How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Jul 23, 2018 at 7:23 AM
    #1141
    bren5279
    bren5279 Well-Known Member
    Brendon
    new bern NC
    2012 Black Tacoma TRD Long Travel Supercharged
    TRD Supercharger Dirt King 14" Long Travel Kit Pro Comp 6" lift Fox dual rate 2.5" remote res front coil carriers Fox triple bypass 2.5" remote res front shocks Fox 12" 2.5" Remote Res. Shocks DSC adjusters (flutter shim stacks) ARB Lockers F+R 4.88 Regear F+R Shackle flip kit Bamf tall shock mount Demello Offroad Front Bumper Smittybilt Winchs F+R Method beadlock 17x9 Rims 37" Open country R/T tires Baja fiberglass Front Fenders Baja Fiberglass Rear Fenders Bulletproof Fab Front Grill Air Intake Reroute High Lift Jack Pro Comp Skid Plate KB Voodo Short Bed Rack CVT Cascadia Rooftop Tent
    Oh well I just did a full transmission and torque converter swap too so everything is pretty well drained
    I was thinking about how it kind of gets some resistance when the axles attached, wasn’t sure how that affected it
  2. Jul 23, 2018 at 9:57 AM
    #1142
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Don’t shift through the gears without the driveline in place. The gears stay moving without a driveline/brakes to stop them and will grind when you switch from forward to reverse or vice versa. It will also chew up the parking pawl going from drive or reverse to park.
    @bren5279
    MolonLabeTaco, TenBeers and bren5279 like this.
  3. Jul 23, 2018 at 10:08 AM
    #1143
    bren5279
    Brendon
    new bern NC
    Awesome good to know exactly what I thought might be the case. Thanks!
    07 sport 4x4[QUOTED] likes this.
  4. Jul 23, 2018 at 11:19 AM
    #1144
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    good call!
  5. Jul 23, 2018 at 11:20 AM
    #1145
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    sorry for the mis-information!
  6. Aug 10, 2018 at 5:44 PM
    #1146
    irish_11
    irish_11 Well-Known Member
    Everett, WA
    2011 DCSB
    Just keep throwin' money at it.
    Performed this tonight. Thank you for the write up.
    I messed up though and shut off the truck when I went to check the fluid. I drained out just under 3quarts. I added in the extra 1/3 quart and when I opened the plug nothing came out. So I added more. Now I am wondering if I might have overfilled the trans since it was not idling at the time. I added in an extra quart and nothing has come out yet. Should I drain more out at this point? I am letting it cool down to run the check again.
  7. Aug 10, 2018 at 5:54 PM
    #1147
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    It doesn’t matter if you over filled a bit. The purpose of the check procedure is to assure you have the correct level. Follow the directions, check it when the temp is correct and the excess will trickle out.
    If nothing comes out, you need to add more and repeat the check.
    nach73 and irish_11[QUOTED] like this.
  8. Aug 10, 2018 at 7:39 PM
    #1148
    irish_11
    Everett, WA
    2011 DCSB
    Thanks. Let it cool down a bit and ran through the process again. Temp light went solid, kept it running and removed the fill plug and nothing came out. Turned it off, and added more. I took out around 3 quarts and so far I have 5 quarts in with nothing dripping out. Seems like a lot of fluid compared to what came out.
  9. Aug 10, 2018 at 8:15 PM
    #1149
    bigfoote13
    bigfoote13 Well-Known Member
    Joe
    South Florida
    15 TRD SPORT
    2016 Sport suspension 1/2 spacer up front and aal in rear SCS Stealth 6 17 inch wheels Wildpeak AT3 265 70 17
    Are you sure your pulling the overflow to check and not the drain? You should get apx 3qts out the drain not the overflow.
    There are 3 holes. Fill, check(overflow), and drain.
    irish_11[QUOTED] likes this.
  10. Aug 10, 2018 at 8:52 PM
    #1150
    irish_11
    Everett, WA
    2011 DCSB
    Its been a long week. I was checking the fill like a diff and not the overflow. This makes WAY more sense now. Thank you.
  11. Aug 11, 2018 at 12:08 AM
    #1151
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Glad to help. This is on my short list to do this weekend also.
  12. Aug 11, 2018 at 5:31 AM
    #1152
    spitdog
    It is always a good idea to keep track of exactly how many qts.and ounces you take out and put back in.
    You either need to make or buy a graduated container.
  13. Aug 11, 2018 at 7:04 AM
    #1153
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Keep track, yes, but not to do the check, verify level - no guarantee it was filled correctly to start
    Loco38SUP likes this.
  14. Aug 22, 2018 at 11:20 AM
    #1154
    knightsofni
    knightsofni Member
    2010 Tacoma ext SR5 4x4
    I hope someone can advise me.
    I tried many times to get my truck in trans temp mode and the trans temp light came on and stayed on, no flash
    Could it be I am already up to temp?
    I am confused also because I'm seeing 2 different temp ranges on this forum.
    Do you know which one applies to a 2010?
    Thanks everyone
    Regards
    Knights
  15. Aug 22, 2018 at 11:26 AM
    #1155
    taco2010trd
    taco2010trd Cyber Bully
    Tampa, Florida
    2010 Silver TRD OR DCSB
    Read the directions on page 1, there is also a video. It is not difficult to do.
    Here is a snip from page 1:
    Several of the dash warning lights will begin to flash (normal). Then shifting from "P" to "N" (pausing briefly in "N"), began a series (six shifts) of "N" to "D" to "N" cycles with the shifter. After the 6 shifts are completed the red AT TEMP light should illuminate for 2 seconds (important to note). Place the AT back into "P" (light will illuminate again for 2 seconds) and let the truck idle to warm the fluid. It is important to note that the light illuminated for two seconds as that verifies that the truck entered "Temp Check Mode". Without this verification, you may wait all day for a light to illuminate without the truck actually being in mode.
    When the AT TEMP light illuminates constantly, the fluid is at the correct temperature for checking. If the AT TEMP light should begin to start blinking, this means the fluid temp has surpassed the allowable range and you must shut off the truck and let the system cool. Retry again after a 1/2 hour break.
  16. Aug 22, 2018 at 1:05 PM
    #1156
    knightsofni
    knightsofni Member
    Thanks for your reply
    I did read the first post and this whole thread
    I also watched the video .
    Every time I've tried it, the trans light comes on and stays on.
    Regards
    Knights
  17. Aug 22, 2018 at 1:09 PM
    #1157
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    Fluid temperature is too hot. Let cool several hours maybe over night and try again.
    -RJM
    taco2010trd likes this.
  18. Aug 22, 2018 at 1:14 PM
    #1158
    knightsofni
    knightsofni Member
    Thanks
    That's what I suspected, I really didn't think it ran that long.
    Must be because of the heat in the garage.
    Thanks for replying
    Knights
  19. Aug 26, 2018 at 6:03 AM
    #1159
    bigfoote13
    Joe
    South Florida
    15 TRD SPORT
    Quick question(4.0 5 speed auto) I wanted to check my trans level so last night I put in an extra quart and this morning I got out an extra quart. I didn't take the truck for a ride after I put the quart in it but I idled and shifted the gears. My question is does the tranny fluid circulate without the truck actually moving or did I just remove what I put in the pan?
  20. Aug 26, 2018 at 6:12 AM
    #1160
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Yes, as soon as the engine starts it is pumping fluid.
    DoorDing likes this.
