How to fix weather stripping?
Discussion in 'Detailing' started by Leadgolem, Oct 20, 2010.
  1. Oct 20, 2010 at 1:18 AM
    Leadgolem
    Leadgolem [OP] Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Not sure if this is exactly a detailing question, but how do I fix this?
    There is a metal tab holding it in on one side, but not the other. What I'm wondering is if I can just get some kind of adhesive and stick it back in, or if I need to try to find a new tab?
    The previous owner told me that the back window had been smashed in, so the center section of it has been replaced. Probably why the weather stripping is hanging down like that.
  2. Nov 18, 2010 at 9:04 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    There's an adhesive to do anything.. But its hard to see what you're working with, and i dont have a first gen to go look at anymore.
    You may be able to order a new strip from your dealer. Check for a website with exploded parts diagrams for "collision" parts.
  3. Nov 19, 2010 at 12:06 AM
    Leadgolem
    Greg
    Littleton, CO
    You know, you got me thinking. So I pulled the diagrams from the manual. That piece of weather stripping doesn't exist in the diagrams. Then I went and pulled it off. What I thought was a factory metal clip was just a bent piece of metal shoved in to keep it from falling out. It's a piece of generic window weather stripping somebody had glued into the channel on the top.
    So, problem fixed by removing unnecessary weather stripping. There is another seal in the sliding window channel. That's the factory one. :)
  4. Nov 19, 2010 at 12:21 AM
    island808
    Jedediah
    hawaii
    Might have been there to stop water from running in.. or attempt to.
    Hopefully you didn't just uncover a long lost leak.
  5. Nov 19, 2010 at 12:34 AM
    Leadgolem
    Greg
    Littleton, CO
    Since the only part of it that's been attached has been a 2" section on one side, I kinda doubt I've uncovered a leak. :) It's been like that for over a year. There is another strip of the exact same stuff on the bottom. That, I'm not planning to touch.
