How to fix these frickin cel codes???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dbs1, Jul 2, 2016.
  1. Jul 2, 2016 at 4:56 PM
    dbs1
    dbs1 [OP] 2015 Dbl cab TRD Pro 4x4
    Dan
    2015 Dbl Cab TRD Pro 4x4
    SC w/urd pulley, afe cai, URD LT's, TRD cat back. 375hp. Custom logos, tonneau cover, westin bar with piaa lights, aero force gauges, custom front air dam, Westin step bars.
    On my 2010 4.0 with TRD SC, DTLT's (has a new fake out wiring kit for the now missing cats). I've recently cleaned the maf, 4 new 02 sensors, and as mentioned replaced the original front cat delete wiring with a new one 10,000 miles ago. The truck has about 136,000 miles on it with 95,000 on the sc and headers. The only thing I have not updated are the rear cats.
    It will be fine for a few weeks, then cel comes on for a few days then goes back off. Any ideas as to what it needs to keep cel off for good?
    Codes-
    1. P0103 Mass or Volume Air Flow Circuit High Input
    2. P0108 Oxygen Sensor Circuit High Voltage (Bank 1 Sensor 2)
    3. P0161 Oxygen Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
    4. P0420 Catalyst System Efficiency Below Threshold (Bank 1)
    5. P0430 Catalyst System Efficiency Below Threshold (Bank 2)
    6. P0607 Control Module Performance
    Tex-Tac likes this.
  2. Jul 2, 2016 at 4:58 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
    Wiring harness or ecm
  3. Jul 2, 2016 at 5:26 PM
    TacomaZL
    TacomaZL Well-Known Member
    Illinois
    2013 Toyota Tacoma 2.7L
    WeatherTech Floor Mats; 15" Cragar Black "D" Window Wheels; Custom Center Caps; 235/75/R15 Goodyear Radial Wranglers; "TOYOTA" Tailgate Decal; Magnetic Tool Storage (in Cabin); Stant Locking Gas Cap; Salex Glove box Organizer Debadged; BHLM; Aftermarket Fog lights; FlashWolves 1000 Lumen Reverse lights; DEPO Black LED Tail lights; Differential Extended Breather Mod; FalconZero F170HD+ Dashcam; Scosche MagicMount; Tyger Auto Tri-Fold Pickup Tonneau Cover;
    That wiring harness is no good. P0420 is basically a CAT code that gets thrown when the CAT blows up or gets cut off. The wiring harness is screwing something up because the MAF, and both O2 sensors are throwing codes that would indicate that they are broken or not working correctly. My money is that harness is garbage. Sorry bud.
  4. Jul 2, 2016 at 5:45 PM
    dbs1
    Dan
    Nooooooooooooooooo.
    Well as noted, the front 2 cats are no longer there due to the headers, despite the wiring sent with them to show the computer they are.
  5. Sep 30, 2016 at 6:21 AM
    AviatorGator11
    AviatorGator11 Member
    09' Black Tacoma 4.0L V6 SR5 TRD
    URD Spec U Headers, URD Y pipe, Flowmaster Exhaust, AFE Cold Air Intake, Throttle Body Spacer.
    Just curious Did you ever solve this problem? Was it your harness or your ECM?
    I have a very similar problem. Im getting p0138 p0430 p0607
  6. Oct 1, 2016 at 6:56 AM
    dbs1
    Dan
    Don't know. I'm just living with it at the moment.
  7. Oct 1, 2016 at 10:00 AM
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    P0456.......Gas Cap loose or small leak in pressure system, gas tank, etc.
  8. Oct 1, 2016 at 11:12 AM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I dunno what is covered under "newer trucks", and havent seen gadgets response to it, but i found this.
    Maybe he can chime in
  9. Oct 1, 2016 at 1:31 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    These are not the same codes I'm getting. I put the URD Long Tubes on w/ their O2 Simulator and I get codes a minimum of once a day. Gadget asked me to send the O2 sim back so he could try sendin gme a less aggressive one. My problem is my life is so damn busy I literally haven't had time to crawl under the truck anddisconnect the stupid thing so I can ship it to him.
    The codes I'm getting indicate a "slow Rich to Lean" on the O2 Sensor itself. Gadget basically told me that's normal on the newer Tacomas (though I didn't get a year cut off). He suggested he may not even be able to get me an O2 sim that actually fixes the problem. Wish their site said that before I bought the headers and the simulator.
    What is stupid though is that Toyota thinks it's a good idea to disable traction control when the CEL comes on. What about those of us with winter weather approaching? Just seems like a liability thing on their part by intentionally shutting down traction control for no necessary reason other than punishing those with CEL that are on.
  10. Oct 1, 2016 at 1:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Exhaust gas leak on a 4Runner will disable ABS as well. Go figure the smarts in that....
  11. Oct 4, 2016 at 8:15 PM
    Brianawd
    Brianawd Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    Go figure gadget sells a part that does not work. I had the same issue on 15 with his 0/2 sim. I sent email asking how he was going to fix the issue. Never did a anything to help. I ended up taking that 0/2 sim out of the truck and tossing it in the trash.
    I now have 2 vibrant 0/2 sim with the smallest spacer. I still get codes 420/430. But now only about once a week or less. I'm about really to pull the URD headers off my truck and go to some JBA shortys with highflow cats
    TacoCynGsxr likes this.
  12. Oct 4, 2016 at 8:54 PM
    inwood customs
    Dave
    Bummer
    Im curious to hear both sides
    @Gadget@URD
  13. Feb 28, 2017 at 9:42 PM
    grydsrt
    grydsrt Mall Crawler
    Heart of, Texas
    '05 Double Cab, Long Bed, 4x4, Camper Shell, 205k Original Owner
    URD TACI, URD MAF Sensor Calibrator, URD Dual Rear O2 Simulator, AFE MACH Force XP Cat-Back, Thorley Y-Pipe, JBA LONG TUBE Headers, URD O2 extension harness. In line tranny filter, URD in-tank pump/fuel filter. Hopkins Smart Hitch Camera and Sensor System. 3M Clear tint on windshield. SnugTop Camper Shell.
    I had a ton of CEL issues with my similar setup. I finally replaced all my header studs and used lock nuts on them. Runs like a striped ape now. You need "external torx" sockets to replace.
    The old header gaskets were replaced as well because when the original nuts worked loose they opened up a gap along the bottom of each header that essentially blew out all the gasket material so that they looked like wire mesh.
    Check all your vacuum hoses for leaks or simply replace.
    Replace PCV valve.
    Check exhaust for leaks.
    I did all the above and after four years of CEL's it finally runs as advertised.
