How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Dec 28, 2020 at 9:37 AM
    #1681
    seedy_tea
    seedy_tea Well-Known Member
    chris
    Cape Cod
    2009 TRD-OR DC
    you can take the jumper out once you're in check mode and it will run normally. stays in check mode until truck is turned off.
    SR-71A[QUOTED] and spitdog like this.
  2. Dec 28, 2020 at 9:38 AM
    #1682
    seedy_tea
    chris
    Cape Cod
    2009 TRD-OR DC
    stick the wire into each hole, turn on the truck, do the procedure, then you can remove the jumper if you choose.
  3. Jan 15, 2021 at 8:40 AM
    #1683
    ArizonaComa
    ArizonaComa Well-Known Member
    Erik
    AZ
    2007 Impulse Red ACLB TRD
    285 K02s, Bilsteins, and a GoFastCamper
    Great write-up, and tips mentioned by others.
    I will plan to perform this drain & fill task on my 2007 with 148k miles very soon.
    Anything I should keep in mind other than the tips and comments already mentioned by others?
    Should I take a peek at my filter, or just keep to the pan magnets?
    I would also like to note: I cannot confirm if my ATF fluid has been changed before. Will have to refer to my maintenance records from previous owner.
    If there is no record of previous change, I plan to perform this drain & fill a few times, perhaps at 30k intervals.
  4. Jan 15, 2021 at 9:02 AM
    #1684
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    You have to remove the pan to get to both, so in makes sense to do both.
    ArizonaComa[QUOTED] likes this.
  5. Jan 15, 2021 at 9:04 AM
    #1685
    ArizonaComa
    Erik
    AZ
    Ah, that's true! My brain isn't working too well this morning I suppose.
  6. Jan 27, 2021 at 5:12 PM
    #1686
    badweatherbiker
    badweatherbiker Well-Known Member
    North Florida
    2011 blue Tacoma crew cab 4.0 TRD off road
    so this procedure would basically be the same if I were dropping the pan and replacing the screen, I would just be adding a little more fluid? should I replace my pan bolts? there is no local Toyota dealership so big box screen and gaskets should be good? My trans fluid was changed at 40,000 miles by jiffy lube and it now has 109,000 miles so its def due.
  7. Jan 27, 2021 at 5:19 PM
    #1687
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Yep....and I see no reason to replace the pan bolts
  8. Jan 31, 2021 at 1:06 PM
    #1688
    badweatherbiker
    North Florida
    So what do we do if we don't have an at temp light?
  9. Jan 31, 2021 at 1:07 PM
    #1689
    Plain Jane Taco
    USA
    Then you don't have an automatic
  10. Jan 31, 2021 at 1:17 PM
    #1690
    badweatherbiker
    North Florida
    Yes I have an auto, light never lights up
  11. Jan 31, 2021 at 1:45 PM
    #1691
    badweatherbiker
    North Florida
    Added a squirt of atf fluid and put it all up for today, no AT temp light when I start my truck or when I jump the wire and shift 6 times between N and D. I even let it idle for 20 mins, stupid design...
  12. Jan 31, 2021 at 5:57 PM
    #1692
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    If it was chilly out, might take longer than 20 minutes to get up to temp
  13. Jan 31, 2021 at 6:14 PM
    #1693
    badweatherbiker
    North Florida
    Made it to 73 here in Florida today even with the rain, main problem is I never see the AT temp light. It doesn't even come on for 2 seconds when I jump the OBD2.
  14. Jan 31, 2021 at 6:43 PM
    #1694
    badweatherbiker
    North Florida
    Does anyone know if the temperature can be read by a scan tool? I have the BAFX bluetooth scanner and Torque lite already but it's not on there, if I buy and download Torque pro will I be able to read the transmission temp?
  15. Jan 31, 2021 at 7:24 PM
    #1695
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Something isn't right with the initialization of the A/T check sequence.
    Verify you are jumping the correct pins in the OBD port. IIRC, its pins #4 and #13. This should cause the dashboard to go "crazy" with lights.
    Then follow the sequence.
    Remember, the shifts are each counted......N to D =1, D to N=2........so on and so forth. Note: the A/T may not light after this shift sequence.
  16. Jan 31, 2021 at 7:26 PM
    #1696
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Yes temps can be read, i have the ultragauge.
    Not sure on the torque pro
  17. Jan 31, 2021 at 7:42 PM
    #1697
    badweatherbiker
    North Florida
    Followed this exact sequence, got the funky lights but no AT light. Ill try again tomorrow
  18. Jan 31, 2021 at 7:43 PM
    #1698
    badweatherbiker
    North Florida
    Thanks of I can't get it to work right like the instructions on this thread I'll just buy the Torque pro and use the temp on the OBD2 reading
  19. Jan 31, 2021 at 7:47 PM
    #1699
    Knute
    You may need to wait a bit after you complete the sequence.
    My A/T light did not come on to confirm the sequence. I tried several times. Then I decided to just wait. After about 15 minutes, the A/T began to flicker, then another minute it became solid. I checked fluid level at this point.
  20. Jan 31, 2021 at 7:58 PM
    #1700
    badweatherbiker
    North Florida
    Thanks I'll try it again tomorrow, I did wait 20 mins but maybe it wasn't long enough.
