How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. May 24, 2017 at 5:43 PM
    #921
    Ncskeeter
    Ncskeeter Well-Known Member
    North Carolina
    2005 Silver Tacoma Prerunner DCSB SR5
    Mostly stock
    I recently did the same thing. A new pan, gasket, and drain plug was just over $100.
    I'm never using a torque wrench on a drain plug again.
  2. May 25, 2017 at 6:43 AM
    #922
    ls1 prerunner
    ls1 prerunner Internet Scientist
    Andy
    El Paso, TX
    19 Golf .:R & 11 4x4 TRD LT S/C
    TRD S/C, Camburg LT, DMZ SUA, SAW Shocks in all four corners, Glassworks hood, fenders and Bedsides, 35" Toyo MT, KMC Enduros
    Checked it last night and the nut definitely came loose on the pan. I'm going to pull the pan and try to weld it first using bronze if the nut isn't steel.
  3. May 25, 2017 at 7:12 AM
    #923
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    If that doesn't work, you could always weld a castle nut upside-down to the pan, and use a matching plug bolt as a new drain plug.
    I'm sure you could find a metric plug/nut combination, if that is important to you.
    Either way, much cheaper than buying a new pan.
    ls1 prerunner and NAAC3TACO like this.
  4. May 26, 2017 at 8:42 PM
    #924
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    transmission flush question...I was going to get my transmission on my 2006 OR flushed, and the dealer told me today that I have a "Sealed Transmission" and it takes more time and effort/cost to flush and refill the transmission since it has to be pumped out AFTER cooling to "room temp", and then new fluid has to be pumped in. Real? Bogus? Getting the runaround? HELP!!
  5. May 26, 2017 at 11:23 PM
    #925
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    It is just a standard flush, the fluid has to be below 86°F (iirc) per Toyota FSM before you start the temp check procedure. But now there is a SST (special service tool) which allows them to check the fluid at any temperature. They are BSing you or don't know what they're talking about. To do the standard temp check mode though it has to be cool at the beginning of the procedure.
  6. May 26, 2017 at 11:40 PM
    #926
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
  7. May 27, 2017 at 12:39 AM
    #927
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Nay. It's the ATF in the transmission that needs to be at the specified temp, not the ATF in the bottles. As ATF warms up, it expands. If it warms up too much, you'll be removing too much ATF. If it doesn't warm up enough, you'll be leaving too much ATF in the tranny.
  8. May 27, 2017 at 4:30 AM
    #928
    91859706
    91859706 I like Toyota trucks.
    Ithaca, NY
    2006 DCSB TRD OR
    I called my localdealershio today and they said it would cost $165 for a flush. I'm still going to go in and talk to the service tech and see what all is involved and make sure they know what they are doing before scheduling an appointment. I also have a 2006 and I'm debating between flush and drain and fill. But I'm the second owner right at 109k miles and want to keep it going...so long story short your dealership is full of it.
  9. May 27, 2017 at 7:14 AM
    #929
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    There's so much conflicting information coming from the dealers on whether or not a trans can or should be flushed, coupled with a few dealerships under filling, that everyone should just follow the info in this thread and diy. It's not ideal, but it's doable by just about anyone with some patience and ability to follow directions
    NAAC3TACO likes this.
  10. May 27, 2017 at 10:01 AM
    #930
    Chuy
    Lakeside, CA
    Silver Taco
  11. May 28, 2017 at 5:43 AM
    #931
    gearcruncher
    Canadain bumper technician
    The proper way and only way to service a transmission is by removing the transmission pan and inspecting the amount of debris laying in the bottom of the transmission pan and visually looking at the magnets that are placed in the pan for a reason .
    Every truck will have different levels of contamination and wear . You cant base a transmission flush on what other people say .
    Why ? because he or she operates the truck differently from you .He may have overheated the transmission 50 times and is basing his opinion only on what he found . If you flush without removing the pan , you are simply guessing that the bottom of the transmission pan may be clean and for many unlucky individuals ,you pay the price down a very short road
    Listen to the guys who service transmissions for a living " not the dealership "
    Take the pan off , check the re-usable filter , inspect the magnets and make a professional diagnosis from that point on .
    If the pan is clean , magnets are clean and filter is clean , flush the rest of the fluid when you put the pan back on .
    Do " not " flush the transmission without performing the above inspection
    Flushing the transmission after the pan is removed eliminates the possibility of sending debris from the transmission pan through your valve body . Ask me why I know this he he o_O ?
    91859706, ImpulseRed008 and DVexile like this.
  12. May 28, 2017 at 7:29 AM
    #932
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Ok so my search skills have failed me, anyone @gearcruncher have DYI link to dropping the pan and cleaning magnets and filter?
    If it's in this thread I missed it:notsure:
  13. May 28, 2017 at 9:52 AM
    #933
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    It's easy... remove bolts, drop pan, clean magnets. Remove bolts holding filter, clean, re- install in reverse order.
  14. May 28, 2017 at 10:54 AM
    #934
    Chuy
    Lakeside, CA
    Silver Taco
    There is no DIY link specifically addressing the ATF filter. It really isn't difficult but if you've never changed one, I can see the apprehension. This video is good, except for the ATF refill procedure. He doesn't measure the ATF temp when refilling.
    https://www.youtube.com/watch?v=4FflypYGgh8
    taco2010trd and DVexile like this.
  15. May 28, 2017 at 11:14 AM
    #935
    303tacoma
    Rebecca
    Thank you!! Does look fairly easy.
    Another thing I noticed is that he didn't loosen fill plug before draining his pan, a big no no that Ive learned specifically from this forum.
    Thanks again for the video:thumbsup:
  16. May 28, 2017 at 6:53 PM
    #936
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    I don't use the fill plug anymore, I fill through the cooler lines with a hand pump. Some people opt to use the sprayer method as well.
    303tacoma[QUOTED] likes this.
  17. May 28, 2017 at 9:03 PM
    #937
    Chuy
    Lakeside, CA
    Silver Taco
    Remind me why it's recommended to loosen the fill plug...Is it so fluid flows out easier? Shouldn't matter as all auto trannys have a breather hole/opening somewhere. I've never loosened it and had no problems draining ATF, that I recall. Only drained it once, when I replaced the ATF filter. Other times, I flush by disconnecting the radiator return lines and pump fluid into the tranny with the Milescraft drill pump.
  18. May 28, 2017 at 9:25 PM
    #938
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    There's a breather on the top of the transmission to allow for the fluid to expand and contract.
  19. May 29, 2017 at 6:37 AM
    #939
    303tacoma
    Rebecca
    It's recommended to loosen all fill plugs before draining any fluid so you don't put yourself in a bind if you can't get them open after draining... It happens:)
    Maybe this is more in reference to the diffs and tcase.
    DVexile likes this.
  20. May 29, 2017 at 10:27 AM
    #940
    Chuy
    Lakeside, CA
    Silver Taco
    Never heard of stuck plug but not a bad idea. The problem with many drain plugs are the small heads, and beveled sockets don't make it easier. Which is why I grinded this extra socket.
