How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Aug 14, 2010 at 11:34 AM
    #81
    Rockadile
    Rockadile Member
    Alan
    PA
    2010 Access cab 4 cyl 2WD
    I hear you loud and clear, And I understand you made several of the disclaimer type referances telling people to double check thier application.
    As the post progressed there were more and more referances made to 2 wheel drives and 4 cylinders and people not having lights in thier dash. Your post is amazing, especially the poor mans method of getting the temperature to read out. I was all set to start the procedure when I double checked the window sticker and realized I had a 4 speed ECT. I then took a look where a dipstick tube should be and it was there. My concern was that there may be other people as clueless as I was. Please take no offense, none was intended.
    I still can not believe that toyota builds a truck that can last 300 thousand miles and claims the ATF doesnt need to be changed!
  2. Oct 9, 2010 at 10:34 PM
    #82
    JUJtacoma2010
    JUJtacoma2010 Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I am wondering how complicated are the steps described. today I drained some of atf mistakely while chainging oil.
  3. Oct 9, 2010 at 11:06 PM
    #83
    sagebum
    sagebum Well-Known Member
    James
    Elk Grove (NorCal)
    07 DC 4x4 TRD OR white
    It wasn't too difficult. I actually just did this procedure last weekend and was able to put in ~12 new qts of the standard ATF WS.
    I was able to get the AT temp check on my first try.
    BTW, Thanks to OP for the writeup!
    TacomaCZman likes this.
  4. Oct 10, 2010 at 8:51 AM
    #84
    JUJtacoma2010
    Fresno
    Can I just do the temp check just as a practise
  5. Oct 10, 2010 at 3:49 PM
    #85
    sagebum
    James
    Elk Grove (NorCal)
    Yes you can.
  6. Oct 10, 2010 at 9:36 PM
    #86
    JUJtacoma2010
    Fresno
    Another question. I probably drained out 1/2 quarts of atf. how do I go about refilling it? do I drain out everything? my truck has only 5000 miles on it. do I just put in another quarts of atf and follow the procedure of getting it to the right fluid level?
    Where is the overflow plug?
  7. Oct 11, 2010 at 5:56 AM
    #87
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you wish you can just refill with the amount you drained. The overflow plug is the one located in the ATF pan that requires an allen key or hex bit for removal. The size is stated in my original post.
  8. Oct 11, 2010 at 9:45 AM
    #88
    JUJtacoma2010
    Fresno
    I called the dealer just to get a quote on refill and they said $170.
    I was like are you kidding me? I am definately do this myself later today and let you guys know how it went.
    thanks for all the advice.
  9. Oct 11, 2010 at 8:56 PM
    #89
    JUJtacoma2010
    Fresno
    I did mine today by following the instruciton here. just not sure where the ring in the picture belongs. anyone knows
  10. Oct 12, 2010 at 8:44 AM
    #90
    ec8
    ec8 Newby
    Stuart
    There is a crush washer (that's what that is) on both the drain bolt and one on the overflow bolt (same size/part number). The Refill bolt has a rubber o-ring type washer that you can also order if you choose, but probably less important. Most say you can re-use the washer, but it crushes on intial use and for $2 should probably be replaced
  11. Oct 15, 2010 at 8:34 PM
    #91
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    What a mofo. Now I know why Toyota gets a good labor rate...
    I purchased a Chilton manual a couple weeks ago and decided to change my tranny fluid and filter on my 08 Prerunner 2wd. The truck only has 60k miles on it, but I decided to change it anyhow. The Chilton manual says to change the fluid and filter at 30k. That seems a little over the top but so does changing at 100k.
    I'm not sure why they recommend changing the filter, but they do. So I figured hell why not. The whole procedure was for the most part as the OP describes except I decided to change the filter too. Getting the ATF light to come on was hit and miss but it did come on. I only had two complications during the process. First complication was I overtightened the tranny pan bolts during reinstallation and snapped off a bolt. (SH*T!) Luckily I had a replacement in my spare bolts box (65 in/lbs FYI). The second complication was, my tranny required 5.1 quarts of fluid to refill it. I only purchase four per the Chilton manual's recommendations of 3.2 quarts. I do live 30 min from an auto parts store so that was annoying but whatever.
    Oh I guess there was technically three complications. I'm a Valvoline freak so I purchased Valvoline High Mileage (WS certified). When I went back for the fifth and sixth quart they said they can't carry the stuff anymore per some California law... WTF. Had to use Casterol as an alternative.
    So that was my experience and so far the truck is functioning well. I have my fingers crossed. Thanks OP
    allenn likes this.
  12. Oct 16, 2010 at 2:51 AM
    #92
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    5.1 seems high. Wonder why yours needed so much?
  13. Oct 16, 2010 at 9:37 AM
    #93
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Not too sure myself. I drained my catch pan back into the oil bottles and did manage to fill up five quarts. So my only guess is that when you change the filter during your tranny fluid change, it allows a little more fluid to come out.
  14. Oct 16, 2010 at 9:40 AM
    #94
    Fortech
    CANADA
    I'm interested in hearing about the filter they sold you as all most of us ever considered it was a mesh screen.
    Was it dealer only item or available in the aftermarket?
  15. Oct 16, 2010 at 9:44 AM
    #95
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Special ordered it from Kraigen. They ordered it in the morning and had it for me that afternoon. I'll go grab the box and see what brand it is...
  16. Oct 16, 2010 at 10:08 AM
    #96
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    It's called a Power Torque Automatic Transmission Filter Kit. Came with the transmission pan gasket too. There is a fine mesh screen inside the filter. Also on the bottom of the tranny pan was four magnets which I wiped clean. They had a fair amount of crap stuck to them in the way of metal dust.
  17. Oct 16, 2010 at 11:00 AM
    #97
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Just curious. There was crap on the magnets. What was the condition of the
    fine mesh screen inside the filter ? In other words was it worth the effort to change it ?:confused: Thanks. Curious George
  18. Oct 16, 2010 at 11:23 AM
    #98
    rzimm001
    rzimm001 Tearmytaco
    Bobby
    Wildomar
    Here are the pictures of the old filter as it came out of the truck. I probably would not have changed it if I had to do it over again.
  19. Oct 16, 2010 at 9:30 PM
    #99
    george3
    New Jersey
    Thanks for your reply and for the bottom line " I probably would not have changed it if I had to do it over again." I'm sure that will save some readers of the post time and $. Thanks. again Curious George Attached Thumbnails [​IMG]
  20. Oct 25, 2010 at 2:30 PM
    #100
    HBtacoma
    HBtacoma SoCal Tacomas
    Oscar
    Huntington Beach
    || Deep Black Custom Paint By DUPONT FINISHES w/ Custom Airbrush Artwork || RCD 4.5 Inch Lift Kit || 20x10 Black XD Monster Wheels w/ Toyo MT 33x12.5x20 Tires || SATOSHI Grill || URD TCAI || Flowmaster 40 series dual exhaust || Pioneer AVIC-D3 w/ Bluetooth and Ipod || JL Audio 500/1 and 12" Kicker Sub || FJ 60 Toyota Emblem Painted Red || Black Custom Leather Interior w/graphite perforated body w/Red Double Stiching and TRD Logo || Leather Arm Rest Mod || T-REX Angry Eyelids || 20% Tinted Windows || Black Altezza Taillights || BHLM Headlights || LED Dome Light || LED Map Lights || HID 35w 6000k || Yellow Tinted Fogs || Nokya 2500k_55w Fog Lights || Painted Engine Cover || Bed Extender || Epic Indust. Bed Bar w/Fog Lamps Tinted Yellow ||
