How to find an acoustic 'leak' in my home
Discussion in 'Garage / Workshop' started by Gen3TacomaOBX, Aug 19, 2021.
  1. Aug 19, 2021 at 6:22 AM
    Gen3TacomaOBX
    Gen3TacomaOBX [OP] Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    For some reason the master bedroom in the house seems to have no acoustic insulation from outside. When my neighbor is out in their gravel driveway it sounds like they're 4ft away.
    The other end of the house muffles outdoor sounds quite nicely. The windows are relatively new throughout the house and were replaced at the same time.
    How does one go about finding how/where my house needs insulation or carpentry changes to cut down on the outside noise?
    I'm hoping there's some technology similar to a thermal camera that can help identify
    Any help is appreciated.
  2. Aug 19, 2021 at 6:28 AM
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I don't know the answer, but I have a similar problem. Hopefully someone knowledgeable can chime in with an answer.
  3. Aug 19, 2021 at 8:49 AM
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    I don't know that this will work, but here's what comes to mind:
    It could be that the loud rooms lack thermal insulation. Much of the sound deadening presumably comes from the thermal insuation. So look for a lack of thermal insulation because its easier to find. Get a non-contact thermometer (the kind you point at something and it tells you its temperature). On either an extremely hot or extremely cold day, walk through your house and check the interior temperature of the exterior walls.
    Be mindful of HVAC vents blowing close to the wall (it may make that section of wall look better than it is), or sun/shade differences on the outside. But if you have walls with consistent interior ventalation and consistent exterior sunlight, they should have a similar heat transfer through them. A wall showing a higher heat transfer has insullation issues.
    This will work best on the hotest or coldest days of the year.
    Pablo8 likes this.
  4. Aug 19, 2021 at 12:47 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    The above - plus check for tiny crack and holes - maybe on a very windy day with smoke or your face (not kidding). A sealed house is a quiet house.
  5. Sep 7, 2021 at 9:48 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Is this any type noise or only certain sounds ?? How far away is your neighbors driveway ??
    Do you have nice heavy drapes at the windows??
    If have had some windows over the years cause some sounds to be amplified .
    Your in the bedroom your not likely to have a very high ambient noise level as compared to the rest of the house
    Is this a new to you bedroom ?? I know in my case it takes me quite some time to adjust to new sounds .
    A female friend staying over night after fun and games I may as well not even try and sleep the strange noises that don`t belong wake me up.
    Yet being used to the Air Compressor kicking on I don`t even hear it nor the Gun Fire from the Gun Club 1/2 a mile away.
    Curious how this plays out.
  6. Sep 7, 2021 at 11:53 PM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Not sure where you're located but you may have some luck looking for thermal camera rentals near you. Much like what @ksJoe mentioned above, this'll give you a better picture of what's lacking in your walls.
    -J
  7. Sep 8, 2021 at 1:16 AM
    mk5
    mk5 Probably wrong about this
    SoCal
    '05 access cab 4x4
    A thermal camera will let you see if there's literally insulation missing from your walls. I had a condo once where a whole 16" portion of the wall lacked any batting, floor to ceiling, totally hollow exterior wall! In Colorado winters you didn't even need a camera, it was so stupid cold right there. I don't know how nobody noticed for 25 years, but I probably tore into that wall by the second snowfall.
    A good consumer camera is made by Seek IR, it plugs into your phone, for around 250.
    Identifying sound sources is a lot harder. A laser vibrometer can identify walls, windows, etc, that are radiating sound into the room. You could probably hire a specialist to do a survey. But even then it's not always intuitive what repairs will get the desired results.
    I've had a construction project at work once where we were building a mechanical chase amidst a larger room of sensitive equipment. Air compressors, vacuum pumps, etc. We wound up pouring a separate floating slab there, and lined the room with a floating wall of MDF, lots of isolators and acoustic foam everywhere. It was a huge pain in the ass, but it was amazing how loud it could be in that room, and how quiet it was once we closed the door!
  8. Sep 8, 2021 at 1:19 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    A thermal camera may help you, but they only way to really find and fix the problem is going to be to open the walls up. You can use some Rock Wool insulation that with help with an R factor and noise.
  9. Sep 8, 2021 at 1:47 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Check your eaves and ceiling insulation too it could be bouncing up into a missing eave panel and coming in from overhead.
    Beyond that it may just be a perfect penetrating frequency you may have to put in some sort of decoupling layer.
    Hang some heavy blanket or tapestries an inch or two off the wall on that side of the room
    Bivouac likes this.
