How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Dec 24, 2010 at 7:36 AM
    #121
    T0y0ta05
    T0y0ta05 Well-Known Member
    Pennsylvania
    05 Silver Sport DC Tacoma
    Bone stock other than new floor mats.
    Actually, I only have 57K on the odometer so I suspect that's right on par with the revised interval of 60K for the transmission change I saw on this thread. :) I never towed anything or off-road so I expect it to be relatively clean, but may be surprised either way. Like others though, I always thought changing the transmission fluid lead to problems before long and typically shyed away from it. However, I'm curious if nothing else to see what it looks like compared to the new fluid.
  2. Dec 24, 2010 at 7:40 AM
    #122
    T0y0ta05
    Pennsylvania
    That crossed my mine as well, but doesn't make sense if it leads to transmission problems down the road that result in pay outs by the factory warranty. I realize it's a numbers game either way and figure that it's perfectly OK (functionality/etc) to be down a quart or Toyota would otherwise fill it to the brim.
  3. Dec 24, 2010 at 10:35 AM
    #123
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    As I understand it - a trans flush-exchange is what to avoid as it stirs and loosens up crap which then clogs valves. A drain and fill is preferred as it does not loosen up any debris and add fresh additives. I would rather be safe then sorry so I would go for 30,000 but 60 is a lot better then 90 or 120.
  4. Dec 24, 2010 at 9:23 PM
    #124
    T0y0ta05
    Pennsylvania
    That makes sense, but there may still be a risk even if it's small.
  5. Dec 25, 2010 at 8:10 PM
    #125
    jimlindenfelser
    jimlindenfelser Active Member
    Jim
    Greenacres, WA
    05 DCab TRD
    Just read through the factory manaul I downloaded off TTORA and it appears to have this exact procedure in it. Just without the helpfull pictures and video. It tells you which terminals to jumper on the OBD and to allow 1.5 seconds in between shifts while doing the 6 shifts between N to D. Thanks for the pictures, video, and extra detail.
  6. Dec 26, 2010 at 5:08 AM
    #126
    T0y0ta05
    Pennsylvania
    Got a link? Or even better which page in the manual?
  7. Dec 27, 2010 at 10:04 AM
    #127
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    The Toyota manual is 95% correct. If you read a little more closely, the manual describes the "D" (drive) indicator will illuminate when the correct temperature is reached. In actual fact however, the "AT TEMP" light will illuminate - rather than the "D" (as described in the manual).
    TacomaCZman likes this.
  8. Dec 27, 2010 at 4:56 PM
    #128
    jimlindenfelser
    Jim
    Greenacres, WA
    05 DCab TRD
    Thanks for the clarification. So Toyota recommends a flush at 60K. Now does that mean a complete flush of the system are just what you describe above? I am 62K. I did see a how-to on how to completely flush the entire system but I am not up for that now. But I did go ahead and buy the oil for the process you describe.
  9. Dec 27, 2010 at 5:03 PM
    #129
    jimlindenfelser
    Jim
    Greenacres, WA
    05 DCab TRD
  10. Dec 27, 2010 at 5:43 PM
    #130
    Fortech
    CANADA
    I don't know if those links will last very long. Every time I posted links to the FSM I got a slap on the wrist from the site admin/mods - hence why there is no reference to them in the write up.
    Allot of dealerships don't even own a flush machine, therefore I suspect a drain and fill will suffice.
  11. Dec 29, 2010 at 7:31 PM
    #131
    sardog2111
    sardog2111 Well-Known Member
    AL
    05 silver streak DC, 5100, borla exhuast
    5100's, Volant Intake, Borla Exhaust. FJ wheels, Wet Okole's. HID's, Go Rhino Steps bars.
    great write up, did it today, so far so good followed the directions to the T and took about an hour. Thanks my tranny is much happier.
  12. Jan 1, 2011 at 4:10 PM
    #132
    jimmyzshack
    jimmyzshack Well-Known Member
    Houma, LA
    06 PreRunner
    leveled
    I saw someone post earlier that their 06 prerunner had a AT TEMP light. mine doesn't when i tried it today
  13. Jan 1, 2011 at 5:31 PM
    #133
    sardog2111
    AL
    make sure that you jump the right ports on your OBD II and when you do it, you need to do it kinda quick it does not light up when you turn your key on, only when you enter the temp mode, it took me 2 times to get it to work because i went to slow the first time.
  14. Jan 2, 2011 at 10:19 AM
    #134
    frieb
    frieb Member
    Ed
    Redwood City, CA
    2013 4WD TRD
    Just checked my 2wd auto - AT TEMP does not illuminate when the key is turned to the ON position.
  15. Jan 2, 2011 at 5:38 PM
    #135
    sardog2111
    AL
    nor will it, you need to put the truck into temp mode for it to light up, you will not see it by just turning the key on. It only comes on with the ports jumped, and your in temp mode.
  16. Jan 8, 2011 at 6:55 PM
    #136
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    what a great piece of information, Planning on doing mine really soon. Atleast I know it will get down I don't trust dealers anymore. What about the filter anyone drop there pan to see what is inside for a filter???? Couldn't hurt to clean the pan and magnet off in there either
  17. Jan 9, 2011 at 10:36 AM
    #137
    johnny 5
    wisconsin
    Most useful info I have found in this truck!!!! I have been looking for years on how to figure this procedure out for the trans. THANKYOU
  18. Jan 10, 2011 at 8:39 AM
    #138
    frieb
    frieb Member
    Ed
    Redwood City, CA
    2013 4WD TRD
    I changed the oil in my 06 2WD Tacoma TRD this weekend, the instructions were perfect
  19. Jan 12, 2011 at 9:32 PM
    #139
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    couldn't have been explained better.. thanks!!!
  20. Jan 14, 2011 at 8:03 PM
    #140
    johnny 5
    wisconsin
    Well I finially got my ws fluid and crushwashers from TOYOTA. Bought a case of fluid at $8.00 qt The whole procedure went fine until I removed the fill plug on the side of the trans and the threads came out with the plug. OH shit now what? Anyone else have this happen??? Only thing I can think of is to get it HELIcoiled hopefully with the trans in the truck. Aluminum threads and aluminum plug BAD idea.
