How to get to the bed through the back seat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Aug 21, 2019.
  1. Aug 21, 2019 at 5:41 AM
    Icepuck72
    Icepuck72 [OP] Well-Known Member
    Mark
    Richmond, VA
    2006 DC TRD
    OME 885's, Dakars, TRD Trail Edition Wheels, 285x75x16 Goodyear Duratracs, Magnaflow 12256 muffler, Fog Light mod, 2 Baby seats
    Is there an easy way to do this? I want to have my fridge in my back seat, but using the the 110v in the bed. I'd just rather do it this way than using my cig plug. Plus it seems to keep up better than using the 12v cig plug.
  2. Aug 21, 2019 at 5:54 AM
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    Possibly use a hole saw to drill something like a 1" hole through both the back of the bed and straight through to the cab behind the seats. Obviously remove the seats first. Then insert some rubber grommets. I'm not sure how 100% water proofed it'll be. Just an idea in my wonderful mind.
  3. Aug 21, 2019 at 6:03 AM
    surfandturf
    surfandturf Well-Known Member
    CT
    2014 TRD DCLB
    There is a thread on how to do 400w anytime mod and also put a household outlet in the back on your console. I'd do that before cutting holes
    Toy4me, stickyTaco, NotUrTaco and 4 others like this.
  4. Aug 21, 2019 at 6:51 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    there are drain holes under your seat. you can cut a hole next to the cubby in the back, route the wire along the factory loom up to the drain hole under your seat and into your cab.
  5. Aug 21, 2019 at 6:58 AM
    Muddinfun
    Muddinfun Well-Known Member
    The inverter is under the center console. Mount a 110v outlet in the back of the center console. If you're not comfortable splicing wires, there's a TW member that makes a plug and play harness.
    Icepuck72[OP] likes this.
  6. Aug 21, 2019 at 7:00 AM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  7. Aug 21, 2019 at 7:05 AM
    MDub07
    MDub07 Well-Known Member
    KS
    2012 Tacoma AC 4WD SR5 SSM
    mtip and surfandturf[QUOTED] like this.
  8. Aug 21, 2019 at 8:17 AM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Outstanding!!! This is perfect. Thanks guys
    Muddinfun likes this.
  9. Aug 21, 2019 at 8:54 AM
    surfandturf
    CT
    2014 TRD DCLB
    Good luck, the 400w and outlet mod is fairly easy. I did it myself on a sat afternoon
  10. Aug 21, 2019 at 8:56 AM
    surfandturf
    CT
    2014 TRD DCLB
    I would recommend an outlet the gets securely bolted into place vs the push-in style with ears that collapse and expand to hold it in place. Several times I pulled the plug out of the console because the it was not secure enough
    bprout and SR-71A like this.
  11. Aug 21, 2019 at 8:59 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Make sure your fridge will actually run on only 400W before you start cutting shit...
    Can approximate using the following W=(120v)(.95)(amps)
  12. Aug 21, 2019 at 9:00 AM
    SR-71A
    Zack
    Southern Maine
    As you may know the inverter will shut off to protect itself if something tries to take than 400W
  13. Aug 21, 2019 at 9:08 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    This would be the route I would take. Much easier and cleaner to tap into this location,run the power cable under the front seat carpet to the door sills, straight behind the back seats and up to the fridge. I wouldn't recommend a long power run to the back of the bed. That wire may get too hot or kinked over time.
  14. Aug 21, 2019 at 11:10 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    This ^
  15. Aug 21, 2019 at 7:31 PM
    Icepuck72
    Mark
    Richmond, VA
    2006 DC TRD
    Fridge is super low amps....it's run off of it before....when truck is off it's runs off of a Jackery 240 portable power station and solar.
    SR-71A[QUOTED] likes this.
