how to fix fuel level needle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by XPOTRPR, Dec 16, 2013.
  1. Dec 16, 2013 at 6:53 AM
    XPOTRPR
    XPOTRPR [OP] CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey guys,
    When replacing my gauge face, I thought I set the needle back to the correct position, but apparently not. Now. When filling up, it wont read past between 1/4 and 1/2 tank of gas. It tries.. but then clicks back down.. Like its stuck.
    I think its reading its "full" and wont go any higher, meaning I need to reset it so that "highest" point is actually at the full mark instead of where it currently sits.
    Only way I can think of fixing it and knowing where my fuel level is, is to fill the tank to full... (until the pump shuts off) then turn the truck on, let it reset the needle, and then set the needle to the full mark. Ill just have to watch it for the duration of the tank, see how many miles I get, then when it hits the low fuel light, fill it up again and see how many gallons it takes.
    Thoughts?
    -Moose
  2. Dec 16, 2013 at 6:01 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2021 TRD OFFROAD 4x4
    Could have trashed the stepper motor that runs in somehow in the remove and install
  3. Dec 16, 2013 at 10:02 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not a stepping motor. More like an ammeter.
  4. Dec 16, 2013 at 10:09 PM
    HamerMan
    HamerMan Well-Known Member
    Andrew
    North Bay Area
    '02 prerunner
    Not racetruck
    Bump for josh:)
  5. Dec 16, 2013 at 10:19 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Really?
    I thought everything has been steppers since the early 90s.
  6. Dec 17, 2013 at 4:58 AM
    Vantage
    Vantage Well-Known Member
    Luke
    Vancouver BC
    2015 Titan Pro 4x
    OP don't listen to these guys. When you remove the needles they lose their "home position".
    You need to wind the needle until you feel the resistance change, it gets a little tougher to spin. It usually takes 1-1.5 full turns before you can feel it.
    Then set it to where you had your fuel level. Sometimes it takes 2-3 tries to get it right so keep the dash apart plug in the cluster and let it idle for a few minutes and see if the needle stays where you want.
  7. Dec 17, 2013 at 6:19 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks for the reply fellas.
    Yeah I felt the resistance when taking them apart. Was going to do it last night but still dont have my truck back yet. Will take it apart tonight.
    As far as spinning it, trying to remember... I will be spinning clockwise to feel the resistance and set it right?
    Just gotta fill the tank so I know where to set the needle. Otherwise I have no idea where the fuel level is.
  8. Dec 18, 2013 at 7:35 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    well, i think i got it all sorted out. after a few tries i think its at where it needs to be. filled up, placed the needle at full. with the ignition OFF, it drops to right about the top horizontal line of the E. ill keep an eye on it along with the Trip.
    I have about 15 miles on it right now after i filled up, the needle hasnt moved (like normal) so hopefully in the next 15 or so miles it will begin to drop.
    anyone have a picture or insight on where the needle should sit when the low fuel light comes on? Thats how I'll check to make sure its accurate.
  9. Dec 18, 2013 at 7:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    Rich is almost right. Most all cars went to stepper motors in the late 90s. They haven't been "ammeter" setups for many years.
    Not sure on when the low fuel light comes on, but whenever I had one that was inaccurate, regardless of the type of vehicle, I simply removed the needle , connected the cluster, disconnected the connector for the fuel tank, turned on the key, then installed the needle in the position it is in for a totally empty tank. Then reconnected everything. Once or twice I was a small amount off, but it usually works every time.
  10. Dec 18, 2013 at 7:43 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    interesting.. so your saying that disconnecting the fuel tank (the sender unit?) then plugging it all back in would "reset" it and raise it to the correct level?
  11. Dec 18, 2013 at 7:46 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Low fuel light should come one with the needle about 1/3 closest to the line to the "E"
    That's how accurate you're going to get it. The needle is one thing the light runs on the amount of fuel left...so there's 3 gallons left when the light turns on
  12. Dec 18, 2013 at 7:50 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    cool thanks man! :thumbsup:
    I'll keep an eye on it, and will adjust it if necessary when the low fuel light comes on.
  13. Dec 18, 2013 at 7:52 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    No prob.
    Stock fuel needles(gauges) aren't always accurate anyways lol it's just a guestamite
  14. Dec 18, 2013 at 7:56 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    yeah i figured i would never get it exact. i use my trip most of the time anyways. i just dont want the needle to be way off when the low fuel light comes on.
    i set the needle right above the full line when i filled up, so it should be pretty close when the light does come on.
  15. Dec 18, 2013 at 8:01 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
    Sounds good. It's funny every truck is different...I've had to work on so many that most before I even touch them don't sit right (came from factory like that)
    Some sit higher than the F or at line
    Same goes with the rest of the needles
  16. Dec 18, 2013 at 8:09 AM
    BamaToy1997
    Bill
    Navarre, FL
    No, what I am saying is that by disconnecting the fuel tank connector, the cluster gets the same signal as if the fuel tank were empty. It is basically tricking the cluster into thinking "empty" tank, so the internal servo will go to the "empty" position.
  17. Dec 18, 2013 at 9:08 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    ahh got it. ok. but then when reconnecting it, does the needle return to where the actual fuel level is afterwards?
  18. Dec 18, 2013 at 9:41 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this is the reason i had issues btw.. swapped in a new gauge face.
  19. Dec 18, 2013 at 6:03 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    60% of the time it works every time ehh? :p
  20. Dec 18, 2013 at 6:05 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Bahh.... Much ado about nothing.
    Can't even see the thing :p
