How to Drain/Refill Automatic Transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fortech, Dec 5, 2009.
  1. Nov 21, 2021 at 8:03 AM
    #1881
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Lets see ..... I use 1 paper clip every 100,000 miles for transmission service.
    I think I will only need about 3 maybe 4 for the life time of the truck.
    Biscuits and Plain Jane Taco like this.
  2. Nov 21, 2021 at 8:05 AM
    #1882
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Biscuits and SR-71A like this.
  3. Nov 21, 2021 at 8:07 AM
    #1883
    Knute
    Guilty.
    I practice the KISS principle in life.
    Plain Jane Taco likes this.
  4. Nov 21, 2021 at 8:15 AM
    #1884
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Does TEMP CHECK MODE use the same temperature measurement method that PIDs in a Bluetooth OBD dongle (or ScanGauge/UltraGauge) use?
  5. Nov 21, 2021 at 8:18 AM
    #1885
    Knute
    Frankly, I don't know. Also, don't care.
    I do know it is the system that Toyota installed on the truck.
    So, it is accurate enough and I can't introduce an error of some sort in the Temperature Check
  6. Nov 21, 2021 at 8:26 AM
    #1886
    2015WhiteOR
    Gainesville TX
    Exactly my point. We know that TEMP CHECK MODE was meant to help with setting the tranny fluid level.
    Using temp guns on the pan, OBD dongles, etc.. might work but might also be entirely wrong. Transmission rebuilds are expensive. Use the freaking temp check mode and do it right.
  7. Nov 21, 2021 at 8:28 AM
    #1887
    Knute
    :thumbsup:
    Accuracy is only based on need.
    Examples.
    A Smart Bomb with a 300 m blast zone that can hit the target within 1 m is insanely accurate. Does it need to be that precise, probably not.
    On the other hand, Laser surgery on your eye an error or 2 mm could result in loss of site. This system must be accurate to the micrometer level.
    Temperature Check Mode accuracy in the transmission probably doesn't need to be within 1 degree, but the accuracy should be within Toyota's supplied onboard system
  8. Nov 22, 2021 at 10:54 AM
    #1888
    shanman
    shanman Member
    2006 Tacoma TRD
    This thread is a bajillion posts long, so I haven't been able to see if someone else has brought it up and answered already, etc. but here goes... My taco has around 270K on it now. I bought it around 100K ago, so it had about 170K when I got it. I'm contemplating changing the tranny fluid. I spoke with the previous owner and he said he changed it at 100K. I assume that was the only fluid change. Is it safe to change the fluid with this history on it? I've heard stories of trannys starting to slip if not changed during its life and then finally changed. Any opinions on my situation?
  9. Nov 22, 2021 at 11:04 AM
    #1889
    2015WhiteOR
    Gainesville TX
    If it works fine, and you want to squeeze another 50k out of it then don't touch a thing.
    But if you are thinking about selling or scrapping it, the mildest thing you could do is a simple drain and fill, which will only replace 1/3 or 1/4 of the entire fluid capacity.
  10. Nov 22, 2021 at 12:08 PM
    #1890
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    understood, there were just so many threads going back and forth for the pan temp on ultragauge, and different input codes for the ultragauge, that ive never been 100% confident that its reading what the actual check temp is.
  11. Nov 22, 2021 at 12:11 PM
    #1891
    ejl923
    Eric
    Western Mass
    Agree, thats how i did it the first time. Its just easier if i can get a direct reading and know where the temp is, rather than waiting for a light. Especially if changing in very cold weather, which i will be doing, just to have an idea if its close or not.
  12. Nov 22, 2021 at 12:12 PM
    #1892
    shanman
    shanman Member
    2006 Tacoma TRD
    I want to keep it and keep the transmission alive as long as possible without a rebuild. So does that still mean doing nothing is still the best option? Would the simple drain and fill most likely increase chances of it slipping in the next few years?
  13. Nov 22, 2021 at 1:23 PM
    #1893
    Knute
    I would suggest to do an enhanced Drain & Fill. Include a pan drop with a filter change. Its just a little bit more effort and the cost of the filter is less than $20. Some will chime in to say the filter can be "cleaned" and reused. IMHO, a used filter can not be thoroughly cleaned and the replacement cost is low. Doesn't make sense to risk a $4K+ tranny on cleaning/reusing a filter to save $20.
    This will give you the opportunity to clean the pan and the magnets and install a fresh, clean filter. Still going to need the same amount of fluid as a Drain & Fill.
    Biscuits and shanman[QUOTED] like this.
  14. Nov 23, 2021 at 5:49 PM
    #1894
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    2014 DCSB, 59,000 miles, a pavement princess.
    Because my 2006 Tacoma had the "slightly less than full" transmission from the factory, I checked this on my 2014 when new. It was full.
    Today I did the procedure as listed by the OP... Everything went as planned. New crush washers and replaced the 5mm overflow bolt with an OEM drain bolt. 2.9 quarts came out, put in 3.3 quarts, brought to temp, and about 0.3 quarts came out... maybe less.
    Did town and freeway driving, still smooth as silk. Good work OP.
  15. Nov 25, 2021 at 5:48 AM
    #1895
    Plain Jane Taco
    USA
    For those interested in replacing the 5mm allen overflow bolt with a drain bolt....
    Biscuits likes this.
  16. Nov 25, 2021 at 5:57 AM
    #1896
    ejl923
    Eric
    Western Mass
    Is everyone replacing this because the hex key strips?
  17. Nov 25, 2021 at 6:13 AM
    #1897
    Plain Jane Taco
    USA
    Some people have. But it's mostly just for convenience.....one 14mm socket required for both
    Biscuits and 2015WhiteOR like this.
  18. Nov 25, 2021 at 6:34 AM
    #1898
    2015WhiteOR
    Gainesville TX
    Man I'd almost go the opposite way and use the same hex key bolt for both. A 14mm socket on a tiny bolt on a thin aluminum pan is too much in the wrong hands.
    usmc2msu, SR-71A and Accipiter13 like this.
  19. Nov 26, 2021 at 7:50 AM
    #1899
    Knute
    Do you have "wrong" hands??
  20. Nov 26, 2021 at 8:12 AM
    #1900
    2015WhiteOR
    Gainesville TX
    Nope, but some people have the dexterity of a gorilla.. literal steak fingers that overpower everything they touch. And then when they strip a fastener, those people claim the engineers did a bad job or write 1 star reviews on products.
    SR-71A, burrito782 and Jimmy92870 like this.
