How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. May 20, 2016 at 4:40 PM
    #701
    Mehullica
    Mehullica Well-Known Member
    Central California
    05 Prerunner d-cab
    Don't have to open the thermal valve on Tacomas. However if the idle is fluctuating because the jumper wire is still in, the fluid will warm up too fast & you'll end up draining out too much. End result is its under filled. I work at a dealer & have done hundreds of the fluid checks/adjustments. I've seen only 4 in the last 10 years that's actually properly filled. They're all usually low by 1/2 quart or more. It's a good idea to reset the learned memory after the fluid change to relearn the shifting time. Over time the ecu learns to shift slower because the fluid doesn't have the same viscosity. When you put in new fluid, it still shifts slow, & may slip & burn the friction material in the clutch packs.
  2. May 21, 2016 at 12:02 AM
    #702
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Hold on. No need to get angry. Does your truck have the tow package?
    One thing that explains underfilled transmissions is that the A750 transmission, as delivered by Aisin Warner to Toyota, comes pre-filled with a certain amount of fluid. The assembly line will add in enough fluid once the entire driveline is hooked up since you have to account for volume in the AT cooler lines.
    Since the tow package adds an aux cooler, this increases the system capacity by a small amount. It would be NICE if Toyota got this part accounted for, but as we've seen even on the 2016s they are still struggling with this part.
    Bear in mind that the entire system capacity is roughly 12 quarts for a 5Spd + Tow Package model. 192 quarts in total. Low by 16 ounces is 8%. Not perfect, but not a significant amount.
  3. May 21, 2016 at 12:03 AM
    #703
    2015WhiteOR
    Gainesville TX
    Why don't you use Techstream if you work at a dealership?
  4. May 21, 2016 at 5:44 AM
    #704
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
    How do you plan on checking it if you're not doing the procedure?
  5. May 21, 2016 at 8:53 AM
    #705
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Mehullica:
    Thanks for your recent input in this transmission drain/fill thread. A dealer tech on another forum once posted the following in a Camry section. Said this would put transmission in learn mode. Would this also work on the A750E/A750F transmission?
    Disconnect the battery ground and wait 10 seconds. Touch the ground to the positive and hold there for 10 seconds. Wait 5 minutes. Repeat the ground to positive for 10 seconds and then reconnect. This puts it into learn mode. Take it on an aggressive test drive. I suggest you do this AFTER replacement of the filter.
  6. May 21, 2016 at 11:00 AM
    #706
    Mehullica
    Central California
    05 Prerunner d-cab
    I do use techstream at the dealer. This procedure with the jumper wire is for non-Techstream users
  7. May 21, 2016 at 11:08 AM
    #707
    2015WhiteOR
    Gainesville TX
    OK.
    Do you mind sharing where you find that the jumper wire needs to be removed once in AT TEMP check mode? The factory service manual doesn't mention it, and the various times I've gone into AT TEMP check mode, the temperature increase is sooooooo gradual and the RPMs maintain steady. I can't see how there would be enough going on with the engine that it would cause an incorrect AT fluid level.
  8. May 21, 2016 at 11:34 AM
    #708
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Doesn't the Techstream just provide the trans temp and you still have to pull the overfill plug?
  9. May 21, 2016 at 5:15 PM
    #709
    Lester Lugnut
    bluewaters182 likes this.
  10. May 21, 2016 at 7:03 PM
    #710
    2015WhiteOR
    Gainesville TX
  11. May 21, 2016 at 8:40 PM
    #711
    2015WhiteOR
    Gainesville TX
    Well I got the itch and re-checked the trans fluid level using the new PDF info. Disconnecting the jumper wire does change how the engine idles and you'll notice it when the ATF is trickling from the overflow port. That being said, the amount of fluid didn't vary at all. I went from a "optimally filled" trans, put 16oz into the fill hole, got into AT TEMP check mode, pulled the jumper wire, light came on, pulled the overflow plug and 16oz came out.
    I'll use the new procedure from now on, but I am glad there wasn't a huge discrepancy in the amount of fluid drained between leaving the jumper wire in vs taking it out.
    As for resetting the ECM after, I could see it being necessary if you went 60k on the original fluid and really abused the trans during that time. The viscosity will naturally change over time due to heat. If it happens with motor oil then it'll happen with trans fluid.
    However in my case I am doing yearly drain/fill to the tune of 3.5 quarts as preventative maintenance. Since this is really overkill, the trans won't ever really notice a change in viscosity from a year of my soft driving. (but I like the idea of keeping the additives fresh)
    Is the OP still around to update the first post in this thread? There are a few things that need to be noted:
    1) The AT TEMP check light will come on for 2 seconds and then go off. It does not come on again for 2 seconds.
    2) Add the step about pulling the jumper wire once you've verified you're in AT TEMP check mode.
