How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Oct 15, 2020 at 9:21 PM
    #1641
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    The temp gun at the pan method really needs to be dropped entirely because the OBD method is the accurate way and therefore the only way.
    Not sure why people are so hung up about jumping the OBD wires.
  2. Oct 18, 2020 at 10:10 AM
    #1642
    BlackTaco22
    BlackTaco22 Member
    2009 Black Toyota Tacoma Prerunner - TRD Sport Package - SR5
    Bilstein 5100 Adjustable Shocks with Toytec coil springs (2.5 inch lift Front) - Bilstein 5100's rear - 265/70/R17 Goodyear Wrangler Duractrac's
    Wow, Fortech! Awesome write-up! I have a 2009 Taco Prerunner 2WD - AT (TRD Sport/SR5). I just replaced the output shaft seal with the updated/new seal as I had slight leaking of tranny fluid out of the output shaft. The new seal that Toyota released is a double lip seal. Way better than the original seal! I don't think I lost a ton of tranny fluid, but will be checking the level in the next day or so. I will report back on whether my AT Temp gauge lights up or not doing this procedure of jumping the OD diagnostics. Hopefully it does!
    I have read that some people add an additional 0.1 to 0.4 quarts of WS tranny fluid after allowing the tranny fluid to come to a slow trickle out of the overflow tube. Meaning, the fluid level is checked, the overflow tube is closed back up after slowing to a trickle, and then an additional 0.1 to 0.4 quarts of fluid are added back into the system. Is anyone doing this?? And is it completely necessary? I read through many comments, but couldn't get through them all!
    Thanks in advance
  3. Oct 18, 2020 at 11:22 AM
    #1643
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    there are several guys on tundra world that have added 1/2 quart extra with no ill effect. Some reported better shifts. I know John over at IPT trans even said he adds extra fluid after a valve body rebuilds cause he feels like the factory level is a little low.
    BlackTaco22[QUOTED] likes this.
  4. Oct 25, 2020 at 3:05 PM
    #1644
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Is it still a potato if I spell it potatoe or tomato tomatoe? An a750 is an a750 bottom line. Take the transfer case off an a750f and replace with a tail shaft, you've got an a750e. Remove the tail shaft on a a750e and replace with a transfer case, now you've got an a750f.
    The only variable that would cause a change in fluid capacity and temperature would be the presence of a tow package which adds the external atf cooler which is just below the AC condenser mounted to the core support.
    https://shop.ukrtrans.biz/wp-content/uploads/catalogs/A750E.pdf
    SR-71A and spitdog[QUOTED] like this.
  5. Oct 26, 2020 at 9:11 AM
    #1645
    Elikk
    Elikk Well-Known Member
    Eli
    Tacoma Trd sport crew cab 2011
    Finally got around to do the filter and the flush, happy I took of the pan to clean the magnets, the filter had filth on it not sure what it is but probably the same crap that the magnets accumulated?Using the sprayer method rly made this easier, the old fluid other than the residue looked pretty good, completed the flush with 13 liters of atf.
    The weather is getting cold here in North Vancouver so it took forever to get up to temp at 3 celsius, I think like 30 +min, ended up overfilling it so around 700ml came out the level check hole. Thanks everyone who posted tips and suggestion how to do this easier !
    NAAC3TACO and SR-71A like this.
  6. Oct 26, 2020 at 12:39 PM
    #1646
    BlackTaco22
    BlackTaco22 Member
    I just checked on my 2009 Tacoma pre-runner 4.0 L 2WD AT And it does in fact have an AT temp check light on the dash. The first time I tried getting it into temp check mode, it didn’t work. I think I was cycling through neutral and drive to slowly maybe? I tried it again and sped it up slightly and it worked perfectly.
  7. Oct 27, 2020 at 2:38 PM
    #1647
    RocyTaco
    RocyTaco Active Member
    Greg
    Tacoma Access Cab 4x4 2006 4L AT
    I added an extra 1/2 Qt of fluid after determining the nominal level in my 2006 4L V6. After I drove the truck (initially with the spec ATF level). The trans did not shift as well as before. Especially reverse (from a cold start); it felt like I had the brakes on. I then added a 1/2 Qt WS (above nominal) and the problems evaporated. With all that said, more ATF than specified risks a number of problems: poor lubrication, foaming, overheating etc. Some here have reported problems with just slightly more than spec so beware. I have been fine for 500 miles now of city and highway driving since my flush. A benefit of a little extra is that you can check it later and there is a reservoir of fluid to test with. Imagine you suspect a leak but everything is OK. The pan 0.1% low (i.e. everything is fine) but you don't know because nothing came out after opening the check port. In that case you would have to add fluid just to see that everything is fine. A little extra in there lets you check it later without the hassle.
  8. Oct 31, 2020 at 8:23 PM
    #1648
    arehman11
    arehman11 Active Member
    2009 Tacoma DCSB TRD Off Road
    Did this today, worked perfectly, no issues with getting into temp checked mode.
    NAAC3TACO and TacomaCZman like this.
  9. Nov 2, 2020 at 4:11 AM
    #1649
    arehman11
    So I just realized that I didn’t circulate the fluid through the tranny before putting it in temp check mode, how critical is this? I did on the first and second drain and fill, but did not on the final one.
  10. Nov 2, 2020 at 4:31 AM
    #1650
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I wouldn't worry about it. It circulated for a bit while waiting for the proper check temp
    arehman11[QUOTED] likes this.
  11. Nov 12, 2020 at 8:59 AM
    #1651
    TDG6701
    TDG6701 Member
    Followed this procedure on my 2015 Prerunned with transmission cooler. Put a strap on temp prob on cooler line at bottom of transmisson. During the test when the temp light came on the line temp read 100 F and when the light started to blink it read 115.5 degrees. So reading the temp on the outside is 15 degrees below internal oil temp. Also the two gaskets listed for the transmission are for drain and overflow plug The fill plug takes an o ring that is special order thru dealer. Also 15 ft lbs torque is enough for an o ring In fact 15 ft lbs is fine for all three (no leaks) Sincerely Tim
    Amo-cat3 likes this.
  12. Nov 12, 2020 at 9:42 AM
    #1652
    TDG6701
    TDG6701 Member
  13. Nov 12, 2020 at 9:51 AM
    #1653
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    A tip. Instead of a wire to jump OBDII pins #4 and #13, use a metal paper clip.
    It slips right into the OBD with a nice solid engagement. Also, you can avoid hunting for a small enough wire to fit.
    SR-71A likes this.
  14. Nov 12, 2020 at 9:55 AM
    #1654
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @TDG6701 good info. Do you have the PN# for that o-ring that is a dealer only item?
  15. Nov 12, 2020 at 10:03 AM
    #1655
    TDG6701
    TDG6701 Member
    Did not replace the 0 ring it was in good shape. I did replace the other seals. Did this drain and fill twice at 30000 and now 60000 as most of these miles i was towing a camper.
    SUMOTNK likes this.
  16. Nov 25, 2020 at 8:58 AM
    #1656
    gearcruncher
    Canadain bumper technician
    Just another heads up .
    Your engine must be running while you have the overflow plug removed for level check .
    I know the author has this part of the procedure highlighted on the first page , but it needs more attention as guys are accidently skipping this part of the procedure .
    ImpulseRed008, SUMOTNK and SR-71A like this.
  17. Nov 25, 2020 at 9:09 AM
    #1657
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Funny how many threads on here where people dont read this first page
    gearcruncher[QUOTED] likes this.
  18. Nov 25, 2020 at 9:16 AM
    #1658
    Knute
    Not 100% sure, but I suspect the tranny will "suspend" fluid in the channels and Tq converter while idling.
    I won't state how my suspicion came about.....lets just say I did something not too bright.....and leave it at that. :der: :smack:
  19. Nov 25, 2020 at 9:23 AM
    #1659
    gearcruncher
    You are correct .
    When the truck is at idle , the transmission pump is pumping and charges the torque converter and hydraulic circuits with pressurized fluid .
    When the truck is turned off the transmission pump stops turning and that pressurized fluid drains back into the pan . If you pull the check fluid plug at this time , all that fluid that was charging the torque converter and hydraulic circuits is going to drain out . You will be at very minumum 3 to 4 quarts low
    NAAC3TACO likes this.
  20. Nov 25, 2020 at 9:36 AM
    #1660
    Knute
    ahhh......my suspicion confirmed.
    Yep, I used my stupid pill prescription.
    gearcruncher and SR-71A like this.
