How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Aug 9, 2017 at 5:14 AM
    #961
    blazze2005
    blazze2005 Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    The toyota part# for the trans pan drain plug crush washer is 35178-30010
    Is the trans pan check plug crush washer the same part#?
    Thanks for any help!
  2. Aug 9, 2017 at 5:28 AM
    #962
    chinorx3
    chinorx3 Well-Known Member
    Florida
    06 Tacoma Lifted
    Pro Mod Lift Kit , Method wheels on 35's
  3. Aug 9, 2017 at 10:58 AM
    #963
    blazze2005
    South Jersey
    I have just confirmed with toyota that part#35178-30010 fits both. The crush washer for the trans fluid pan drain plug and the trans pan fluid check plug.
  4. Aug 17, 2017 at 8:05 AM
    #964
    06TXED
    06TXED Well-Known Member
    Tony
    Aurora CO
    2023 DCSB MGM TRD OR 4x4
    I did the drain and fill last night per this thread. I did the fluid level check at 115 deg f (with a OBDII shop scan tool) . In the OP the temp range is between 115-130 deg f. However I have read on service manuals the temp for checking is between 97-115 deg f . Since I did the fluid level check at 115 am I ok on the fluid level ? what is the correct range for the fluid level check ? TIA
  5. Aug 17, 2017 at 8:53 AM
    #965
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    I think later models like ours are the 97-115. My 2010 falls into that range. Earlier models are the 115-130, from what I've seen.
  6. Aug 24, 2017 at 3:54 PM
    #966
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Getting this done at the dealership tomorrow for $125.. good deal?
    Long story to what happened and why i'm doing it lol
  7. Aug 24, 2017 at 6:18 PM
    #967
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    We have plenty of time...please share :cool:
  8. Aug 24, 2017 at 6:30 PM
    #968
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    went to go change the oil (which I've done before) but was kinda rushed I had a dinner to go to. Needless to say I started to drain the transmission fluid and didn't realize it until it was just about fully drained... So, this was around 6pm... dealership closed, dinner was at 7pm and I worked at 6:30am the next morning. Ended up getting the truck towed to a Big Brand Tires they were the only people that could get me in right away. They filled it....BUT they used Shell brand transmission fluid... So, been driving around for week with it and its been acting up a little on deceleration and in first after a stop sign/light. Delayed movement with a sudden jolt then its smooth as can be. Found out through this forum a few day later that you can/should only use Toyota fluid... So now that's happening tomorrow
  9. Aug 24, 2017 at 6:33 PM
    #969
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    That seems low for a full flush.
    themanbearpig012 likes this.
  10. Aug 24, 2017 at 6:35 PM
    #970
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    not a full flush. Just a drain and fill
  11. Aug 24, 2017 at 6:41 PM
    #971
    ImpulseRed008
    Susan
    SC
    my .02 if you are having tranny issues with the shell fluid, you need to replace all the fluid, not just part of it.
  12. Aug 24, 2017 at 6:49 PM
    #972
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Well, I scheduled a drain and fill. But I was gonna have first have them check the levels of the fluid. I've read on here and elsewhere that the issues i'm having can and very likely due to it being under filled
  13. Aug 24, 2017 at 6:58 PM
    #973
    ImpulseRed008
    Susan
    SC
    Only issue I had from mine being underfilled, was hard shifts, especially when the cruise was on and going up a hill. Hope that's all your issue is.
  14. Aug 24, 2017 at 7:02 PM
    #974
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Its more of just a delay shifting into first gear. smooth shifting the rest of the way through
    Brie likes this.
  15. Aug 24, 2017 at 7:20 PM
    #975
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    and it only does it sometimes...
  16. Aug 25, 2017 at 3:15 AM
    #976
    80schild
    80schild Well-Known Member
    Chad
    Flori-Bama
    2007 TRD Sport Access Cab
    You can use whatever brand fluid you want, as long as it says it's Toyota WS compatible.
  17. Aug 25, 2017 at 8:04 AM
    #977
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    They didn't show me the bottle of fluid. Have heard toyotas are finicky with any other than oem toyota fluid. Just got to the dealer, explained and they said it's probably a combination of it being under filled and not using the correct fluid. Estimate was $115
  18. Aug 25, 2017 at 9:41 AM
    #978
    themanbearpig012
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    All done. Turns out the shop that had originally filled it only put in 1 quart of fluid!
  19. Sep 5, 2017 at 9:57 PM
    #979
    jclassboat
    jclassboat Member
    AL
    2015 Pre-runner
    Has anyone installed a Magnefine Transmission Oil Filter? Would a real filter like Magnefine eliminate the need to drop the pan, clean the magnets and replace the OEM Transmission Filter that's little more than a screen?
  20. Sep 18, 2017 at 1:54 PM
    #980
    jdr43
    jdr43 Well-Known Member
    Jim
    Hamelton Montana
    2016 Tacoma SR5
    Just reached 30,000 miles on my 2016 SR5 so I decided to do a drain and fill of my transmission it was strait forward no problems, removed the drain plug and 3gt 8oz came out and I put the same back in used Valvoline MaxLife it has the WS rating.
    07 sport 4x4 likes this.
