[How to] Enable Video Bypass on Pioneer NEX Units
Discussion in 'Audio & Video' started by xguntherc, Jun 3, 2015.
  1. Jun 14, 2015 at 1:40 AM
    xguntherc
    xguntherc [OP] Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Wow... No Thx. I'll deal with it
  2. Jun 18, 2015 at 12:51 PM
    djvictor69
    djvictor69 New Member
    This doesn't work on the 4100.
  3. Oct 3, 2015 at 8:18 AM
    llokii2015
    llokii2015 New Member
    Gunther any way on the AVH 4100 NEX units to do a bypass through the radio. Had it installed didn't worry about grounding out the parking brake because I assumed the 4th quadrant trick was going to work but it doesn't seem too. Firmware is 1.03. If Pioneer took away the fourth quadrant trick I'm wondering how svc techs and developers access. Is grounding out the parking brake wire okay or do you have to do the relay
  4. Oct 5, 2015 at 12:18 PM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    I believe you have to engage ebrake, disengage and re-engage which means I think you need a switch as they've figured out that people are just grounding the parking brake to get around this safety feature. So with a switch, you could switch on, off and on again tricking it into thinking you've pressed, released and re-pressed the parking brake.
  5. Oct 25, 2015 at 10:55 AM
    xguntherc
    Cory
    East Dallas
    It doesn't work on the 4000 or 4100.. Sadly.
  6. Oct 25, 2015 at 11:03 AM
    Do58
    Do58 Well-Known Member
    2015 white tacoma limited
    If it doesn't work you "could" use a switch. ( I personally think there is a better and seamless way. Plus, who wants to mess with a switch ) get a double pulse relay or make a bypass
  7. Dec 14, 2015 at 7:35 AM
    slwburn
    slwburn Well-Known Member
    Winter haven Fl
    12 tacoma dclb 4x4
    I tried touching the screen to disable the override and nothing happen. Am I doing something wrong
  8. Jan 12, 2016 at 3:26 PM
    heretic69
    heretic69 New Member
    2011 Tacoma Double Cab
    Pioneer AVIC 6100NEX
    Can anyone verify if the software bypass still works after updating firmware to 1.05 on 6100NEX?
    Also, if it helps anyone else out, I originally couldn't get my 6100NEX to do the bypass. The trick was that I needed to calibrate the touch screen first, even though everything seemed like it was clicking where I was touching. (It's a menu option to do this somewhere in the settings) Then when trying the bypass again just like all the videos explain it worked first try.
  9. Jan 14, 2016 at 7:11 AM
    ReidStylez
    ReidStylez Well-Known Member
    Reid
    Kansas City
    11 PreRunner SR5
    I wonder if this works with the AppRadio 4 too?
  10. Feb 19, 2016 at 1:17 PM
    rbenner89
    rbenner89 Well-Known Member
    NY
    '10 man tran TRD SR5
  11. Feb 19, 2016 at 5:48 PM
    Do58
    You can use that (though I have never) or just use a pac tr-7. Pioneers just need a double pulse relay if not using a switch (which I would never... Just me though). Tr-7 can be used for MANY different things. Also good if someone gets an alpine ddin.
  12. Feb 20, 2016 at 11:32 PM
    bluewaters182
    bluewaters182 Well-Known Member
    Greg
    Ohio
    2019 4runner TRD premium
    Weathertech Mats, Leer 180 Cap, Icon 2.5 coilovers w/700lb springs, Icon UCA, fox 2.0 remote resi 10" travel rear shocks, nitro 4.56 gears, carrier bearing drop, Level 8 guardian rims 16 x 8.5, 315/75/16 Cooper ST Maxx, satoshi grill, shorty antenna, BHLM, color matched eyelids, rear diff breather relocated, exhaust chop, mudflap delete, debadged, All Pro front bumper powder coated white, smittybilt x2o 8 comp winch, SOS sliders, illumination supply 30" single row led bar, uniden 880 CB w/2' firestick on relentless fab hood mount, full AllPro skids, AllPro expo leaf springs, AllPro U bolt flip, Ultraguage, interior LEDs , trimmed fenders and flares 2", AP ext brake lines, CMC, fire wall massage, pelfreybilt battery box, diehard group 31 battery, Kragen 7" HID, homemade HiLift mount, Yaesu ft-8900, Ellis precision AT shifter, EBC yellowstuff & sport rotors, PIAA 510 fogs, Safari snorkel
  13. Feb 21, 2016 at 1:10 PM
    ndjimmyv
    ndjimmyv New Member
  14. Feb 21, 2016 at 1:14 PM
    bluewaters182
    Greg
    Ohio
    I'm not sure, sounds possible. I have not updated my firmware at all. Did the update improve anything else? If not maybe see if you can uninstall the update.
  15. Feb 21, 2016 at 1:18 PM
    #35
    bluewaters182
    Greg
    Ohio
  16. May 27, 2016 at 2:06 PM
    #36
    Justice14
    Justice14 New Member
    Explorer
    Pioneer 5100 nex
    I have a ford explore just left an aftermarket auto shop , guy was very short with me Didn't even put the screws back in the conceal when he finished but he said he tried 3 different things and nothing worked to bypass and watch DVDs , I did try the AV off for 15 seconds while driving home but I do have my e brake wire grounded to the truck Not sure if that matters , but in at a lose ,, I was excited to get it done and he tells me it can't be done , please tell me he's just too lazy and it wasn't worth his time
  17. May 27, 2016 at 2:42 PM
    #37
    Justice14
    Explorer
    Pioneer 5100 nex
    It worked I put it in park I tried it twice and the second time it said setup .... Thank you
  18. May 27, 2016 at 2:47 PM
    #38
    Do58
    just grounding parking brake doesn't work on that radio. people will say use a micro bypass but sometimes they don't work. I have made them before. I generally use a pac tr-7 when installing stereos that use a double pulse. (this is what I do for a living and never had a problem)
    Justice14 likes this.
  19. May 27, 2016 at 6:50 PM
    #39
    Justice14
    Explorer
    Pioneer 5100 nex
    When I first bought it the 15sec trick didn't work but I guess it's very sensitive ,, anyway I'd live to add a rear camera to the rear bumper , I did notice it had a rear setting , assuming it's for a camera and ideas for me ,
    Thanks
  20. Jun 4, 2016 at 8:02 AM
    #40
    JookyDFW
    JookyDFW Member
    Cool trick. I'm going to try it on my 5100 when it's installed. You mentioned in the YouTube video comments that you wired the rear view mirror backup camera to the radio. Do you have any instructions posted for how you did that?
    Thanks
