How to get a wire out of wiring harness on fuse panel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Backt, Dec 21, 2015.
  1. Dec 21, 2015 at 12:19 PM
    Backt
    Backt [OP] Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Do they pull out or is there a clip that holds them in that needs to be pressed to allow the wire to slide out?
  2. Dec 21, 2015 at 12:24 PM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Are you trying to pull a single wire out of its plug?
    Or the entire plug out of its recepticle?
    Single pins usually require a small tool to release the pin clip. There's some videos on YouTube on how to do it.
  3. Dec 21, 2015 at 12:33 PM
    Backt
    Oregon
    Trying to pull individual wires out to tie them together for the Jumper Led DTRL's
  4. Dec 21, 2015 at 1:21 PM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    You will usually need a mini flathead (watch repair type) or an ice pick to unlock the terminal from the connector that the wire is in. There are quite a few different styles though so how you unlock the terminal really depends on what connector you are dealing with.
  5. Dec 21, 2015 at 1:25 PM
    Backt
    Oregon
    I found the door on the top middle of the connector that pops up that is ultimately a lock. I opened that up but have no idea what needs to be done to actually un clip the wire from the terminal. Do I need to pry or just insert it into the hole?
  6. Dec 21, 2015 at 2:03 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    all these connector types have special small tools to unlatch the pins, they pop out easy with the special
    tool, problem is finding a kit that has all of them
    tiny screwdrivers can do it too
    this video is pretty useful (it is generic not vehicle specific)
    https://www.youtube.com/watch?v=S9xeg_3eREc
    google 'tiny pin connector removal' for other ideas
  7. Dec 21, 2015 at 2:10 PM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Ah I see what you are looking to do. I don't normally re-use terminals, I would just crimp the wires into a new terminal in your case. If you don't have a new terminal to use though you may be able to carefully open the old terminal up and then re-crimp it.