  12. May 21, 2016 at 11:37 PM
    #712
    Lester Lugnut
    Correct - the A/T temp light only comes on for 2 secs when the system enters temp check mode. At that point the jumper wire/paper clip is to be removed.
    When the lower level of the temp range has been reached, the A/T temp light will come on solid. This is when I remove the overfill plug.
    Remove that plug whenever you like.
  13. May 27, 2016 at 2:43 PM
    #713
    TACOconvert2012
    TACOconvert2012 My truck hates you. My wallet hates you.
    Socal
    SC'd 2012 MGM TX/Pro 4x4
    never ending..
    I didn't go through all of the thread, but has anyone tried used a ScanGuage to monitor AT temp??? might make this process so much easier for anyone who has one already like I do...
  14. May 27, 2016 at 3:36 PM
    #714
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I did a drain and fill today on my transmission and followed this write up again. After a few times its fairly easy to go into temp mode.
    I removed 3 quarts and then added 3.25 back in. Once I hit temp mode only about
    1/16 of a quart drained from the check plug.
    RJM
    Lester Lugnut and choupick like this.
  15. May 30, 2016 at 10:03 AM
    #715
    2015WhiteOR
    Gainesville TX
    Sounds about right. You're all set and now you know that the level is correct. Drive with confidence.
  16. May 30, 2016 at 7:16 PM
    #716
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Posting to help out anyone who may be in my shoes, i'm doing this today on a hot day for my area, around 90F. did a quick drive 1 mile down the road to pick up parts and back, drained my atf, pumped in the new fluid. When I go to put it into check mode the light just keeps flashing, I've waited almost 5 hours now and it's gone solid into check mode. i'm going to give it another hour to try and let it get below the temp and take it back up to solid, if it doesn't in an hour i'm just going to check the level then since it should be good to check when the light is solid. but beware of time best to do after sitting over night I would guess.
    *Update
    2 hours later the temp light was still solid when checking, never dipped lower than that I guess so I figured it was good and opened the overflow. one thing that was strange was that I had it down almost to what I would consider a "slow trickle" and I was about to cap it off, then the rpm dropped on my car and a big flow started back up... I let that flow flow until it came to a "small trickle?" and then I capped it. everything seems fine so far driving around the block, but I thought that was interesting.
  17. May 30, 2016 at 10:05 PM
    #717
    Lester Lugnut
    And there you have it.
    Elevate the front end...way up and you'll drain an extra qt. Refill accordingly - drive for a day - repeat the drain/refill. Do this every 25K-30K and you'll never have dirty fluid.
    Yes - I know - some of you have gone 200K+ w/o changing fluid. And some people smoked until they were 90.
    Loco38SUP[QUOTED] likes this.
  18. May 31, 2016 at 11:22 AM
    #718
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I just saw this after doing my first change yesterday. This is exactly what happened to me I was about to be down to a trickle and the engine rpm changed and a new stream of fluid started back up. I ordered 4 more quarts of fluid and am going to do another flush Thursday and will try this method.
  19. Jun 3, 2016 at 11:17 PM
    #719
    Mehullica
    Central California
    05 Prerunner d-cab
    This is why the correct procedure must be followed. Sudden RPM changes by even 50 rpms will pump more or less fluid causing the fluid to pour out the overflow tube
  20. Jun 13, 2016 at 6:25 PM
    #720
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Thanks to the great information in this thread I was able to drain and fill the transmission fluid on my truck this past weekend. The fluid was ~17K miles old and was a bit darker compared to new fluid but nothing alarming. That gave me some peace of mind that the previous owner didn't abuse the rig.
    Being paranoid to short out something on the OBDII connector I purchased a male OBDII connector and soldered a wire, between pins 4 and 13, to the rear side of its PCB. I think it cost me $6 (Amazon or eBay) and took about five minutes to get it soldered and screwed back together. Then I just plugged this dongle into the truck's OBDII connector.
    A few things I noted:
    1) Similar to one of the post from a couple pages back the A/T Temp light lit up for two seconds when I entered temperature check mode but it did not light up for two seconds when I put the rig in park.
    2) I read the updated procedure about removing the OBDII jumper after exiting temperature check mode . . . after I was done completing the job. Hopefully enough fluid drained out. Next time I'll remove the jumper at the appropriate time.
    3) It took about three minutes for the A/T Temp light to turn on after the truck was idling in temperature check mode. The outside temperature was ~70*F when I did this. An hour before I had driven the truck slowly up and down the street, since I had changed out some of the power steering fluid, so I'm sure this helped warm up the tranny fluid.
    4) I drained about 2.7 quarts and pumped in 3.0 quarts. About 0.1 quarts came out of the check port when I decided the fluid was coming out at a "slow trickle."
    Thanks,
    2015WhiteOR and Loco38SUP like this.
