How to extend rear brake line?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cobes, Aug 28, 2023.
  1. Aug 28, 2023 at 1:54 PM
    cobes
    cobes [OP] habitual line-stepper
    cobes
    slc
    2000 XtraCab TRD 3.4l Auto
    I have a ~2.25" lift with OME and some Alcan springs, and my rear brake hose is rubbing on the park brake cable(discovered when on a lift for an inspection, so fully extended). So I want to extend the hose before I break it or the parking brake cable. I have never worked on brakes before and am only really starting to do my own maintenance(just did spark plugs, tie rods for the first time.
    So I'm looking to try to get some tips and tricks, things to do, and things to make sure I dont do. Any help would be greatly appreciated. Also could use a recommendation for what kit to get.
    Thanks
  2. Aug 28, 2023 at 2:03 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Andy01DblCabTacoma likes this.
  3. Aug 28, 2023 at 2:03 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  4. Aug 28, 2023 at 2:07 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Like they said. Get a longer one. You will need a line wrench to do any work on the brake lines. Hit those fittings with some pb blaster, they are going to be real snug. Use rubber vacuum cap stoppers while things are disconnected to minimize brake fluid loss / to prevent air from making it further up the chain. You need to bleed your brakes afterwards. If you haven't done that before, it might be best to find a friend who has, or get yourself a power bleeder.
    cobes[OP] likes this.
  5. Aug 28, 2023 at 2:20 PM
    O'Silver_Taco
    MD
    Good time to do a whole brake fluid flush....
    .....suppose to be done every 5 yrs....
    Get one of those cheapee bleeder bottles they sell everywhere....
    or copy and make your own little bigger....
    couldnt be easier....on a scale 1 to 10 .....a 1.......
    go watch half doz videos....
    Thats assuming you dont have abs.....
    ....if you have that ......your gonna need some help.....
  6. Aug 28, 2023 at 2:34 PM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Toytec sells a 24" one. Works great.
  7. Aug 28, 2023 at 2:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Buy one of the many available; hell I even gave one or two away cause they are so abundant.
    Undo with a line wrench, replace, and 2-person bleed them.
    Shouldn't be long as you won't suck in much air from having replaced it.
