How to Drive Manual Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BanjoScott, Jun 7, 2015.
  1. Jun 12, 2015 at 7:17 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Lots of opinions and I disagree with some of them, like skipping gears is bad. Main thing is DO NOT lug the engine. If you're leaving from a complete start, and the road is going down hill, skipping a gear hurts nothing.
    One suggestion, keep your foot off the clutch as much as possible. If stopped at a light, put trans in neutral, wait on light with clutch out.
    When yellow light comes on for the other traffic, THEN depress clutch and put it gear to be ready for light to change. Saves a lot of wear on the throw-out bearing. Also watch your tachometer when shifting, say from 2-3. If rpm goes up when you depress clutch, you're not getting your foot off of the gas soon enough.
  2. Jun 16, 2015 at 4:28 PM
    BanjoScott
    BanjoScott [OP] Member
    Damn good advice, it's very much appreciated. And as I get better, the more I find that what you've told me is true. I do accelerate quite a bit in first ( up to 2500 rpms) just because it's easier to shift into 2nd.
    I've also noticed that I shouldn't be afraid of the gas pedal when shifting into 2nd. The truck needs that quick acceleration as soon as it has shifted I've found.
  3. Jun 16, 2015 at 5:16 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Generally good advice but there are exceptions. For example, when accelerating on a freeway on-ramp running the 4th gear revs up to 3K+ its perfectly fine to skip 5th gear. It will settle into 6th right in the sweetspot. Saves a bit of wear on the clutch and throwout. Even keeps the engine in the torque curve possibly saving a tiny bit of wear on the engine.
  4. Jun 16, 2015 at 5:31 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    Don't "learn to drive a drive a manual" in your '07 Toy, see if you can find a rental with a manual. I had to replace a clutch not long after trying to teach a girlfriend how to drive a stick on my previous Toyota truck.
  5. Jun 16, 2015 at 6:05 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I learned on one that looked just like this (except with 5 spoke Cragers, natch) with no instruction, decades before the Internet, and less than an hour of trial and error. Only burnt clutches by ruining tires. Was a darn good way to learn how to replace them. :) Comparatively our modern 6 speeds are a dream to use and dead simple to learn on.
  6. Jun 16, 2015 at 6:16 PM
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    2500rpm is the sweet spot for getting fairly clean shifts... also I highly suggest investing in a TRD short shifter ...and just shift slowly because those Transmissions do not like to be rushed by any means
  7. Jun 16, 2015 at 7:27 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can read a lot on here about what you should/shouldn't do, and how to do things properly. Really learning will come down to becoming comfortable with your vehicle. Props for being willing to learn.
    This is exactly how I teach people to drive stick, but in 2Hi. Find an empty parking lot (high schools on weekends are great), come to a stop and practice starting without the gas by just easing the clutch out. Drive down one row, turn to the next row and repeat. This will help you get familiar with your clutch engagement point without overcomplicating things. Once you have become very comfortable with this, then start trying to add gas at the same time. I say 2Hi because it will be more real world than 4low, since it is what you will be doing daily.
    This is good advice for prolonging your throw out bearings life.
  8. Jun 29, 2015 at 12:11 PM
    BanjoScott
    Thank you everyone! It's taken a few weeks, but I feel like I got the hang of it. Thanks for all the advice - it's what helped get me there.
  9. Jun 30, 2015 at 12:08 PM
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    Define lug the engine.. I have 4 banger that I lug around and it seems perfectly happy its like a mini tractor... Not going to get anywhere quick but it will get there
  10. Jun 30, 2015 at 1:06 PM
    JB
    JB ....................
    Justin
    CA
    2015 Off Road DCSB
    ICON Stage 2, SCS Wheels, Toyo R/T's, 6-Speed
    Lugging the engine is when you shift into a higher gear than you should at the present speed. For example, you shift into 5th going 20mph and give it gas. It will sound like someone is throwing rocks under the hood. Its not good for the engine at all - rough on the connecting rods and if you do it all the time you will wear the engine out much sooner than it was designed for. Every once in a while is not a big deal and everyone does it at some point. Basically avoid shifting into a gear where the vehicle will struggle to accelerate when you step on the gas.
    Lugging does not mean towing if thats what you mean.
