How to flush the cooling system?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coehorn1, Mar 24, 2010.
  1. Mar 24, 2010 at 2:47 PM
    coehorn1
    coehorn1 [OP] Well-Known Member
    '03 4x4 2.7I4 5sp "beast"
    What's the beat way to flush the cooling system on a 2.7 I4?
  2. Mar 24, 2010 at 2:49 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    have the coolant exchanged done by a machine...Should run you about $60-70.
  3. Mar 25, 2010 at 7:24 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    drain and fill run for an hour drain and fill again. :) idk thats what i did worked pretty good.
  4. Mar 25, 2010 at 7:30 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I had mine done professionally. They did the service but I provided the fluid.
  5. Mar 25, 2010 at 7:31 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    when i put in my sc, just drainging it wont even cut it, there is soo much that was held up, i would get it flushed
  6. Mar 25, 2010 at 7:44 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When my husband and I did it (years ago) and probably not the best way to do it, but it worked and nothing bad every happened after that.
    Drain the radiator and fill it with water. Make sure the drain cock is closed. Start the truck and let it run until the thermostat opens up so the water cycles through the system. My husband actually had the radiator cap open and poured more water in as the thermostat opened since the system wasn't completely full. A couple minutes......shut the truck off, let it cool down. Drain the radiator again. I think we repeated that step twice (with water). Drain and put 50/50 anti-freeze in and once again, let the truck run and let the system cycle. This time - you need to watch the coolant level and top off as needed after the system cycles and works out the bubbles.
    We used regular tap water for flushing. Used distilled water to mix with the anti-freeze.
