How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Sep 4, 2016 at 5:47 AM
    #761
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
  2. Nov 16, 2016 at 8:26 AM
    #762
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    My drain and fill on my 08 took over 7 quarts. how are you guys only filling 3 quarts
  3. Nov 16, 2016 at 9:14 AM
    #763
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    Did you measure how much you drained out?
  4. Nov 16, 2016 at 10:12 AM
    #764
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    You have either overfilled your transmission or by some means other than draining the pan - have drained more fluid than what you get from a pan drain.
    2015WhiteOR and NABeast like this.
  5. Nov 21, 2016 at 7:03 PM
    #765
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Thanks, great post!!!
    Are there any pictures of the transmission fill hole that could be put on the original post? I found it but it's way up high on passenger side and I wasn't 100% sure I had it right except it was the only 24mm.
  6. Nov 22, 2016 at 7:02 AM
    #766
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    The plug has "WS" stamped on it, sounds like you have the right one.
    zerotimeouts[QUOTED] likes this.
  7. Nov 22, 2016 at 11:12 AM
    #767
    zerotimeouts
    Nor Cal
    2011 DCSB 4.0 S/C
    I thought so, I went for a drive after and it didn't blow up :bananadead: so that's good.
    Pabloeeto[QUOTED] likes this.
  8. Nov 22, 2016 at 3:14 PM
    #768
    skkzhg
    skkzhg Well-Known Member
    Stephen
    North Georgia
    Thanks for the great post. Just finished my drain and fill at 30k miles.
    A few particulars:
    2015 TRD OR DCSB 4.0
    Drained a tad over 2.5 qts
    Refilled with Valvoline MaxLife. Added back a little over 3.5 qts.
    Drained out about .5 qts checking the level. All total added back about 3.2 qts. I guess mine was almost 1 qt low from the factory.
    Entering temp check mode, the light did not illuminate at all when I returned the shifter to Park. It only illuminated for 2 secs after the 6th N-D-N cycle. OP said it would light up when returned to P but mine did not.
    Took almost 15 mins of idle time to reach proper temp and illuminate the light.
  9. Nov 22, 2016 at 6:50 PM
    #769
    Scott B.
    Scott
    Georgia
    My 2015 acted the same way.
    I wonder if they made a programming change in the '15s?
  10. Nov 27, 2016 at 5:40 PM
    #770
    ASUAviator
    ASUAviator Well-Known Member
    Anchorage, AK
    Tacoma TRD Off Road
    Hoping someone can help me out real quick. Doing a 1st time drain/refill on my '13 V6 4x4 w/tow. pulled the 5mm check nut and had just shy of a quart come out. Had me thinking it was over filled. pulled the 14mm drain and just shy of 2 quarts came out. Total drained is about 2 3/4 quarts.
    Do I refill with 2 or 3 quarts????
  11. Nov 27, 2016 at 5:50 PM
    #771
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Were you in the temp check mode? If not, fill with 3 quarts and get her to temp and follow the directions.
  12. Nov 27, 2016 at 5:51 PM
    #772
    Scott B.
    Scott
    Georgia
    3 quarts minimum.
    You want to overfill the transmission, then, once at temperature, drain it out of the level port until there is a slight trickle of fluid running out.
  13. Nov 27, 2016 at 8:35 PM
    #773
    ASUAviator
    Anchorage, AK
    Tacoma TRD Off Road
    Thanks for the help. Got it figured out!
  14. Nov 29, 2016 at 9:28 AM
    #774
    Alexfiggy
    Alexfiggy Well-Known Member
    Alex
    Miami
    Trd off road
    I was using a very nice thermal imaging camera made by MSA to check weather my scan gauge was giving me a good trans temperature. It did .it was with in a 1 or 2 degrees .
    Nedrolls likes this.
  15. Nov 29, 2016 at 9:35 AM
    #775
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    See Crom's post on this.
  16. Nov 29, 2016 at 11:20 AM
    #776
    Alexfiggy
    Alex
    Miami
    Trd off road
    Can. You be more specific?
  17. Nov 29, 2016 at 11:59 AM
    #777
    David K
    Sorry...
    In the big D.I.Y. ATF Flush thread, read replies from Crom... beginning on page 14 or 15, I think https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/page-15
    I hired Crom to do the flush on my 2010 Tacoma (at 90,000 miles)... and it was perfect! My truck has shifted much smoother ever since, too.
    Here is more: https://www.tacomaworld.com/threads...d-and-adventures.362772/page-43#post-11372529
    My report on Crom's procedure on my truck:
    https://www.tacomaworld.com/threads...gen-tacoma-today.6499/page-4853#post-13103051
  18. Jan 13, 2017 at 2:42 PM
    #778
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
  19. Jan 14, 2017 at 2:59 PM
    #779
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I ended up replacing my read output shaft seal today along with a drain and refill on the transmission. Completed in two hours (with a trip to Lowes for a PVC seal driver). Transmission shifts much better and have peace of mind knowing my seal isn't dripping anymore. I recommend the drain and refill for anyone who is experiencing hard shift points at random intervals!
  20. Jan 17, 2017 at 4:03 PM
    #780
    sy272004
    sy272004 Well-Known Member
    West Chester
    15 TRD V6 4x4 DC
    3" lift. 33" tires. Headlight Retro, intake, exhaust
    says to use computer to check temp of fluid and not ir temp gun. how about Fluke meter with temp probe and make hook and dip it inside transmission through level check hole?
