how to get to front wheel bearings?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greensystemsgo, Aug 27, 2011.
  1. Aug 27, 2011 at 12:00 PM
    Greensystemsgo
    Greensystemsgo [OP] 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    press on standby to press them out, but how do i get to them? does the front hub with spindles not just come off? so frustrated gr.
    truck in sig, 99' 4x4 ifs.
  2. Aug 27, 2011 at 12:03 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    search ncttora.com for a factory service manual. very helpful
  3. Aug 27, 2011 at 12:06 PM
    Greensystemsgo
    Dirty Nickers
    Peoria, AZ
    Bone Stock.
  4. Aug 27, 2011 at 12:10 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yeah looks like it. I was not sure thought. On the 2nd gen its 4 bolts and slides right out.
  5. Aug 27, 2011 at 12:11 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    It's pressed on the wheel hub. You need to pry it out of the spinde
  6. Aug 27, 2011 at 12:15 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    In this aspect I'm so glad the 2nd gen is the way it is. Saved me about 800 in shop costs when I did my bearings.
  7. Aug 27, 2011 at 12:17 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :confused: It's the same set-up as the first gen
  8. Aug 27, 2011 at 12:18 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    I didnt have to use a press to remove the hub assembly... Loosen 4 bolts and coax out the assembly with rubber mallet. If it is the same... Well, Shit'chyeah! Thats better for OP
  9. Aug 27, 2011 at 12:20 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yes, the hub assembly should come out of the spindle, it just takes a coaxing. The wheel bearings should have needed pressed off of the hub.
  10. Aug 27, 2011 at 12:21 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    yes. only the bearings them self need the press work
  11. Aug 27, 2011 at 12:23 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Look!!!..........................a squirrel!!!!!!!!!!!
  12. Aug 27, 2011 at 12:24 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
  13. Aug 27, 2011 at 12:28 PM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
  14. Aug 27, 2011 at 12:41 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Yep, & of course its always best to have them pressed out by a shop or wherever you can find a good vice & press if you dont have one, with a few tools & a little skill it isn't that big a deal, pop the caliper & hardware related shit outta the way, pop off that round inspection cover on the center of hub , you may or may not have to knock the small bends in lock ring/nutt/washer (which ever applies, i've seen all 3 before)straight with small chisel & mallet, getting the old race out is pretty easy, if you don't have a vice (or a press for that matter) you can use a couple bricks, 4x4 blocks, whatever to get a little space between the hub/bearing assembly
    now get a screwdriver & pry out the old seal get a big ass socket, one that is just undersized to the bearing race you are about to send on its way to the shit can, place that slightly undersized socket S Q U A R E L Y on the old race & with a good single jack about 2 or 3 good smacks will have it out
