How to get a six inch lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eric.gumberry, Jul 23, 2016.
  1. Jul 23, 2016 at 5:25 PM
    eric.gumberry
    eric.gumberry [OP] Well-Known Member
    Eric
    North Carolina
    2006 6 speed 4x4
    17 in methoods and 265/70r17, 884s and billys at 1.75 in front no rear lift
    As of right now I have ome 884 and 5100s on all for corners 5100s are at zero I think what would I have to do to obtain a 6 inch lift or how every much lift it takes to be able to run 18x12 rims
  2. Jul 23, 2016 at 5:54 PM
    Pigpen
    Dan
    Northwest Montana
    Are you 2wd or 4x4? On a 4x4, a drop bracket is the only way to get a 6 inch lift. On a 2wd, you could put 4" spindles in addition to the 884/ 5100 combo.
  3. Jul 23, 2016 at 6:04 PM
    eric.gumberry
    Eric
    North Carolina
    2006 6 speed 4x4
    Ohh I may just need to get a smaller rim and 12 wides for my lift I have right now
  4. Jul 23, 2016 at 7:49 PM
    Pigpen
    Dan
    Northwest Montana
    16" is the smallest that will fit on 6 lug trucks due to the size of the brake rotors and the calipers.
