How to Fluid Film your 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InSight Retrofits, Oct 11, 2016.
  1. Jun 11, 2023 at 7:14 AM
    #301
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Took at least 6 cans of RP-342 cosmoline to do my tacoma. This was 2 decent coats letting the first coat creep into all the crevices till it was fairly dry. I coated everything steel I could find, including any transmission and power steering lines. Did not coat the driveshaft, and shocks. Spent some time getting the insides of the boxed frame sections, and rear bumper insides removing the bumper ends, along with doing the spare tire&chain/w the crossmember. That was 3 years ago with the salty winters here. This spring, just very minor touchups in the high abrasion wheel well areas. All else looked great, just like new. Its so much better then having to apply fluid flim throughout the truck every friggin year.
  2. Jun 11, 2023 at 7:23 AM
    #302
    RedRoss
    RedRoss Well-Known Member
    '23 TRD Sport WCP DCLB
    Thanks! Yeah I’m sure I’ll burn two more cans when I get back to it. Good, hot, and dry here now. But winters are vehicle eaters. My six yr old Silverado I dumped was looking ugly.
  3. Jun 11, 2023 at 7:33 AM
    #303
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Yes, I would've done Cosmoline initially. But I opted for Fluid Film. Once you choose either, you really can't switch.
  4. Jun 11, 2023 at 7:39 AM
    #304
    zoo truck
    None
    Friend of mine had a 10 year old Silverado that he drove to Vermont every weekend in the winter. By the 10 year without any rust inhibitor coatings on the chassis, one side of his trucks frame was so bad it failed inspection when it went for emission testing. He complained to gm about it. Their answer was ''were sorry this happened, but go pound sand''.
  5. Jun 11, 2023 at 7:41 AM
    #305
    zoo truck
    None
    You could if not rusty. You'd need to pressure wash any of the ff remains off really well.
  6. Jun 11, 2023 at 8:46 AM
    #306
    gsubioguy
    gsubioguy Well-Known Member
    Evan
    Maine
    '21 TRD OR
    Basically I want to remove it all before reapplying to a fresh/clean surface. I didn't remove any after the first application before applying it for the second winter. Now I have massive amount of grime & grit stuck to the frame.
  7. Jun 11, 2023 at 8:50 AM
    #307
    willtill
    Maryland
    I understand you. That Fluid Film; even with the grime and grit, is still protecting the frame. I've been Fluid Filming mine since 2019 and just reapply over the grime and grit.
    I think of Fluid Film and the grime and grit as barnacle paint. It sloughs off enough throughout the year, to enable another application of it in the fall; in prep for the winter.
  8. Jun 11, 2023 at 10:18 AM
    #308
    RedRoss
    I live in those conditions 24/7/365. Six years almost on the nose and I thought the undercarriage on Silverado was a mess. Everything was being eaten. I always drove gmc. First Chevy I had. There’s a difference somehow. Chevy, What an absolute POS. transmission gone at 80,000 mi (non warranty). Starter went. Tires always leaked. Electronic tire gauges were out and always weird. Never again. They still gave me $21k for the pile of junk. Only thing nice about it was it was paid off and the Bose speakers (boy JBL sound isn’t great). Otherwise a loaded 2023 taco was cheaper msrp than a pretty stripped z71 double cab Silverado in 2017. Plan for this one to last longer.
    zoo truck[QUOTED] likes this.
  9. Jun 11, 2023 at 11:57 AM
    #309
    RedRoss
    I’ve lived there. IMO no. Not unless you live in the hills of the Appalachians. Or if you really want ten plus years out of that truck it sure wouldn’t hurt.
    zoo truck likes this.
  10. Jun 11, 2023 at 2:01 PM
    #310
    zoo truck
    None
    Well from experience owning toyota pickups since 1978, the chassis will rot out even sooner if nothing is done. I used fluid flim on my 2001 tundra every fall, and it still was pretty rusty 19 years later when i sold it. It gets very salty, and wet here in southern New England all winter. Fluid flim works fine if it's reapplied twice a year, but I had enough of just once a year. I've now found cosmoline to be the answer...at least so far.
    As far as gm reliability...just ask my brother about gm before he became a toyota owner for keeps now.
  11. Sep 19, 2023 at 10:32 PM
    #311
    leodavies
    leodavies New Member
    Leo
    2023 TRD Sport
    Anyone know where I can get the spray nozzle extention for cans of cosmoline so I can get inside the box frames?
  12. Sep 20, 2023 at 3:06 AM
    #312
    willtill
    Maryland
  13. Sep 20, 2023 at 4:45 AM
    #313
    zoo truck
    None
  14. Sep 20, 2023 at 5:53 AM
    #314
    willtill
    Maryland
    Oh you're right. I thought he wanted them for Fluid Film. I don't comprehend well when I first wake up and get on the computer. :pccoffee:
  15. Sep 20, 2023 at 9:56 PM
    #315
    leodavies
    Leo
    2023 TRD Sport
    Appreciate the feedback. I Emailed Cosmoline Direct and got a reply back. He confirmed that most of the extensions won't fit but didn't provide info on which ones would fit. He said that Cosmoline doesn't recommend using them anyway. He said the material forms a fog like mist that will travel a good distance and will coat the inside of enclosed frames very well without without an extension to the six inch straws provided. They don't sell one. If it was a good idea I think they would. I plan to just hit the enclosed frames generously with cosmoline from whatever openings are there and call it good. Plan to get an underbody flush at a car wash on a nice non windy day next week, let dry, and then go at it with full body covering and a mask to protect my face. Sounds like a messy job. Will drop the spare tire and the skid plate and also hit the transmission and 4WD differential and whatever looks like metal from underneath. Also anything under the hood that looks like metal that could rust but not get hot.
    gsubioguy and zoo truck like this.
  16. Sep 21, 2023 at 4:52 AM
    #316
    zoo truck
    None
    It's a messy job for sure. If you got some latex type gloves, use them. I wore one of the hooded 3m suits with a pair of goggles doing mine. After you're done doing 2 coats, it all goes in the trash. You'll likely need more than 6 cans once you hit those boxed in frame sections.
  17. Sep 21, 2023 at 4:55 AM
    #317
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    You can get adaptors to use those extensions on cans that they normally don't fit. Search for "graffiti adaptors" on Amazon. I have used the extensions on a similar product and it works just fine. I put the extension on a can of WD-40 and flush it out after use to keep it from getting clogged.
  18. Sep 21, 2023 at 5:12 AM
    #318
    zoo truck
    None
    These cosmoline rattle cans are odd. What fits on nearly every other can out there doesn't fit theirs. I went through this when doing my truck till I stumbled on a source on eBay. I tried later to get another one of these extended wands, but came up empty.
  19. Oct 2, 2023 at 8:40 AM
    #319
    jewboi
    jewboi Well-Known Member
    will a 6 gallon pancake compressor be able to keep up? FAQ here (https://www.kellsportproducts.com/FAQ_ep_42-1.html) says anything more than 3 gallon is fine, but that seems a bit small. i dont mind waiting for it to recharge the tank a bit, but dont want it to be excessive to the point where its obviously intended to be done with a much larger tank.
    also, how clean do surfaces need to be before applying? gearing up to do my 2017 TRD OR for the first time, and ive never explicitly cleaned the underbody beofre
  20. Oct 2, 2023 at 10:18 AM
    #320
    zoo truck
    None
    Its called a power washer, or manually do it at a self car wash.
