How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Jun 14, 2016 at 12:17 PM
    #721
    Sandokan
    Sandokan Member
    Colorado
    TRD Off Road
    Well. I Am kind of mad and confused.
    I ended up here because I got a new 2016 TRD OR DBCB LB Tow Package and I came accross gearcruncher posts about the Tacoma's being delivered low of ATF and also his post about Toyota's ATF WS being sub par.
    So I did the ATF level check with the thermostat open and it was about .6 qt. low. I figured since I am doing this I might as well now drain it and fill it with Valvoline Max Life ATF, compatible with WS and which many recommend here at Tacoma Wolrd.
    Then I come to find out that this draning method only gets about 1/4 of the ATF out, about 3 qts and capacity is about 12qts. So now I have a mix of ATF, Toyota and Valvoline in my truck.
    Now I will have to figure out if this is really bad and if so I will have to take it somewhere where they can flush the whole thing out and replace with new. The fluid is new and clean so it should be just a take out and fill with one-kind anew.
    Now regarding the hoopla about Toyota delivering and giving customers vehicles low in ATF.... Well some people report that it was found to be low but it is usually less than 1qt so much less than 10%. And if this is standard practice for Toyota, how many millions of vehicles they sell ea. year? And how many end up with bad transmissions? I think this, as many thing on the web, is blown out of proportion and many of us, overzealous, end up making things worse. After crawling under my brand spaking new vehicle I really had the feeling that it was not put together by a bunch of clowns, even if they are saving money by introducing more and more plastic parts.
  2. Jun 14, 2016 at 2:53 PM
    #722
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    First of all - you're fine. You can mix MaxLife and WS. Don't waste brand new fluid. As long as the level is cool, you're OK to keep driving since frankly your transmission doesn't know you are running 25% MaxLife/75% WS.
    That being said, from a WARRANTY perspective, consider that the WS now has a shortened life span. I'm not saying the fluid is compromised or won't perform, but that you should find a convenient time in the future to go back to WS. You can do a 100% exchange via the trans cooler lines. There is a writeup on this site on how to do that so you'll have to find it.
    Why should you go back to WS? You have a 50k mile powertrain warranty. While the Magnusson Moss act protects you, life tends to be easier when you don't give the dealership a reason to deny a claim in the event that something breaks. I'd rather spend $100 on new fluid than have to spend 8 months and $4k in court fighting Toyota corporate.
    Finally - you are correct that half a quart in a 12 quart system is nothing. On principle, it seems bad that they underfill from the factory, but I would be hard pressed to say it has a detrimental effect on the transmission.
    R0dzilla75 and patbegley like this.
  3. Jun 14, 2016 at 3:37 PM
    #723
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Been thinking about doing the same thing! Good job!
  4. Jun 14, 2016 at 3:47 PM
    #724
    Sandokan
    Sandokan Member
    Colorado
    TRD Off Road
    Thanks!
    I thought it would be OK like this 75/25.
    Now I could not tell much difference in color or consistency between ATF WS and Valvoline MaxLife.
    Do you think the dealer service dept would if it came to needing warranty repair, and especially after the fluid has gone through several thousand miles of service life?
    I was thinking on the line of removing All the ATF WS and replacing it with Valvoline per the write up on this site, I know which one it is, using the cooler outlet line. Yep it would cost another close to $60 in additional fluid but then I would have better quality fluid. I am 66 and it sure looks like the last vehicle I purchase.
    The truck is warrantied 8yrs/100,000 miles.
  5. Jun 14, 2016 at 4:09 PM
    #725
    2015WhiteOR
    Gainesville TX
    For the most part, trans oil is trans oil. The variations are in the additive package to protect against heat and wear, and maybe some friction modifiers.
    Ultimately do what makes you feel comfortable inside. It's probably better to be 100% Maxlife or 100% WS, but a blend is really not going to be discernible to anyone but a chemist.
  6. Jun 20, 2016 at 11:51 AM
    #726
    Helislider
    Helislider New Member
    2015 TRD Sport 4x4
    Oil catch can, trans cooler
    Does this procedure work with a 2016 4Runner?
  7. Jun 20, 2016 at 1:49 PM
    #727
    2015WhiteOR
    Gainesville TX
    If you can find us the model of trans used, we can tell you.
  8. Jun 20, 2016 at 4:36 PM
    #728
    Helislider
    2015 TRD Sport 4x4
    Nor sure of the trans model number I will look at it when I get home. It's a 2016 SR5 premium with 5 speed trans.
