How to get a higher lift?
Discussion in '1st Gen. Builds (1995-2004)' started by RoyalThunder, Jan 16, 2013.
  1. Jan 16, 2013 at 10:03 PM
    RoyalThunder
    RoyalThunder [OP] Know Hope
    Orange County CA
    03 PreRunner V6
    im thinking just a solid 3 would be good (looking for the cheapest route to take) not an offroad junkie but i want to tear up some nice trails
    Kinda want to stay away from body lifts ive heard they suck(really stiff ride)
    I currently have 2.5 spacers front 1" block in rear
    Also would 285/75R16 size tires make a difference i currently run 265/75R16
  2. Jan 16, 2013 at 10:13 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Eibach/toytecs on 5100s should get u a solid 3"
  3. Jan 16, 2013 at 10:17 PM
    Blacktacoma23
    Blacktacoma23 CO
    Denver
    2011 TACO
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, Nitto Mud Grapplers, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5%/30% tints, 2 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, JBA Long Tubes, URD o2 sims, Trail Gear bumper/Sliders, Crown brake lines F/R
    You trying to get 3" on top of what you already have?
    edit:
    2wd or 4wd?
  4. Jan 16, 2013 at 10:19 PM
    RoyalThunder
    Orange County CA
    03 PreRunner V6
    Nah probably replace what i hve
  5. Jan 16, 2013 at 10:19 PM
    RoyalThunder
    Orange County CA
    03 PreRunner V6
  6. Jan 16, 2013 at 10:20 PM
    williamsdouglas73
    williamsdouglas73 Well-Known Member
    doug williams
    redding
    97 tacoma dlx 4x4
    Bilstien adjustable 5100's up front, Trail-gear stinger bumper, custom fab stop sign skid plate, removed mud flaps
    get the wheelers three leaf progressive aal and drop shackles in the rear paired with the eibach springs and billies 5100, will give you aprox 3 in the front and 3 in the back depending on the shackles. plus the ride will be alot better with the eibach's vs the spacer.
  7. Jan 16, 2013 at 10:23 PM
    NW4RUNNER
    NW4RUNNER Well-Known Member
    4 runner trail
    Truck looks sweet. Just upgrade to 285s
  8. Jan 16, 2013 at 11:20 PM
    RoyalThunder
    Orange County CA
    03 PreRunner V6
  9. Jan 16, 2013 at 11:25 PM
    DSully72
    DSully72 2WD Problems
    Daniel
    Appling, GA
    04 PreRunner TRD Off Road
    go either OME or bilstein 5100s and eibach springs on the front and as far as the back goes, i aals will really stiffen up ur ride. im not sure about the blocks. never dealt with them. but although it may be a little pricey, new OME springs for the rear isnt a bad way to go. eventually i wanna score me the toytec ultimate coilover kit. and some new rear springs. just running basic skyjacker 3" with aals right now. as far as the tires, if you dont want any rubbing, stick with what youve got. but if you wanna upgrade to a 285/75R16, you may want to look into what you need to trim first. you may be able to get out of the cab mount chop with spacers or rims with a smaller backspacing. still may have to do a little on the fenders though. imo its not worth it for the extra half inch of lift you get from them.
  10. Jan 16, 2013 at 11:44 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    I had 285s with 2.5 spacers and only rubbed at full lock on the frame.
  11. Jan 17, 2013 at 4:20 AM
    DSully72
    Daniel
    Appling, GA
    nothing on the fenders? i see a lot of people trimming down their fenders to fit. what rims were u running? wheel spacers?
  12. Jan 17, 2013 at 4:32 AM
    tram
    tram Well-Known Member
    Timmins, Ontario
    2000 3.4L V6 4wd
    3'' Ultimate Toytech suspension lift: - Front Bilstein HD 650lb coils - Light Racing 25460 Upper Control Arms - OME Dakar Leafs - Rear Bilstein 5100 Extended length rear nitrogen gas shocks -Magnaflow performance Catback -ARB Deluxe Winch Bumper -Bushwacker Extend-A-Fender flares
  13. Jan 17, 2013 at 12:27 PM
    DSully72
    Daniel
    Appling, GA
    what he said ^ lol. thats exactly what i want down the road
  14. Jan 17, 2013 at 2:18 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  15. Jan 17, 2013 at 2:22 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    I was running stock wheels and no wheel spacers. Only started rubbing on the plastic when I got the 12.50s
  16. Jan 17, 2013 at 4:39 PM
    RoyalThunder
    Orange County CA
    03 PreRunner V6
    Do you guys recommend the 3" skyjacker lift
  17. Jan 17, 2013 at 4:52 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Lift spindle is what I'd do. And for the back mutil AAL or full leaf pack.
    You will significantly improve the ride up front (back to stock) and the ride in the back would be improved as well.
    I believe Solo Motorsports makes spindles for your truck. Great company and their product is real high end. Been around for a long time too.
    OOOOOP, not the cheapest route to take.... stick with what you got!
  18. Jan 17, 2013 at 5:37 PM
    DSully72
    Daniel
    Appling, GA
    I have the very basic kit. Uses factory coils on new front shocks. Same concept of a spacer lift actually. Basically from the plate that the spring sits on down is longer than factory shocks. Then I got aals for the rear. Like I said, it'll stiffen up the ride some but it was pretty inexpensive. Got mine from Autoanything. Don't forget to look up coupon codes too. Only pain in the dick was using a spring compressor to get the coils of old shocks and onto the new ones
  19. Jan 17, 2013 at 5:46 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    I got over 3in with my 5100 and eibachs
  20. Jan 17, 2013 at 5:48 PM
    DSully72
    Daniel
    Appling, GA
    always a good way to go!
