How to Fluid Film your 3rd Gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by InSight Retrofits, Oct 11, 2016.
  1. Oct 3, 2023 at 6:17 AM
    #321
    frahengeo
    frahengeo Well-Known Member
    Adam
    Tacoma Shopper --> Owner
    Man...this type thread hits me right in the sweet spot of my OCD.
    Derry Murbles likes this.
  2. Oct 9, 2023 at 12:36 PM
    #322
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    UPDATE: The graffiti adaptors that I bought on Amazon did not fit the Cosmoline cans (too small). I drilled out the end that goes on the can to make it work. I used a #25 drill bit which is half way between 9/64" and 5/32".
    You really need an extension to get in all of the inaccessible places and the small hose fits in a lot of holes that a full size gun won't.
  3. Nov 5, 2023 at 9:57 AM
    #323
    Mesopotamia
    Mesopotamia Member
    eastcoast
    2023 OR AC Blue Crush
    LOL @ me attempting with 4 rattle cans of woolwax clear. Got me a solid coat on the exterior frame, the rear diff and most other random ends. Sprayed the spare tire mount. Ordering another 6 cans to spray another layer and catch some hard to reach areas later this week. its a start
    deusxanime likes this.
  4. Nov 28, 2023 at 2:41 PM
    #324
    PooTaco
    PooTaco Well-Known Member
    Utah
    2020 Tacoma Access SX 4x4
    I just did the fluid film today, I only used 3 cans and it did just fine.
    On heavy coated areas I used a rubber glove to rub it in a bit.
    I did however get some on my exhaust and did my best to remove it.
    Question, is it flammable after being sprayed and sitting?
  5. Nov 28, 2023 at 3:17 PM
    #325
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    I don't think it is flammable, just really stinky as it burns/cooks off.
  6. Nov 28, 2023 at 7:14 PM
    #326
    PooTaco
    Utah
    I can still smell it on my hands
  7. Dec 20, 2023 at 6:07 PM
    #327
    Renniks
    Renniks Active Member
    Haven't seen much online from people that used it on a vehicle for 10-15-20 years. Where did rust become a problem? Would really be interested in long-term results from people. It seems proven that at the 6-8 year mark FF vehicles are virtually rust free, and untreated cars are starting to rust at this point.
    Just coated my new 23 Tacoma so it's fresh on my mind. I used a spray gun, and the rocker access thru the plugs only allow the tip of the 360 nozzle in, and I feel I need a better solution -- the ability to snake a line in there. Also does not fit in any doors but the hole at the front door latch, so I need to either pull panels or drill a hole, or ideally figure out a way to create a 1/8" 360 wand extension for my spray gun.
    Anyone have advice?
    PooTaco likes this.
  8. Dec 20, 2023 at 6:13 PM
    #328
    PooTaco
    Utah
    I only did the underneath of my vehicle, adding it to the inside of doors might cause issues to my speakers, but I might be wrong...
    Renniks likes this.
  9. Dec 20, 2023 at 6:20 PM
    #329
    Renniks
    I really think you should coat the inside of the door at the pinch seam. I even sprayed it on the outside seam and then wiped down the weather stripping with Clorox wipes.
    PooTaco[QUOTED] likes this.
  10. Dec 23, 2023 at 1:26 PM
    #330
    635NinOR
    635NinOR Member
    2021 TRDOR DCLB
    One thing to consider when applying FF, whether from the rattle can, or via a spray gun, is wearing a respirator. The FF is aerosolized during application. Your face, nose, and mouth are probably pretty close to the underside of the truck and getting bounce back. I've found that a tight-fitting half face respirator with organic vapor cartridges work best for keeping this stuff out of your lungs and respiratory system. This stuff smells enough as it is as it burns off the truck. I don't want to taste or smell this any more than I have to!
    Hope this helps folks and keeps you safe.
    gsubioguy and PooTaco like this.
  11. Dec 24, 2023 at 3:46 PM
    #331
    PooTaco
    Utah
    When I used FF on my under carriage I had safety glasses and a N95 mask.
    Fluid film does stink imo.
  12. Aug 24, 2024 at 5:06 AM
    #332
    Wastah
    Wastah Member
    21 Sport MT
    Anyone have recommendations for shops that apply fluid film professionally? I'd like to get my third gen coated. Have had very good results on trucks in the past. Mass or surrounding areas? Thanks
    SilverBulletII likes this.
  13. Aug 24, 2024 at 6:26 AM
    #333
    SilverBulletII
    SilverBulletII Well-Known Member
    New England
    2017 Silver Tacoma SR, MT, 4 cylinders, 4X4
    I’ve had my 3’rd gen Tacoma Fluid Filmed and Wool Waxed by both a pro shop and by Jason who is a Tacoma World member. And, Jason does a better job. He’s located in SE MA. Sign up soon !
    https://www.tacomaworld.com/threads/woolwax-undercoating-spring-summer-fall-2024.828599/
    gsubioguy and Canadian Caber like this.
  14. Oct 9, 2024 at 2:36 PM
    #334
    Fye123
    Fye123 Well-Known Member
    2022 TRD off road.
    Question on this. What are people doing to get the fluid film behind the fender liners? Are they pulling fender liners and wheel well liners?
  15. Oct 9, 2024 at 2:57 PM
    #335
    probby19
    probby19 Active Member
    Pat
    Colorado
    2019 TRD OR - 2004 SR5 5-speed 4x4
    Possibly a dumb question here, but how necessary is this for someone who lives in the Denver area and travels up to the mountains 10x +/- a winter?
  16. Oct 9, 2024 at 6:44 PM
    #336
    PooTaco
    Utah
    No, I just get it the best I can from underneath.
    Does Denver get snow? Is salt used on the roads?
    gsubioguy and Fye123[QUOTED] like this.
  17. Oct 9, 2024 at 7:14 PM
    #337
    probby19
    Pat
    Colorado
    I do not believe they salt the roads in Colorado.
    We do get snow once in a while but it doesn’t stick.
  18. Oct 9, 2024 at 9:53 PM
    #338
    PooTaco
    Utah
    I would take a look underneath just to see how the frame looks.
    Stuck in VT likes this.
  19. Oct 30, 2024 at 11:11 AM
    #339
    Mesopotamia
    Mesopotamia Member
    eastcoast
    is it recommended to clean last years film off any portions of the frame before reapplying this year? just plan on spraying everything over same as last year. thnx
  20. Oct 30, 2024 at 11:28 AM
    #340
    deusxanime
    MN
    Nope just keep layering it on. It slowly wears down over time, so you want to respray it over the top, but no need to remove the old stuff. High contact areas are going to need it the most - wheel wells, front of A arms, front of rear axle, etc. Just don't spray it on the exhaust or it'll be (extra) stinky for awhile.
