how to fix hole in PVC pipe?
Discussion in 'Garage / Workshop' started by wileyC, May 12, 2012.
  1. May 12, 2012 at 10:01 PM
    wileyC
    wileyC [OP] Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    ...drilling to put toggle bolts into wall, ..hanging cabinets.. looks like i drilled into a PVC pipe in the wall, ...waste or vent?... anyway, hoping theres an easy way to plug the little hole...
  2. May 12, 2012 at 10:05 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Cabinet height, my guess would be vent, unless you are on something other than the first floor.
  3. May 12, 2012 at 10:06 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    you have to cut it and put a couple at the joint correct?
  4. May 12, 2012 at 10:07 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    duct tape
  5. May 12, 2012 at 10:07 PM
    Monkeysuncle
    Kevin
    Florida
    Hell if it's behind cabinets just cut an access hole to access the "damage" then fix the pipe in question.
  6. May 12, 2012 at 10:08 PM
    Monkeysuncle
    Kevin
    Florida
    Small cut in dry wall or similar material, and JB WELD FTMFW
  7. May 12, 2012 at 10:12 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Ding ding ding!! We have a winner.
    Get yourself some pvc cleaner and glue, usually sold together in a brown can and a purple can, and a union. Cut the pipe in half where you drilled into it. You'll have to bend the pipe pretty good to get the union in there. Use the cleaner on both the pipe and the union, apply the glue, and stick it back together. Everything should be good as new. Good luck.
  8. May 12, 2012 at 10:13 PM
    Monkeysuncle
    Kevin
    Florida
    Ha Ha just saw the home improvement thread, isn't that always the case, try and fix or do something and it turns into a mess. Good luck.
  9. May 12, 2012 at 10:32 PM
    wileyC
    Centerville, OH
    yeah it's on the first floor, ...the pipe is right up against the f-ing drywall, ..so assume it spans the width of the stud (drain/waste)?.... can i just glue or screw some kind of plug into it?
  10. May 12, 2012 at 10:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Stuff an HDMI cable or one of your spare guns in the hole
  11. May 13, 2012 at 10:20 PM
    wileyC
    Centerville, OH
    it's a big 3" pipe (actually 3.5"), running vertical between studs, ...some moisture in the hole, ..i think its waste pipe serving the second floor?..?... anyway, i think i have a plan:
    cut annular ring from another piece of pipe (same size), ...only about 3/4 of the circle, ...this will "snap" around the pipe, to help hold in place while the pvc glue dries... so i should be able to use this method to weld the annular patch right over the hole... i'm trying a test run on a scrap piece of pipe, same size... hopefully this is a good idea, i hope...
  12. May 13, 2012 at 10:23 PM
    OZ-T
    Peter North
    British Columbia
    Awesome idea if you are OK with the upstairs poop water inside your wall cavity later :)
  13. May 13, 2012 at 10:27 PM
    wileyC
    Centerville, OH
    :confused:
    ? what cavity?
  14. May 13, 2012 at 10:27 PM
    OZ-T
    Peter North
    British Columbia
    Isn't the pipe inside the wall ?
  15. May 13, 2012 at 10:37 PM
    wileyC
    Centerville, OH
    you don't think this is a good fix?
  16. May 13, 2012 at 10:38 PM
    OZ-T
    Peter North
    British Columbia
    I wouldn't trust it to not leak if it is a waste stack , if it is a vent it would probably be OK
  17. May 13, 2012 at 10:40 PM
    wileyC
    Centerville, OH
    ...hmm, ..well it's not under pressure, right?.... not sure why it would'nt be trustworthy?... the guy at the h/w store was trying to peddle some tape to put over it, or epoxy putty?... i figured welding pvc to pvc would be better?
  18. May 13, 2012 at 10:42 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    JB weld to plug the hole would be the most dependable QUICK fix.
    I would go the correct route which has been stated:
  19. May 13, 2012 at 10:43 PM
    OZ-T
    Peter North
    British Columbia
    It's not under pressure , no .
    The inside diameter of the pipe won't match the outside diameter of the same size pipe .
    It's up to you , if it was my place , I'd replace the section of pipe
  20. May 13, 2012 at 10:44 PM
    wileyC
    Centerville, OH
    i don't think i'll have the clearance or range of movement needed for a typical pvc union...? :(