  9. Jun 24, 2016 at 9:23 AM
    #729
    TonkaToyTaco
    TonkaToyTaco Hope you can run faster than 965 FPS
    Louie
    11 Tacoma TRD DCLB 4X4
    Fox 2.0 Coilovers cranked up with JBA UCA, Rear OME 2" leaf pack with Ride Rite air bags, SCS Steath 6 matte black rims wrapped in 285/75/17 Cooper ST MAXX, Blacked out emblems, Debaged tailgate, Tinted windows (5% in rear, 5% up front and 40% on windsheild), Retro color matched HID headlights with Amber Halo, Projector LED Foglight, Custom LED Taillight and 3rd brake light, T-Rex 2 eyelids color matched, Fog light anytime MOD, All LED interior and exterior ligths, Volant CAI With forced Ram, JET throttle body spacer, Aero Turbine SS Muffler, Aero Turbine SS 4inch tip dumped after axel, URD MAF Calibrator, LED bed lights, 4X4 light mod, Satoshi Grill with matching scoop and lower Valance, 20" LED bar and 2 LED Pods behind Satoshi, Diff breather mod, Sea Blu secondary fuse box with 100A breaker, Outlaw Train Horns with dual Air Compressors and 5 Gal tank, Ultraguage, Andre Devil Horns, Pedal Commander
  10. Jun 26, 2016 at 3:37 PM
    #730
    Bowfisher1
    Bowfisher1 Well-Known Member
    Ty
    Louisiana
    07 Tacoma Double cab
    3 inch Rough Country Off Road lift/level kit, NITTO Trail Grapplers, Monster Xd Series rims, memphis door speakers and amp, two sundown SD-2 10's, Kenwood head unit, weather tech floor matts, coverking neoprene shadowgrass seat covers
    Is there any kind of gasket/seal on the check plug? I'm thinking I may have devolved a slow leak after messing with the tranny, but it could just be some excess that was splattered collecting there and slowly dripping. I can't remember if there was one or not when I took it out. It's an 07 auto 5spd BTW! Thanks in advance!
  11. Jun 26, 2016 at 6:46 PM
    #731
    2015WhiteOR
    Gainesville TX
    There should be an aluminum hollow crush washer on the check plug.
    Theoretically, you should be able to unscrew the check plug while the truck is cold and nothing would drip out.
  12. Jun 27, 2016 at 5:00 AM
    #732
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not true. I inadvertently allowed my crush washer to fall off, so had to pull the plug while not running. Fluid will run out if not running. I just pulled the plug and covered it with my thumb while putting the washer back on and then reinstalled it.
  13. Jun 27, 2016 at 6:03 AM
    #733
    2015WhiteOR
    Gainesville TX
    Sorry I meant cold, but running. (as in you just started it up and it's not fully warmed up)
  14. Jun 27, 2016 at 7:56 AM
    #734
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Drain plug and overfill plug gaskets are same part number - 35178-30010
    Refill plug gasket - 90301-15004
    Transmission pan gasket - 35168-60010
    nartmot and Loco38SUP like this.
  15. Jul 2, 2016 at 1:55 AM
    #735
    t3hk
    t3hk Active Member
    10 PreRunner SR5
    Be careful when putting the drain plug back in -- I ended up in a situation where the drain plug wouldn't tighten, looks like I stripped or crossthreaded it. I already put in 3 qts of WS fluid, so that's going to be fun when I drop the pan to replace it.
    The109 likes this.
  16. Jul 25, 2016 at 3:09 AM
    #736
    tunabreath
    tunabreath Member
    Ohio
    08 SR5 AC
    Is everyone using WS fluid from Toyota specifically?
    Walmart sells Super Tech DEXRON VI Automatic Transmission Fluid which meets Toyota WS specifications and it is only $4.27/qt.
    "Suitable for use where DEXRON II, DEXRON III, JASO M315 (1A), Toyota WS and Toyota T-IV fluids are recommended"
  17. Jul 25, 2016 at 6:07 AM
    #737
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Had the same thing happen. Spilled about 2 quarts on the driveway when I replaced the pan.
    I found a new pan at Lakeland Toyota overstock parts for $87. Everyone else wanted $150 to 180. I'm now tightening the drain bolt to 12 ft lbs and no leaks.
    The109 likes this.
  18. Jul 25, 2016 at 1:11 PM
    #738
    mattfromkingston
    mattfromkingston Member
    2013 dclb
    just got done doing this. i bought a hand pump from harbor freight that goes onto the top of the bottle. well it also makes the bottle topheavy and you guessed it i spilled a bunch in the driveway. also, all said and done i think i was shy of 3 quarts, more like 2.7 ish. for what its worth i learned that when shifting from n->d->n do it pretty quickly. i was doing the shift with 3-4 seconds between them and it wasnt lighting up the at temp light.
  19. Jul 30, 2016 at 1:22 PM
    #739
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Of course not. Many use Valvoline MaxLife; die hards use Amsoil; the cheapos use SuperTech. I don't have a problem using SuperTech coolant, but ATF fluid is a bit more complex; so, I avoid the cheapest stuff when it comes to ATF for my vehicles.
    I read back a few thread pages and read how many are confused with the ODB jump wire method. The IR method has been proven to be just as accurate. It's what I have been using in four ATF flushes with my Taco and the wife's Lexus with no apparent ill results.
    See post #146: http://www.toyotanation.com/forum/1...o-transmission-flush-pics-10.html#post9686129
  20. Jul 30, 2016 at 2:26 PM
    #740
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    My truck has about 120k on it and the transmission has never been serviced. I noticed it hasn't been as smooth at it used to be so I replaced my worn carrier bearing and that helped some. So I've decided to do the transmission fluid change. I've done the drain and fill twice now and it feels so much smoother. I will probably do it one more time just to get it cleaned out.
    Anyway I just wanted to share this graduated pitcher I bought off Amazon, works great. Drain it, measured it,dumped and poured fresh fluid up to the line, and hand pumped it straight out of the pitcher.
    Markc1024 likes this.
