How to fix front tire rubbing.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by easyheimer, Jan 24, 2021.
  1. Jan 24, 2021 at 9:00 AM
    easyheimer
    easyheimer [OP] Well-Known Member
    Robert
    2010 Magnetic Grey Tacoma SR5
    Bull Bar | Nerf Bars | Tuff T01 Rims on Nitto Trail Grapplers | Smoked Spyder Tail Lights | Black Powder Coated Step Bumper | Towing Package| Tonneau Cover
    Hey guys. Bought the truck used and it had 33” tires on it. It seems to be rubbing when pulling out of my driveway or anywhere else for that matter, in reverse. Doesn’t rub going forward. Seems to be rubbing on the fender liner towards the front of the vehicle. I tried to take a heat gun to the liner and bend it in a bit and that seemed to work for a while but I think my new suspension is settling in so it’s doing it again.
    Is there any recommended way to get rid of this or is the way of a heat gun or hacking it up the preferred solution?
    Thanks in advance!
  2. Jan 24, 2021 at 9:26 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I would cut off whatever it’s rubbing on. Lots of threads around on it.
    Island Cruiser likes this.
  3. Jan 24, 2021 at 9:30 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
  4. Jan 24, 2021 at 11:51 AM
    easyheimer
    Robert
    Thank you. I appreciate it. I didn’t want to cut and hack it up at first but if that’s the best way to do it then it’s game on.
    It won’t affect the overall functionality or purpose of the fender liner will it? That was my biggest concern.
  5. Jan 24, 2021 at 11:54 AM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Yeah, going to have to cut. I used a dremel. You can also try to zip tie the fender liner further forward
  6. Jan 24, 2021 at 5:15 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    It depends what part/how much you cut. If you only cut off a small amount it won’t be floppy.
  7. Jan 24, 2021 at 5:19 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    33's? Or 285's?
    33's you are DEFINITELY going to need a cab mount chop, 285's if the run small and you got upper control arms with forward caster adjustment you *MIGHT* be able to get away with a little trimming of the splash guard in the front but it's probably going to rub *ON EVERYTHING* if you ever off-road.
  8. Jan 24, 2021 at 6:18 PM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Bigger tires suck on 2nd gens
  9. Jan 25, 2021 at 5:46 PM
    easyheimer
    Robert
    Thanks for this. I don’t plan on off reading with this truck since it’s my daily driver. Seems like I’ll just have to trim the fender liners sine it only rubs when turning in reverse, but not always. I just want to get rid of the noise on my daily drives / trips.
  10. Jan 25, 2021 at 8:27 PM
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    Harbor freight heatgun and get to work remolding . That's what I had to do.
