How to fix a seat belt that wont retract?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Jul 18, 2009.
  1. Jul 18, 2009 at 7:23 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well the title says it all i saw the post of 4x4wire on it but the pictures are so zoomed in i cant really tell what part of seatbelt the are working with.
    Did a search didnt find anything.
  2. Jul 19, 2009 at 7:22 AM
    keredson
    keredson Member
    plano,. tx
    '95 SR5 V6 4x4 Taco
    i had to do this a few weeks ago. once you remove the retractor mechanism (about the size/weight of a brick) you'll notice there are plastic caps on both sides. one side contains gears, one side contains a spring. i drilled a small hole in the spring side and sprayed some motorcycle chain lube in. i then sealed the hole w/ some gorilla glue. (make sure you just cover the hole, don't get it inside. prob. better to use a silicon sealant of some sort)
  3. Jul 19, 2009 at 7:40 AM
    [eric]
    [eric] Well-Known Member
    Eric
    Bend, OR
    2005 Tacoma TRD OFF Road
    i dont know how true this is, but i once heard by law the dealership has to fix damaged seatbelts for free. or free to us and the goverment pays for it or something.
    anyone else ever hear this?
  4. Jul 19, 2009 at 10:15 AM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    well it not damaged its just when you let go of it it doesnt want to retract ALL the way with out a little help from me.
    I cant understand first i cant get the dash off now i cant figure out how to get the door panel off to get to the seat belt thing...but i cant change my oild in 10 minutes TOPS i guess i just dont mix well with plastic.
  5. Jul 19, 2009 at 12:45 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    uhh mine sucks too. my understanding was that most old toyotas just had shitty seatbelt retractors.
    i just pull it in when i get out. its kinda become part of the routine.