    Something you can do is to shift through all of the gears without ever using the gas pedal. Simply let the clutch out slowly until the engine is idling in 1st gear. Then go to the 2nd and idle. You can go all the way to 6th gear idling the engine and it won't lug if you don't add gas. You'll probably idle at 25mph in 6th. Add a little gas when you're in 4th or 5th and you'll hear it lug.
  11. Jun 30, 2015 at 1:21 PM
    goldentaco03
    goldentaco03 Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    Here's what you gotta do.
    Push the clutch in, put it in first, rev er up to about 1500rpm. Then let the clutch out slowly until until you feel it start to engage. Once you feel the slightest engagement pop that bitch out while pushing the gas pedal through the firewall and into the engine bay. Job done :thumbsup:
    I don't know about the V6's but this ^^ is the only way to get a 4cyl moving.
    Just my .02
  12. Jun 30, 2015 at 1:31 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    It's pretty hard to lug the VVT-i engines unless you're under 1,000 RPM. The older trucks would knock/ping like crazy if you lugged them.
    My tip: If you're backing up a trailer don't feather the clutch, and put it in 4lo if you have that option. The clutch will quickly smoke with even a small amount of feathering. DAMHIK :anonymous:
  13. Jul 1, 2015 at 10:16 AM
    75z28
    Homer
    Ah i see what you mean. I keep mine at around 1500-2000 most of the time and I thought you meant that is lugging it. I know it isn't in the best power band, but I also know it wont hurt it at that RPM. However I usually shift at 2500-3000
  14. Jul 2, 2015 at 11:46 AM
    BanjoScott
    Yeah I used to Lug it because it shifted "smoother," but was so hard to get good acceleration so I just accelerated to about 2500 - above speed and then shift - even more smoothe and no lugging.
  15. Jul 30, 2015 at 8:45 AM
    #35
    BanjoScott
    Why does my exhaust have a rattling sound (really inexplicable) when I shift gears in my truck? It's a low sound coupled with some rattling... Doesn't make sense. Anyone have any experience with this?
  16. Jul 30, 2015 at 8:51 AM
    #36
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    right foot to the floor, left foot up quickly for starts, and my right foot never leaves the floor during shifts.... thats how i drive all my manuals.
  17. Jul 30, 2015 at 8:59 AM
    #37
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Sounds like you're bogging the engine. What RPM are you shifting at?
  18. Jul 30, 2015 at 9:03 AM
    #38
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    Lots of good advice here. For most situations when driving in traffic, shifting below 2000rpm is not possible in most gears without bogging. Don't use the gas when pushing the clutch in. don't make a habit of down-shifting to slow down, this wears out your clutch faster which is mucho dinero whereas new brake pads are only $60. Getting the hang of starting up in 1st from a standstill is something to work at. To avoid rolling backwards at start-up on an incline, pull your e-brake and take your foot off the main brake, rev your gas and let the clutch a quarter of the way out, then slide the e-brake back in as you let the clutch the rest of the way out, once you can engage the gears with your e-brake on you will laugh in the face of hills!
  19. Jul 30, 2015 at 10:19 AM
    #39
    nd4spdbh
    SoCal
    NO..... i guarentee on most inclines you find on the street you dont need to TOUCH the gas to hold the truck with the clutch. Revving the engine and slipping the clutch at higher than idle speeds is a surefire way to kill your clutch quick.
    Hold the brake with your right foot. clutch all the way in, IDLING, slowly let the clutch out till you feel it grabbing, then keep your foot at that same spot and slowly let out the brake, if you roll back, apply brake pressure to stop, slowly let the clutch out a little more and then roll off the brake. You would be surprised what you can idle out in 1st in even with the 2.7.... and slipping the clutch while idiling can be done for FAR longer without damage vs any extra revs.
    I know my buddies old 5 lugger taco with the old 2.4L had no problem idiling out in 1st on our steep street.
  20. Jul 30, 2015 at 10:21 AM
    #40
    snowmanwithahat
    snowmanwithahat Well-Known Member
    2013 Spruce Mica DCSB, TRD OR, V6, Auto
    Same... After 7 months I was still butchering shifts on rare occasion... This is after 4 years of ownership of a 6-speed manual WRX STI.
