How to flex the suspension with a jack?
Discussion in 'Suspension' started by DiffLock, Oct 24, 2017.
  1. Oct 24, 2017 at 8:04 AM
    DiffLock
    DiffLock [OP] Well-Known Member
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    I'm trying to troubleshoot tire rub, and I'd like to see where my tire is going along its travel. I thought about driving the tire onto my low profile jack and then I can jack it up. This seems a little unsafe since the front wheel could spin off of the jack. Any better ideas?
  2. Oct 24, 2017 at 8:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you trying to test the front? Pull out your coilover and use the jack underneath to raise the tire. Just have the front of the truck on jackstands so both tires are in the air. That's the best way to see where you rub at full stuff through the turning motion.
    61ragtop, tomwil and DiffLock[OP] like this.
  3. Oct 24, 2017 at 8:13 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    What size tires?
    What suspension?
    How much lift?
    Alignment specs?
  4. Oct 24, 2017 at 8:22 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    275x70x17 bfg ko2
    king extended 3" lift
    caster 2.0
    It only rubs when hitting bumps while turned. I already have a CMC so I assume it is hitting the pinch weld in the rear of the fender well.
  5. Oct 24, 2017 at 8:29 AM
    eon_blue
    Azusa, CA
    If you have sliders, use a Hi Lift on either side of the truck to lift it a few pumps and it will compress the suspension on the opposite side.
  6. Oct 24, 2017 at 8:30 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Do you have aftermarket upper control arms? If you do then up your castor to 3-4* then flatten the pinch weld and you shouldn't rub. I was able to have no rubbing with 285/75/16's.
    But like eatsleeptacos said, you can pull the shock out to cycle everything and see exactly where you are hitting.
  7. Oct 24, 2017 at 8:30 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    hi lift jack and let 'er rip.
  8. Oct 24, 2017 at 8:33 AM
    DiffLock
    Dan
    SoCal/OC
    2019 DCSB OR 4x4
    King Ext Travel 3"
    Yeah I have total chaos UCA's. Sounds like a plan. I was wondering how the hell you guys put even larger tires when I'm still rubbing on 32's.
    I don't have sliders/hi-lift yet but I have some demello's on order!
  9. Oct 24, 2017 at 8:37 AM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yep up your castor a little and get the bfh out for the pinch weld
    DiffLock[QUOTED][OP] likes this.
