How to get dirt off tires??
Discussion in 'Detailing' started by Zac808, Nov 3, 2009.
  1. Nov 3, 2009 at 9:02 AM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I used dish soap and a tire scrub brush. I got the dust/dirt off the center of the sidewall but that's about it. There is a perfect clean 3 inch ring in the center of the sidewall where the lettering is. But the ring around the outer edge and inner edge won't get clean. Does anyone have any tricks up their sleeve?
  2. Nov 3, 2009 at 9:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you tried useing a brush, and a little dish soap?
  3. Nov 3, 2009 at 9:19 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    STP Son of a Gun. Does a great job on the plastic mudflaps too.
  4. Nov 3, 2009 at 9:20 AM
    smallcandle
    smallcandle The clown has no penis...
    Brian
    South-central Kansas
    02 DC TRD SR5 4X4
    Deck plate mod, Maglite console mount, Husky Liners front and back, Black powder coated OEM rims, BF Goodrich All-Terrain KO's 265/75/16, Grillcraft MX black insert, Hella 500FF mounted behind grill
    Tire bleach and a tire brush will work.
  5. Nov 3, 2009 at 9:20 AM
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Westley's Bleche White should remove any dirt and grime from the sidewalls. Also pick up a good tire scrubbing brush to work the Bleche White around after it sets for 30-60 seconds.
  6. Nov 3, 2009 at 9:23 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Yeah, I know. Sounds like I should be driving a Ridgeline.
  7. Nov 3, 2009 at 9:27 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    lets see ...................elbow grease?
  8. Nov 3, 2009 at 9:42 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I use a 50/50 mixture of purple power and water in a spray bottle first, then I mix car wash and a splash of purple power in a bucket for the brushes. I use a tire/wheel brush with relatively stiff bristles to clean the tires, rinse, then follow up with a soft bristled wheel brush to clean the wheels then go back over the tires one more time with that.
    What I hate is that the tire shine on my tires makes the soap go flat really quick. I try to use tire shine sparingly and make sure I rub/wipe it in really good with a foam applicator. I use the aerosol advance auto parts brand tire shine.
    I have also used the bleach-white stuff in the past however I use purple power since its a multipurpose cleaner that I can use for other stuff. I buy the big jugs of it.
  9. Nov 3, 2009 at 9:45 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    i had that brown stain on my tires from using tire shine then going out dirt roads. i used dish soap and it seemed to work the best. gotta find something better though. and im not using tire shine as much anymore
  10. Nov 3, 2009 at 9:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Well...He made a post about what wheels look best, so he has no room to make comments like that. ;)
  11. Nov 3, 2009 at 9:48 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Hide it with more mud.:D
    Simple green, purple power both real good cleaners.
  12. Nov 3, 2009 at 9:54 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Good idea. I'll just pick up a can of spray on mud so the truck matches too. LOL.
  13. Nov 3, 2009 at 9:55 AM
    Afwrestler1986
    Johnstown, NY
    :thumbsup::mudding:
  14. Nov 3, 2009 at 9:56 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Armor all tire foam works best for me. Takes mud and dirt off and leaves a rich black look no shine at all.
  15. Nov 3, 2009 at 10:06 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    I used a degreaser and barley had to scrub. The dirt just fell right off.
  16. Nov 4, 2009 at 7:12 AM
    Warren Thompson
    Warren Thompson GeoTaco
    Warren
    Elko, Nevada
    '06 Tacoma DC TRD Sport RadRed
    Be careful with that! Remember your tires are a petroleum product too!!
  17. Nov 4, 2009 at 7:15 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    x2 actually try dirt doesnt necisarily stain rubber
  18. Nov 4, 2009 at 7:17 AM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    :laugh:
  19. Nov 4, 2009 at 7:50 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I use a hard brush, soap of any kind and loads of elboy grease. Keeps the tires clean longer than the spray on stuff. If its dirt/mud use high pressure, like at a carwash then get it with a hand brush at home.
  20. Nov 4, 2009 at 8:00 AM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    mmm maibe its easier if you just pull up to a wash it youre self car wash
    the ones with the power washers and just clean them real quick with the power washers.
