How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Jul 1, 2021 at 8:38 AM
    #1841
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    No. You can look up a generic max torque per fastener size as well. Personally snug is good for these things cause sometimes books are misprinted
    SR-71A likes this.
  2. Jul 1, 2021 at 8:43 AM
    #1842
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    I’m sure it depends too on the materials involved for both the bolt and what it’s threading into. As well as if there’s an o-ring, crush washer, etc.
  3. Jul 2, 2021 at 12:09 AM
    #1843
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    I don't see any mention of a dipstick feature on the YouCovers A750F pan.
    I was looking at that pan, and was thinking to do two things to it. A) paint it to protect the cast aluminum from corrosion, (they offer a painted version at $70 extra!) B) Epoxy in some magnets or epoxy in a steel plate to add magnets to in the bottom.
  4. Jul 2, 2021 at 7:32 AM
    #1844
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    My bad. I didn't look closely enough at the pan.
    I seem to remember hearing from them a couple of years ago, when they were thinking about and designing this pan. I could have sworn they added a dipstick at the time.
  5. Jul 4, 2021 at 7:57 AM
    #1845
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    I am planning on flushing the tranny this week and wanted to ask opinions on this post. Is there a consensus or factual experience if this is needed: "reset the learned memory after the fluid change"
    "Don't have to open the thermal valve on Tacomas. However if the idle is fluctuating because the jumper wire is still in, the fluid will warm up too fast & you'll end up draining out too much. End result is its under filled. I work at a dealer & have done hundreds of the fluid checks/adjustments. I've seen only 4 in the last 10 years that's actually properly filled. They're all usually low by 1/2 quart or more. It's a good idea to reset the learned memory after the fluid change to relearn the shifting time. Over time the ecu learns to shift slower because the fluid doesn't have the same viscosity. When you put in new fluid, it still shifts slow, & may slip & burn the friction material in the clutch packs."
    My 2013 has the factory transmission cooler.
    Thanks guys!
  6. Jul 4, 2021 at 8:00 AM
    #1846
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    IMHO...you are succumbing to an internet mythconception.
  7. Jul 4, 2021 at 8:31 AM
    #1847
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    What’s the source of the quote?
    SR-71A likes this.
  8. Jul 4, 2021 at 9:15 AM
    #1848
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I pull the jumper wire (I actually have an adapter, not a wire) once it's in temp check mode. The idle does even out a little compared to leaving it in. Does that actually effect anything? I don't know.
    I can tell you this....3 years ago I did a level check before doing any DAFs just to see where it was at and to familiarize myself with the procedure. The level was spot on. Sometimes I think this whole "the fluid level is always low from the factory" stuff gets a little overblown on the Internet
    SR-71A and Hook78 like this.
  9. Jul 4, 2021 at 10:51 AM
    #1849
    kwanjangnihm
    Jeff
    Central Florida
    source is a post on this thread many pages back - will try to find it again
  10. Jul 4, 2021 at 11:11 AM
    #1850
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    here
  11. Jul 4, 2021 at 3:44 PM
    #1851
    kwanjangnihm
    Jeff
    Central Florida
  12. Jul 4, 2021 at 8:12 PM
    #1852
    Tacoma1970
    Tacoma1970 New Member
    Carlos
    08 tacoma trd
    Airbags
    I drained and filled my transmission a month ago and 4.5 quarts came out...
    I also installed a transmission cooler and filled it just to prime it..I can say my trans temp has significantly decreased by 30-40 deg. Now on hot days the outside temp has alot to do with cooling.
    I'm towing a 3500 lbs camper and in August I expect temperature to be higher as summer goes.
    I added a mishimoto fan to help with keeping transmission temps down when the towing goes uphills and when truck is not moving at traffic.
    When truck moves it begins cooling the transmission when it's slowing or not moving the temp goes up alot..the fan definitely is a added help..
    Filling the transmission was a pia I used a long hose to fill. I used a funnel . I got the hose to go up to where the windshield washer fluid tank is and had gravity do the job it worked out good . Try not to make a mess.
    I also used a measurement pitcher and made sure it was accurate what I took out and what I'm putting in..
  13. Jul 5, 2021 at 11:01 AM
    #1853
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I bet it only applies to trucks that get the towing package add/on since that adds capacity to the fluid loop. Maybe the person on the assembly line whose job it is to fill the fluids doesn't always pay attention to this fact.
  14. Jul 5, 2021 at 1:55 PM
    #1854
    Plain Jane Taco
    USA
    Mine has the tow package
  15. Jul 5, 2021 at 2:32 PM
    #1855
    Sacrifice
    KS
    DCSB OR 4X4 LT
    Its automated. Machine knows which vehicle is on the line and tge operator just hooks it to vehicle and push a button
  16. Jul 5, 2021 at 6:56 PM
    #1856
    RadicalTaco
    RadicalTaco Well-Known Member
    It's probably about time to do this on mine.
  17. Jul 9, 2021 at 7:12 PM
    #1857
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    Mine had the tranny cooler added at the port and it was over a quart low. It shifted really hard going up hills. I assumed it was properly filled... shifts S O MUCH better when full of fresh fluid to the proper level.
    SR-71A likes this.
  18. Aug 14, 2021 at 1:05 AM
    #1858
    Inko96
    Inko96 New Member
    Daniel
    Des Moines, IA
    2021 Tacoma Limited
    I recently purchased a 2021 Tacoma. Decided I should inspect the transmission to see whether it was low from the factory. I decided I should pull the overflow plug when the transmission was cold and had sat overnight, just to get a baseline of what the level was cold, and when I pulled the overflow plug in the AM 1.5 quarts came out of the overflow plug. I pumped 1.5 quarts back into the transmission, and didn’t bother do anything else because I assumed if 1.5 quarts came out of the overflow plug after it had sat overnight then I wasn’t low on transmission fluid. Am I right in assuming the level is above the filled mark and I don’t have to worry about my transmission being low on fluid?
  19. Aug 14, 2021 at 2:20 AM
    #1859
    kwanjangnihm
    Jeff
    Central Florida
    SR-71A likes this.
  20. Aug 14, 2021 at 3:15 AM
    #1860
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    This is a second gen thread so follow the third gen procedure posted above, but you have to do the check with the engine running or else you will dump a bunch of fluid just as you did.
    SR-71A likes this.
