How to get marker lights to operate when locking, and unlocking doors.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by PURCTRY, Oct 16, 2018.
  1. Oct 16, 2018 at 10:17 AM
    PURCTRY
    PURCTRY [OP] New Member
    2017 TRD Sport
    6" RC Lift 35" Nitto Ridge Grapplers Custom hood wrap
    Ok, so is it possible to have your marker lights light up when locking or unlocking your doors? I currently have the beeping noise, and I have found in my settings for the vehicle a place to turn this function off, and on however it does not seem to work in my truck. Any help would be much appreciated.
  2. Oct 16, 2018 at 10:42 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
  3. Oct 16, 2018 at 10:49 AM
    PURCTRY
    2017 TRD Sport
    Maybe I was misunderstood, There is a way to enable the marker lights in your customization vehicle options. There is a box to check which I assume enables the lights to blink when locking, and unlocking the doors. However no matter if the box is checked or not my lights will not blink with the key FOB when locking or unlocking. I hear the audible beep, and I can disable that. But the light function does not seem to work.
  4. Oct 16, 2018 at 10:52 AM
    vuTron
    SF Bay Area
    oh, ok... I thought you meant marker lights on your grille. my bad.
    as for your issue, your marker lights def should blink when you lock your doors... mine do... jus play around with the settings more.
  5. Oct 16, 2018 at 5:21 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    They work when the truck is on? Bad bulbs or something? Bad wiring?
