How to find out if my 2010 dbl cab taco needs the spring TSB
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JUJtacoma2010, Mar 17, 2010.
  1. Mar 17, 2010 at 1:46 PM
    JUJtacoma2010
    JUJtacoma2010 [OP] Well-Known Member
    Fresno
    Tacoma 2010 Dbl Cab. OFF Road Package
    I have seen others here having taken their trucks to the dealer and had the TSB dealing with springs done. How do I know if my truck needs this TSB? Are there signs that the springs are not working properly?
  2. Mar 17, 2010 at 1:48 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Look at a leaf pack. If there are only 3 leafs including the overload, then you dont have it done.
  3. Mar 17, 2010 at 1:49 PM
    JUJtacoma2010
    Fresno
    what is a leaf pack? Where do I look for one? what do you mean overload? thanks again.
  4. Mar 17, 2010 at 1:51 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Looks like this behind the rear tire
    Not that exact one but you get the point....I hope.
  5. Mar 17, 2010 at 1:52 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
  6. Mar 17, 2010 at 2:22 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you have to ask if you need it, you probably don't.
    Its like a quadruple bypass, you'll know when you need it.:)
  7. Mar 17, 2010 at 2:34 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    if you load your truck with 300-400lbs and your bed slams against your bumpstops..sounding like a mini bomb going off, you need the TSB...
  8. Mar 17, 2010 at 2:37 PM
    dog tired
    dog tired Well-Known Member
    NE Ohio
    +1
    If you want a Cadillac ride you are fine ........
    if you want a TRUCK LIKE ride , bounce and jerked all around when unloaded for those times when you do carry a load then you want the TSB
    Many extol the virtues of increased rear end height -- like that means something ?
  9. Mar 17, 2010 at 11:59 PM
    JUJtacoma2010
    Fresno
    I am glad that I have been reading tsb posts here and now I need to get this done. my truck has only 800 miles on it. Do you think I should get it done now? How should I approach this to the dealer?
    I attached some pictures. Please take a look and verify that I do need this tsb. pictures clearly show 3 leafs.
  10. Mar 18, 2010 at 12:01 AM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    Just say it bottoms out easily. Voila, they'll fix it
  11. Mar 18, 2010 at 7:48 AM
    JUJtacoma2010
    Fresno
    Does anyone have a link to the TSB which shows model 2010? I looked at T-SB-0305-08 and it only goes up to 2008 model.
  12. Mar 18, 2010 at 7:59 AM
    Kmoney
    Kmoney Well-Known Member
    Kelly
    Bend, Oregon
    '17 DCSB TRD OR
    White dog
    http://www.tacomaworld.com/forum/2n...-0305-08-revision-2-includes-2009-2010-a.html
    Here you go, this thread has the updated TSB for 2009's and 10's. I'm getting mine done next week. Depending on the dealer you may have to "prove" that you need the TSB, which will include loading your truck down to show excessive sagging and bottoming out to the dealer. I was lucky my dealer just ordered the parts after I called and expressed my concern and gave him the TSB. Others suggested calling Toyota directly and apparently then you can CHOOSE a dealer to have the work done at without having to weigh your truck down. Either way, getting this done, imho, is well worth the time and slight hassle.
    Best of luck.
  13. Mar 18, 2010 at 8:29 AM
    JKD
    JKD Well-Known Member
    It doesn't matter whether it has three or four leafs. What matters is whether the loads you are carrying are causing your rear suspension to bottom out.
  14. Mar 18, 2010 at 8:41 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    :laugh: Very good!
    I always chuckle when I see "before and after" pictures posted in the forum.
    To the OP, you don't have to decide right away to get it done. Anytime before the 3 year or 36K mile warranty expires is fine.
  15. Mar 18, 2010 at 9:21 AM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ....you dont need it...:facepalm:
