How to fit a 33 with a 3 inch lift
Discussion in 'Wheels & Tires' started by drizl16, Jul 16, 2012.
  1. Jul 16, 2012 at 7:28 AM
    drizl16
    drizl16 [OP] Well-Known Member
    Derek
    york, PA
    04 xtra cab
    exhaust, k&n intake, painted stock rims, TRD
    I have installed my 3 inch suspension lift(billy 5100's all around, aal in rear, and eibach coils up front. I have purchased new tires that are 265/75/16 because I have a stock rim. I really badly want to fit 33x11.50 at least, but would really love to fit 33x12.50, with very minimal to no rubbing. I was wondering what it would take to do so, and if it takes a different rim, does anyone have any suggestions on what kind?
  2. Jul 16, 2012 at 7:35 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Plain and simple your not going to fit a 33x12.50 on the truck without a lot of cutting. if you want just a little trimming (for street driving only) 33x10.50 would be the widest on a 3" lift. I have 33x12.50's and I rub EVERYWHERE front,back,top and the frame and I've cut away at least 2 or 3lbs of sheet metal.
  3. Jul 16, 2012 at 7:37 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    I have 33-12.5 on my Tacoma mounted on FJ Cruiser TRD special edition wheels. Done with a standard 3" lift/leveling kit. The tires I am running are Super Swamper Trxs. I believe this is possible because I have not gone to a wider wheel. They recommend a wider wheel for these tires. I get a scrape once in awhile on my coil spring housing but not often enough to bother me.
  4. Jul 16, 2012 at 7:39 AM
    JLee
    Jerry
    Bay Area NorCal
    The OP has a 1st Gen completely different truck.
  5. Jul 16, 2012 at 7:40 AM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    spacers do anything for this?
  6. Jul 16, 2012 at 7:43 AM
    JLee
    Jerry
    Bay Area NorCal
    No they just put you further out and you rub the fenders more. I had to cut 2" of metal of my front fenders just to drive on the street without rubbing. With a 8" wheel it would be less but you would still have to do a lot of cutting to fit 33x12,50's on a 1st Gen without rubbing. And that's street driving only there is no way to fit 33x12.50's on a 1st Gen that don't rub if you wheel your truck hard without major wheel well modification.
  7. Jul 16, 2012 at 7:45 AM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    so higher price tag, rubbing no doubt, trimming. sigh.
  8. Jul 16, 2012 at 7:47 AM
    JLee
    Jerry
    Bay Area NorCal
    More like cutting then trimming and cutting is free for the most part :D
  9. Jul 16, 2012 at 7:47 AM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    Op has a first gen...they fit tires differently so your advice is useless.
    Op, 33x10.5 doesent rub anywhere for me on stock rims, so if you want to avoit chopping that would be your best bet. Blackdawg has some stupid wide tires, go find his build and ask him how bad it rubs and how much he had to cut out. If I remember he just pounded the pinch weld, but it was still rubbing pretty good on the bumper. He does have a 97 though, and we are not sure why, but it just seems like the older 1st gen handle lifts and fit tires better than the newer ones.
  10. Jul 16, 2012 at 7:48 AM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    :p 32's probably wouldnt rub to bad u think?
  11. Jul 16, 2012 at 7:55 AM
    JLee
    Jerry
    Bay Area NorCal
    Yeah it's a lot easier to fit 32's but if your a 4x4 and you stuff your tires anything larger then 265's and your going to rub somewhere.
    Having the glass and not front bumper helps :p
  12. Jul 16, 2012 at 7:56 AM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    well then, I only have one thing left to ask..
    is the rub worth it?
  13. Jul 16, 2012 at 8:07 AM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    :rofl:well played
  14. Jul 16, 2012 at 8:17 AM
    JLee
    Jerry
    Bay Area NorCal
    It's really up to you I've cut enough to just rub a little backing up at full lock on the street. Off road on the other hand i rub everywhere and there is really nothing i can do to stop it. I don't mind it but that's me
  15. Jul 16, 2012 at 11:42 AM
    drizl16
    Derek
    york, PA
    04 xtra cab
    In case it matters I have an 04 and I do offroad around once a month. But what im getting from this, is that theres pretty much no way im fitting 33's without rubbing somewhere?
  16. Jul 16, 2012 at 12:13 PM
    Critta93
    Critta93 Well-Known Member
    Virginia
    2000 Toyota Tacoma SR5 TRD Offroad V6
    3" coil over suspension lift and 3" body lift on 35's.
    If you put a 5100 and eibach/toytec coils on which you have, you can run 33 12.50. I'm doing it now
  17. Jul 16, 2012 at 12:15 PM
    drizl16
    Derek
    york, PA
    04 xtra cab
    how much you rubbing on/offroad, did you trim at all, and what rims you running?
  18. Jul 16, 2012 at 12:37 PM
    Critta93
    Virginia
    Yeah I trimmed.. who doesn't
  19. Jul 16, 2012 at 1:02 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    Can we see a picture of the cut area.
  20. Jul 16, 2012 at 1:04 PM
    Critta93
    Virginia
    Yeah not right now I'm at work.. Later I will post
