How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Apr 24, 2016 at 6:49 PM
    #681
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Dont do a stupid check mode, just get scnaguage II and read temps that way, it will save you time and aggravation.
  2. Apr 24, 2016 at 7:17 PM
    #682
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Did you at least get the OBD jumper set correctly and saw the various gauge lights flashing?
    A few tips to get it into check mode:
    1. Make sure the engine is running. I saw a video posted a few pages back where a guy couldn't get it to activate, and he didn't have the engine running.
    2. Once the engine is running, all the lights are flashing, and you're in PARK, put your foot on the brake and shift into Neutral. Keep your foot on the brake, and then move the shifter from N to D, D to N, N to D as quickly as you can count out loud: "one, two, three, four, five, six". Around the "six" you should see AT TEMP light up on the cluster. Then just shift into Park and let the truck idle until it warms up.
    3. Just as a reminder, do this procedure on a completely cold truck.
    I think most who can't get into AT TEMP mode are doing it too slow.
  3. Apr 25, 2016 at 3:27 AM
    #683
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Yep, did all that 3 different times.
  4. Apr 28, 2016 at 1:19 PM
    #684
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Ok, so I guess you check it like a diff.....
    But I don't know anyone that would go thru all that shit, I wouldn't & not because I lack the skills, I lack the interest really & was under the belief that it was a "flush" & fill, not drain & fill like my A340F
  5. Apr 28, 2016 at 1:23 PM
    #685
    2015WhiteOR
    Gainesville TX
    It's really no different. The only thing is they got rid of the dip stick and put a procedure in the ECM so you can get the correct level.
    The FJ guys with the same transmissions seem to prefer doing cooler line flush and then using the OBD jumper method to check the level. I'm in the school of thought that draining and filling 30% of the fluid each year will keep the additives strong.
    Lester Lugnut likes this.
  6. Apr 28, 2016 at 1:30 PM
    #686
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Probably so....
  7. Apr 29, 2016 at 4:55 AM
    #687
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    i have no problem with Toyotas procedure to ensure a correct fill. I do have a problem as someone who takes great care of their equipment and cant check fluid level easily, say once a week. I dont see why they cant add a cheap dipstick on a $30k+ vehicle as peace of mind for people who care. If not that, even cheap generators have a low oil warning light.
  8. Apr 29, 2016 at 5:05 AM
    #688
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    I wish there were options. Substitute one feature for another. Get rid of the problem-plagued Entunes and give me a warning light for low transmission fluid level/temp. The stick would be nice, but I doubt they're going to resurrect it.
  9. Apr 29, 2016 at 5:28 AM
    #689
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    It's not done for the people that do care, its done for the people that don't care or shouldn't be messing with it . Which are in far greater numbers
  10. Apr 30, 2016 at 6:34 PM
    #690
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
  11. May 1, 2016 at 7:39 AM
    #691
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  12. May 1, 2016 at 7:55 AM
    #692
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I did it pretty slow and it worked. Went into AT TEMP on the 3rd shift. Took about half an hour to get to temp.
  13. May 3, 2016 at 9:22 AM
    #693
    tweety
    tweety Member
    2006 TRD OffRoad
    Just wanted to say THANKS to Fortech for his great instructions. I followed them exactly and had no problem.
  14. May 15, 2016 at 7:57 AM
    #694
    jeffwv
    jeffwv Member
    2015 black Tacoma
    Went to check atf fluid using these procedure; after 3-4 shifts from N to D, the ATF light came on for 2 seconds went off, then i shifted to park per instructions but ATF light did not come on again for the 2 seconds; then waited 15 minutes idling and no light ever came on. Once the ATF light came on during the shifts from N to P, but not when put back in P, am I in the ATF check procedure or not? Or should I have kept it idling longer than 15 minutes?
  15. May 15, 2016 at 8:11 AM
    #695
    Lester Lugnut
    Some of the notes I took when putting 2015 Tacoma PreRunner V6 into temp check mode:
    - Jumper OBD-II ports 4 & 13 with a small paper clip
    - Turn ignition switch to first position. You should see many cluster lights blinking. If not, you did not properly jumper 4 & 13
    - Start vehicle - move thru all of the gears a few times. Move to D; then back and forth between N & D for 6 secs. For the Tacoma, you should see the "A/T Temp Oil" light illuminate for 2 secs. If this occurs, shift truck into P and remove the jumper wire. Vehicle entered Temp Check Mode at 1:33pm
    - 1:46pm - "A/T Oil Temp" light on solid. Truck is now at the lower part of the acceptable temp. range. IR thermometer now reads 95 degrees F at front of transmission pan and 93 degrees F at the back of the transmission pan. I took IR reading for curiosity sake. Did NOT use it to determine when the fluid temp was at desired temp.
    - 2:00pm - "A/T Temp Oil" light flashing. This indicates the transmission fluid temp. is excessive. IR thermometer now reads 110 degrees F at the front of the transmission pan and 107 degrees F at the rear of the transmission pan.
  16. May 15, 2016 at 8:26 AM
    #696
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    I think I idled about 19 or 20 minutes.....
  17. May 15, 2016 at 8:38 AM
    #697
    jeffwv
    jeffwv Member
    2015 black Tacoma
    As a follow up: even though the ATF light did not come on when putting back in park, after another 5 minutes (the truck was already warm), the ATF light came on steady; I checked the fluid; one single drop on the overflow plug came out and that was it; turned truck off, added 16 ounces of Toyota ATF WS; went through procedure again, took only a few minutes for ATF light to again come on solid, immediately checked overflow (with engine running of course) and this time a slow but steady dripping occurred. This is a 2015 with only 1,800 miles and IT WAS LOW BY 16 OUNCES. FUCK Toyota for this "sealed" transmission making checking it cumbersome and FUCK Toyota for delivering this LOW on ATF fluid.
  18. May 20, 2016 at 2:11 PM
    #698
    Mehullica
    Mehullica Well-Known Member
    Central California
    05 Prerunner d-cab
    The fluid adjustment is correct EXCEPT for 1 step, & the probably the most important. After correctly entering fluid temp detection mode, you need to remove the jumper wire from DLC3. If you don't the ECU will stay in base timing & not maintain the correct idle speed & ATF cooler flow to adjust the ATF level properly. The idle will fluctuate & cause the fluid level in the pan to go up & down incorrectly while you have the check plug out, you'll let out of much. You also must have all accessories off to reduce alternator load & to maintain exactly 800 rpm.
  19. May 20, 2016 at 2:34 PM
    #699
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    What about the tranny cooler thermal valve on the model with factory tow package? Do we have to manually open it? We have to do that step on Tundra.
  20. May 20, 2016 at 3:13 PM
    #700
    Lester Lugnut
    That might be done during a FLUSH. This thread covers a drain and fill. In my opinion, the most important part of this thread is understanding how to set the correct fluid level once fluid has been changed, regardless of whether you did a complete flush or just a pan drain.
