How to Fit 285x75s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCGuyInACOMA90, Nov 9, 2010.
  1. Nov 9, 2010 at 12:49 PM
    SCGuyInACOMA90
    SCGuyInACOMA90 [OP] Well-Known Member
    Alex
    Statesboro, GA
    2007 Silver Streak Mica SR5 4x4
    Leveling Kit, Westin Sportsman Grille Guard, 6000 K HIDs, PA/CB Radio, and much more to come!
    Hello All,
    Im aware that there are probably a few dozen threads similar to mine but im having a little trouble locating them. The ones that i have found do not seem to answer my whole question. The question: What do i have to do to clear 285x75R18 tires?
    I have a Ready Lift leveling kit that i believe is 2 inches and i can clear 285x75s but i rub on my control arms. my problem deals with backspacing.
    I am looking at gettin 18x9 monster XD wheels and 285x75R18 Mickey Thompson baja ATZ radials. i just want to know from y'alls opinion and experience what you all had to do in order to clear these tires/rim combo. I would love to avoid trimming but i understand sometimes u have to do what you have to do. and also how much backspacing would i be needing to clear these tires?
    if i need more lift how much more should i add?
    price is not really a problem. i really just want to ensure that it is done properly and that it looks great.
    I appreciate all the info y'all and hopefully with all of the help i will be able to have the tacoma sittin right before the new year.
    Thanks
  2. Nov 9, 2010 at 12:55 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Well 4.50" is the back spacing you will need to clear the UCA's but with a 9" rim your going to need to cut in the wheel wells and maybe the cab mount.The only way to avoid trimming is lift the truck higher.
  3. Nov 9, 2010 at 1:01 PM
    jusmac
    jusmac Well-Known Member
    i have that size with a 17x9" rim with a -12mm backspacing and I didnt trim or cut the mounts so just depends on lift and backspacing.
  4. Nov 9, 2010 at 1:04 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    285/75R18 is basically a 35" tire.
    Your search results may be more productive if you search for threads where folks are trying to clear a 35" tire.
    Typically, that would be a 6" lift. Not saying it can't be done with a 3" lift, but since I'm only running 33s, I can't speak from experience on that.
  5. Nov 9, 2010 at 1:05 PM
    JLee
    Jerry
    Bay Area NorCal
    The OP want's 18's 285/75/18's are 34.83" yours are 33.83
  6. Nov 9, 2010 at 1:05 PM
    SCGuyInACOMA90
    Alex
    Statesboro, GA
    10-4.
    guess thats what i will have to do. im also looking into getting some 5100s for the front at least. now because i need some more lift and i love the way a truck looks when it is squatted.
    would this be sufficient or is there something else i should consider?
    and instead of the 9inch wide rim is there another measurement of a rim to consider?
  7. Nov 9, 2010 at 1:06 PM
    jusmac
  8. Nov 9, 2010 at 1:07 PM
    SCGuyInACOMA90
    Alex
    Statesboro, GA
    i always thought that 285x75s were 33x11.50or something similar. i may just have to go down in tire size... all i really want are some 33s. and that will be all i do with the suspension... well for now haha
  9. Nov 9, 2010 at 1:08 PM
    JLee
    Jerry
    Bay Area NorCal
  10. Nov 9, 2010 at 1:09 PM
    JLee
    Jerry
    Bay Area NorCal
    On a 16" rim they are
    from the online tire size calculator
  11. Nov 9, 2010 at 1:09 PM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    DUDE that is going to be tough on an 18..go 16s FTW
    285/75/16
    285/70/17
    maybe a 295/70/17.
    Some even have managed 305/70/17s...but that is extreme on a 3 inch lift for these trucks without some major trimming and rewelding the cab mount.
  12. Nov 9, 2010 at 1:12 PM
    jusmac
    eww.... your going for an offroad look and are going over 17's!!!
  13. Nov 9, 2010 at 1:13 PM
    SCGuyInACOMA90
    Alex
    Statesboro, GA
    haha yea but i love the monsters and i have always wanted them.
    but in y'alls opinion what would you recommend that I do? with the 18s. 265x75s? something like a 33. i will find a way to make it work! and maybe a little more brain storming is required.
  14. Nov 9, 2010 at 1:15 PM
    JLee
    Jerry
    Bay Area NorCal
    Not anymore he's not now that he know's a 285/75/18 is a 35" tire.
  15. Nov 9, 2010 at 1:15 PM
    SCGuyInACOMA90
    Alex
    Statesboro, GA
    haha thats right.
  16. Nov 9, 2010 at 1:17 PM
    JLee
    Jerry
    Bay Area NorCal
    More like closer to 34" your going to need 265/70/18's to be under 33"
  17. Nov 9, 2010 at 1:20 PM
    JLee
    Jerry
    Bay Area NorCal
    If your going off road I don't recommend 18's unless there 35's or larger.
    Just stick with a 17" or 16" with a 33"
  18. Nov 9, 2010 at 1:22 PM
    SCGuyInACOMA90
    Alex
    Statesboro, GA
    i really did not want to get rid of my stock wheels just because i have always been fond of them. but there is only way to get some backspacing without spacers... and that is new wheels. at least that is the only thing to my knowledge
  19. Nov 9, 2010 at 1:22 PM
    JLee
    Jerry
    Bay Area NorCal
    Oh yeah those would work.
  20. Nov 9, 2010 at 1:23 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Depends on what you're doing with the truck.
    If you're staying on the street - a street look can be cool. One guy did a really nice job with a 3" lift and 20" wheels.
    If you want to run those 18" wheels and you're staying on the street, you could run 285/60R18 tires.
