How to get unstuck/start in snow or mud in a manual transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Btosh, Jan 9, 2022.
  1. Jan 10, 2022 at 8:38 AM
    J A Red
    J A Red Well-Known Member
    Peachland, BC
    2021 DCSB TRD Sport 6MT WCP
    KO2s, 6112/5160,
    If you have an OR or Pro put it in 4Lo and engage A-Trac. Like other's have said, go out and practice, just don't ride the clutch.
  2. Jan 10, 2022 at 8:49 AM
    gearcruncher
    Canadain bumper technician
    Time to talk with your insurance company .
    Speak loudly and push them ....get other members from BC to join in your pursuit .
    If Ontario gives you a discount , I cant see why BC would have a problem ?
    You guys see a similar amount of snow if not more than Ontario .
    Its not a huge discount .....Maybe save $150 a year on a regular policy over a year .
    I run studs in Ontario . If studs are allowed in B.C. , I highly suggest running them as a winter set .
    Makes a huge difference in winter traction .
    I will add that snow tires without studs last 5 years on average . Adding studs to winter rubber allows for an additional 40K .
    Speedfreak[QUOTED] likes this.
  3. Jan 10, 2022 at 8:52 AM
    Jammers1971
    Jammers1971 Well-Known Member
    James
    2019 Tacoma TRD Off-Road 4x4
    3.5 lift, 315/75-16, DIY hybrid front bumper, skids, sliders, ditch lights, hood struts, tailgate lock, bed rack, custom exhaust, horn meant for an actual truck, neoprene seat covers
    I second this option.
    No snow where I am now, but 24 years experience in Western Canada, lol.
  4. Jan 10, 2022 at 9:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    All good advice here.
    The one other thing is that if you are spinning at idle in 1st, use your clutch to rock you and modulate the throttle with the clutch out to stop spinning / get traction.
    If you are in deep and not going anywhere, try to stop spinning as soon as possible as you will just go deeper. Reverse course for a run / momentum is gonna be a better path forward, unless you are on a grade.
  5. Jan 10, 2022 at 9:07 AM
    remote
    remote Well-Known Member
    Minnesota
    2021 DCSB Sport Cement
    4000 rpm??? IDK
  6. Jan 10, 2022 at 10:06 AM
    lostMarbles
    lostMarbles A Lost Cause
    Micah
    Alaska
    2021 3.5L 6MT, and 1997 2.7L 5MT
    The wingnut behind the wheel
    Winter tires help a lot. If predominantly dealing with snow studs don't add anything. However, if you have a lot of ice (such as costal areas) studs help quite a bit.
    While I would not do this all the time, up to about 3 seconds of ridding the clutch does not cause much harm. If you need more than 3 seconds it is time to employ things like 4H, 4L, A-TRAC, chains, Etc.
    On clear water ice with a decent grade, chains are about the only answer. If pushing through deep, heavy snow, once again chains are the answer.
    The manual says no chains on the front tires, which sucks.
    tonered likes this.
  7. Jan 10, 2022 at 10:23 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you really want them, get some spacers to clear the knuckles and get the chains on tight to not hit the UCA ball joint bolt. That was going to be my approach and to only run the spacers temporarily, but ATs have done all that I have needed for our area. All the deep snow places get blocked for snowmobiles to play.
    lostMarbles[QUOTED] likes this.
  8. Jan 10, 2022 at 12:25 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don’t do anything particularly special with the clutch when driving in low traction situations. Don’t slip the clutch too much in any situation. It wears it out. If wheel spin is unavoidable, let the clutch out all the way and apply light throttle. Let the tires spin instead of the clutch.
  9. Jan 10, 2022 at 12:28 PM
    DuffyBank
    DuffyBank Well-Known Member
    but they will penalize us for not having them
  10. Jan 10, 2022 at 12:30 PM
    DuffyBank
    BC has a single insurer, the government run ICBC
    M&S or 3PMSF mandatory from Oct 1- either March 31 or April 30 (depending on where you drive).
