
    mdmt800[QUOTED] likes this.
  5. Mar 7, 2016 at 11:49 AM
    #605
    mdmt800
    Houston
    2007 Tacoma
    Finished up the drain and fill. 1 and a 1/4 quarts drained from the overfill plug, 1 and a 1/2 quarts from the drain plug. Total out was 2 and 3/4 quarts. I put in 3 and a 1/2 quarts. Warmed up at idle till the temp from the IF laser showed 118-120 and drained from the overfill 1/2 quart. So it took 3 quarts. So it would have been 1/4 quart low. Is has been shifting pretty rough lately.
    I took it out for a spin and smooth as silk. I could tell a big difference in the shifting. I know it wasn't a flush but would being low 1/4 qt make the difference or would it be partially new fluid? The drained fluid looked pretty dark. The transmission hasn't been touched prior and has 138 k miles.
    Thanks to all, because this forum has saved me a bunch of money and has taught me how to work on my own truck. Yesterday I changed my oil/filter and rear differential gear oil, and today the drain and fill on the transmission. Pretty cool.
    Toyota qt was 9.45 x 4 =37.80
    Harbor Freight, Multi use pump was 6.99 worked like a charm. Also I bought the IR Laser to read the temp on the pan. that was 35.00.
    Dollar Store for the jug to measure the drained fluid.
    Pabloeeto likes this.
  6. Mar 9, 2016 at 5:08 AM
    #606
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    I 2nd that, I have Valvoline Maxlife in my tranny for 2 years now with no issues. 1/2 the price of the Toyota tranny fluid.
    mdmt800 likes this.
  7. Mar 9, 2016 at 11:47 AM
    #607
    hardthunder
    hardthunder Member
    J
    Texas
    08 4dr PreRunner
    The pill bottle was holding the crush washers for the drain and overflow plugs. dealership didn't carry the oring for the filler plug. And all my tranq's are gone : this OBD2 trans. fluid temp drove me crazy, gave up.
  8. Mar 9, 2016 at 11:56 AM
    #608
    hardthunder
    hardthunder Member
    J
    Texas
    08 4dr PreRunner
    No, your right, the H F OBD2 didn't work. got my money back on that one. Tried the BAFX brand of bluetooth OBD2 with Torque, no luck there either.
  9. Mar 10, 2016 at 5:32 PM
    #609
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Ok so what is a slow trickle? Temp was at 118F pulled check plug...the extra 12 ounces I pumped in gushed out of level check hole. Then it went to a steady thin stream,then it got really slow and started trickling down the pan. So do you put check plug back in at the steady thin stream,or the barley dripping? Thabks
  10. Mar 10, 2016 at 5:39 PM
    #610
    mdmt800
    Houston
    2007 Tacoma
    Mine slowed down from the big stream to a much smaller stream. You can tell then it's almost done. I plugged it up right then. So I would say the the small steady stream or a trickle your good.
  11. Mar 13, 2016 at 6:41 PM
    #611
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Drained mine Saturday. Removed 3 qts 2 oz.. Put back just short of 3-1\2 qts. Pulled check plug when IR temp on the outlet line hit 120 and about 1/2 oz came out. So I would say it was a little low from factory.
  12. Mar 15, 2016 at 4:50 AM
    #612
    esse10
    Texas
    I believe a trickle is when it go's from a thin stream to just quick drops, that's a trickle........put the cap on quick.
    On another note; My IR thermometer kept jumping from 157F to 161F pan temperature while my Torque program was reading a steady 160F after a small 10 mile cruise on the HWY and then Idling the engine. IMO I believe the torque data is more accurate and
    that's what I'm gonna use on my annual fluid level check.
  13. Mar 15, 2016 at 5:56 AM
    #613
    Lester Lugnut
    I agree with the trickle.....
    I have one of those cheap, entry-level IR thermometers from Harbor Freight. $59 unit on sale for $39. I too see variation in temp. readings. Seems to vacillate as yours does. Would be interesting to hear from those who've invested in a more upscale IR thermometer. Do they also vacillate?
    I'm content to go by what I get using a 6" length of jumper wire in ports 4/13 of DLC3.
  14. Mar 15, 2016 at 11:58 AM
    #614
    Chuy
    Lakeside, CA
    Silver Taco
    I avoid all things electronic from HB - well, I do have LED calipers, but that's it. I forked up $65 for Raytek MT6 from Amazon. The Etekcity Lasergrip 1080 has good reviews and runs $17. However, I think it's normal for temp to skip a bit as your hand shakes. The response time for the IR is most likely quicker than the temp sensor in the tranny.
  15. Mar 16, 2016 at 8:49 AM
    #615
    esse10
    Texas
    just a thought,
    Maybe if folks would fix the IR gun to a small tripod or something to keep it steady it might give ya a better reading. Im just still gonna go with the torque program and get my reading like that.
  16. Mar 16, 2016 at 10:38 AM
    #616
    stump jumper
    Bill
    Texas
    why go to the trouble. The range is 115 to 130. SO what if the reading fluctuates a few degrees. I took mine on the outlet side of the tubing going to the radiator.
    Chuy and mdmt800 like this.
  17. Mar 24, 2016 at 10:53 AM
    #617
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    Checked the AT fluid on my 2015 TRD OR w/tow package last weekend. Couldn't get the dash lights to work properly using the jumper so I purchase an IR thermometer at HF. When the pan reached 120 I pulled the check plug and about 3 or 4 drops came out. I figured those might be in the check plug tube due to fluid sloshing around in the transmission. So I waited until the exhaust cooled a bit and pumped in what ended up being 9 oz of Toyota WS fluid. I then ran the temp back up on the trans, popped the check plug and some fluid drained out until it was trickling, at which point I screwed in the plug. After measuring what came out I found that I'd added 4 to 5 oz. Not what I'd really call "under filled", but on a truck with 6,000 miles it I believe it should have been completely topped off.
    I bought this truck mid Feb with 4K miles on it and always thought the shifting felt soft. After driving it for five days I've found shifting may be a tad better at light and heavy throttle. Medium throttle appears to remain about the same. Of course these improvements could be in my head. I mean, really, should *5 oz.* of AT fluid actually make a difference?? In any case, it didn't seem to hurt and I know my trans is full of fluid.
  18. Mar 24, 2016 at 10:57 AM
    #618
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Nice, can post a link to what you bought? Is that sufficient to avoid the jumping of pins
    and trying to get it into temp check mode??
  19. Mar 24, 2016 at 11:56 AM
    #619
    syswalla
    syswalla Knob
    5557 ft.
    2015 DCSB TRD OR
    The AT fluid came from the Toyota dealer. I got one of these and a from HF. Hint: find a 20% off coupon to use on the thermometer. They're usually in a mailer (might find one at the store if you don't have one) as well as the motorcycle mag I subscribe to. Tools I already had.
    I think the jumper is a more sure way to know the trans is at the correct temp, but for the life of me, I could not get it to work. And I don't consider myself to be a newb when it comes to working on vehicles. All told, I spent about $45-$50, but now don't wonder if my trans is unhappy or if it's just me. Apparently it's mostly me.
  20. Mar 24, 2016 at 12:00 PM
    #620
    BlkTaco47
    BlkTaco47 Unhinged
    Thanks dude. I don't know if I'm checking mine, I was just curious. I have NO issues tranny
    wise but just wanted to be prepared, I just don't trust the "we checked it with TechStream so
    you're fine" answer. I thought how does the TS hookup check Fluid levels??? :notsure:
