How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Dec 10, 2020 at 6:16 AM
    #1661
    crocket1973
    crocket1973 New Member
    2013 Tacoma TRD Sport
    HI All,
    First post. Great Forum.
    I have a question regarding the procedure for the AT Temp.
    I can get the AT Temp light to come on for 2 seconds after the N-D procedure, but when I put the gear selector back to park the AT Temp light does not come on again for 2 seconds. I am able to consistently reapeat this without the light coming on for a second time when put into park. Any thoughts?
    Thanks
    Dave
  2. Dec 10, 2020 at 7:16 AM
    #1662
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Mine does the same thing. There has been some discussion that perhaps the '12-'15 don't. It's never failed to be in temp check mode for me though
  3. Dec 10, 2020 at 7:20 AM
    #1663
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    After the N-D sequence the A/T will light to indicate the system is active. Place tranny into P, the light will go off. Wait. Let the truck idle. The next time the A/T lights, then do the fluid level check. Remember, leave the truck in P, idling and E-brake applied.
    If the A/T light begins to blink, after placing in P, then the fluid has gone over the check temperature. Shut off the truck, try again in 2 hours.
    SR-71A likes this.
  4. Dec 10, 2020 at 7:22 AM
    #1664
    Plain Jane Taco
    USA
    Seems as though many of us with '12+ don't get the 2nd A/T light when placing it in park. I never have....and I've done 5 successful DAFs over the last 3 years or so
    SR-71A likes this.
  5. Dec 10, 2020 at 7:45 AM
    #1665
    Knute
    My '06 didn't give the 2nd A/T light when placed into P. Really, had me wondering if the system was ON or functioning. So, I just decided to sit in the Driver's seat and wait.....listened to the radio.....waited....after about 15 minutes the A/T light started to flicker...... A minute or 2 later, the A/T light went ON solid. Time to check fluid level.
    SR-71A likes this.
  6. Dec 10, 2020 at 12:15 PM
    #1666
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    And while it's likely been mentioned before in this 84 page thread, as soon as you get into temp check mode - remove the jumper wire if that's your approach.
    Leaving it in can cause squirrely FI behavior as per one smart tech on the t4r.org forum.
    SR-71A and Plain Jane Taco like this.
  7. Dec 10, 2020 at 3:21 PM
    #1667
    Plain Jane Taco
    USA
    Now that's something I've never done. Obviously it will stay in check mode with it out? Never had an issue with it.....and the 1st I've heard of it
  8. Dec 10, 2020 at 3:28 PM
    #1668
    Lester Lugnut
    Yes - it stays in temp check mode when you pull the jumper as long as you have actually entered temp check mode B4 pulling the jumper.
    A long-time Toyota tech over on t4r.org who goes by BlackWorksInc mentioned this in a tranny fluid tread on the 5th Gen 4R forum. 2nd Gen Tacoma's and 5th Gen 4Rs use same transmission - A750E(2WD) or A750F(4WD).
  9. Dec 10, 2020 at 4:17 PM
    #1669
    crocket1973
    Thanks for the reply. I decided to try it even though the second light didnt come on. I waited 20 minutes and then the light came on. I waited some more and then it started blinking, indicating it had exceeded checking temperature. It looks like it is working like it should, and I will go ahead with the DAF.
  10. Dec 10, 2020 at 4:38 PM
    #1670
    Plain Jane Taco
    USA
    If you ever do it on a really cold day....it can take awhile. I waited 45 minutes once because I decided that a 15° day would be a lovely time to do a tranny DAF.
    :facepalm:
    ToxicTwin likes this.
  11. Dec 10, 2020 at 5:47 PM
    #1671
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    :smack:
  12. Dec 27, 2020 at 8:25 PM
    #1672
    Flash77
    Flash77 Member
    08 Tacoma
    08 Taco, TRD Pro wheels, Bilstein 5100’s, K&N CIA, Anzo projections
    Do you still have to go through the complete temp check sequence if you are just topping off? I just had one of my trans cooler hose clamps go and I lost probably 1/2 qt. I need to top it off.
    Plain Jane Taco likes this.
  13. Dec 27, 2020 at 8:26 PM
    #1673
    Plain Jane Taco
    USA
    I would if it were mine
    SR-71A likes this.
  14. Dec 27, 2020 at 8:28 PM
    #1674
    gearcruncher
    Canadain bumper technician
    Yes sir .
    Even if you are simply checking the fluid level , you are supposed to follow the procedure .
  15. Dec 27, 2020 at 8:41 PM
    #1675
    Flash77
    Flash77 Member
    08 Tacoma
    Probably a dumb question but when you jump slots 4 and 13 on the OBD you don’t leave them in there correct? Just contact the wire into both and then remove?
  16. Dec 28, 2020 at 7:08 AM
    #1676
    Knute
    I left the jumper installed between 4 and 13 for the entire procedure until I shut off the engine.
    My "jumper" was a custom formed metal paper clip.
  17. Dec 28, 2020 at 7:31 AM
    #1677
    Flash77
    Flash77 Member
    08 Tacoma
    Ok ty, The paper clips a good idea to! I just walked down to advance auto and they don’t even have ATF WS fluid. I don’t really wanna drive it till I check everything. Appreciate the help guys
  18. Dec 28, 2020 at 7:38 AM
    #1678
    Knute
    I'll bet they do. Look at Valvoline MaxLife. Turn the bottle over and read the label on the back. You will see its compatible with WS.
    SR-71A likes this.
  19. Dec 28, 2020 at 9:03 AM
    #1679
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    I've done this a couple times on my '14 and the light will come on and stay on when it is warm enough. You have to wait.
    I have left the jumper in during the whole procedure but it does make the engine run for shit. Makes me work faster because I don't like hearing it run like that.
  20. Dec 28, 2020 at 9:14 AM
    #1680
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    So its not just me!! I did this last week to practice temp check mode before I actually do a drain/fill. Noticed it definitely sounded off when I started the truck. Was worried I got the wrong pins and jacked something up haha
