How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Jan 15, 2011 at 8:18 AM
    #141
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    If you can't heli-coil it yourself and you've already drained the trans I would suggest getting one of those universal expanding rubber plugs. They are typically only 1/2" or so at auto parts stores but you can get all different sizes at marine places. It's certainly not a permanent fix but should be fine to get the truck to someone who can heli-coil it for you. Another reminder whenever draining a component on a vehicle. ALWAYS REMOVE THE FILL PLUG FIRST! Then if you run into trouble you can stop.
    That said I still need to do this on mine. 116k now and no record of any transmission service from Toyota. Shifts perfect though. Although usually when you notice shifting problems it's a larger issue than a fluid drain/top off will fix.
    TacomaCZman likes this.
  2. Jan 15, 2011 at 8:35 AM
    #142
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Hardware store and or plumbing supply should have rubber plugs if you don't find them at auto store. Good idea 85GT
  3. Jan 19, 2011 at 8:29 PM
    #143
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
  4. Jan 20, 2011 at 5:53 AM
    #144
    SurfnWolf
    SurfnWolf Well-Known Member
    Fayetteville NC
    2006 Tacoma Prerunner Double Cab
    Printed off a data sheet, that said for the 2 wheel drive prerunners the indicator light would be the "D" indicator light. I assume that meant the "D"rive light ? not really sure, I took mine to a friend who used a temp gun, and we changed the rear trans seal that was leaking and drain and fill trans fluid. Easy job, only surprise I saw was when changing the seal, you had to take down the whole drive train...from Transmission to carrier bearing to real axle. Easy job though.
  5. Jan 21, 2011 at 9:12 AM
    #145
    jimmyzshack
    jimmyzshack Well-Known Member
    Houma, LA
    06 PreRunner
    leveled
    So guys that have raised the front to lvl your truck how are you leveling truck back to normal to this?
  6. Jan 22, 2011 at 3:49 PM
    #146
    johnny 5
    johnny 5 Well-Known Member
    wisconsin
    Black 07 TRD Off road 4x4
    7-6'' sno-way plow w/DP
    yeah good question the trans does not sit level in the truck so should you level the trans with a level then fill it or WHAT!!!!! With truck on groung trans is not level.
  7. Jan 27, 2011 at 5:20 PM
    #147
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
  8. Feb 20, 2011 at 5:28 PM
    #148
    reneval
    reneval New Member
    4x4 sr5
    ..Hi, i got a question hopefullyu can help me. I have to replace the transmission on my tacoma, i crash and transmission fluid spilled out, burned. Do i fill the converter first and then bolt it on? or filled when installed? How many quarts? I got the info to check level from your thread, but im not sure if i have to fill converter before or after install. Thank you!!! very much for your help
  9. Feb 22, 2011 at 10:56 PM
    #149
    pinktaco808
    pinktaco808 Hot Steppa
    how you get of the check mode???
  10. Feb 24, 2011 at 5:49 AM
    #150
    pinktaco808
  11. Feb 24, 2011 at 10:45 PM
    #151
    pinktaco808
    how i get it out of check mode, any particular way
  12. Feb 25, 2011 at 6:07 PM
    #152
    Fortech
    Fortech [OP] Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    Pull the jumper, shut off the engine - your choice.
  13. Feb 26, 2011 at 11:47 AM
    #153
    pinktaco808
    it that easy thanks. what about changing the filter???
  14. Feb 26, 2011 at 12:47 PM
    #154
    pr3moTRD
    pr3moTRD Member
    buddy
    az
    08 pr3runner
    so i did my drain and i got the light to come on but i turned my truck off on accident.. and cant seem to get the light to come back on.. what do i need to do now help!! disconnect the battery?? any suggestions
  15. Feb 26, 2011 at 1:34 PM
    #155
    pinktaco808
    waite a while and do the whole process again
  16. Feb 26, 2011 at 2:57 PM
    #156
    pr3moTRD
    pr3moTRD Member
    buddy
    az
    08 pr3runner
    sweet ill give it a go tonight after work.....
  17. Feb 26, 2011 at 7:43 PM
    #157
    pr3moTRD
    pr3moTRD Member
    buddy
    az
    08 pr3runner
    alright on my 08 2wd taco there is indeed a light.. with that being said i got it to get in temp mode..it came to a steady light so i then went ahead and unscrewed the 5mm bolt. now after i did that a little drip fell out?? does this mean that its leveled???
  18. Feb 26, 2011 at 8:35 PM
    #158
    pr3moTRD
    pr3moTRD Member
    buddy
    az
    08 pr3runner
    YUP!! got it thanks
  19. Feb 28, 2011 at 1:39 PM
    #159
    pinktaco808
    what the part number for the tranny filter???
  20. Mar 5, 2011 at 5:26 PM
    #160
    jlhuck
    jlhuck New Member
    Joe
    N Idaho
    2010 Tacoma TRD Off-Road
    TRD Catback Exhaust, Tow Package
    so i live 3 hrs from my nearest dealer. preferring to order and ship, i tried the link to find the fluid from toyotapartsales.com and while they have it listed, i can't seem to purchase at this time. just curious if there were any other sites to get the fluid and crush washers???
